shock broke
Discussion in 'Suspension' started by jason1kyle, Jul 24, 2010.
  1. Jul 25, 2010 at 1:53 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    No worries. It happens fairly often that's why it was the first thing that came to several member's minds.
  2. Jul 25, 2010 at 1:57 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    you can still use them. just set them at 2.5 and use your stock springs. then sell the ome coils to me hahaha
  3. Jul 25, 2010 at 2:02 PM
    VooDoo
    VooDoo More Cowbell!
    Carter Ivey
    Baton Rouge, LA/ Starkville, MS
    '06 DC LB PreRunner
    Well at least now you know how to NOT install them next time...
  4. Jul 25, 2010 at 2:19 PM
    bikewrench
    bikewrench Well-Known Member
    East Coast
    01 4x4 xtra-cab 2.7l
    OME 881/struts, 1.5" aal w/ Nitro 9000s, Sirius
    Did you try to reinstall the correct way. If the perch acts as a sleeve around the clip, you might be able to salvage it after all. Can't hurt to try.
  5. Jul 25, 2010 at 2:24 PM
    Yoytoda
    Roland
    completely stock
    i wouldnt. if the groove is comprimised too much it might hold the spring for now but the first big bump you hit it could make a scary ride. and it could "hurt"
  6. Jul 25, 2010 at 2:36 PM
    bikewrench
    East Coast
    The groove shouldn't have taken much damage. The perch slipped because the perch was upside down and forming a sleeve to prevent the clip from spreading and slipping. If anything would have taken some stress/damage, I would look at the clip itself to see if its deformed. From the pics, it just looks like the clip spread from the downward stress and nothing there to reinforce it.
    All you have to do is mike the groove and one you didn't use to see if they are the same depth. I see the scoring, but just put the split in the clip there. From the pics, there looks to be a scrape where the perch slipped, the clip is still in place which means that is still has some sort of shape. If they are going to slip, they more than likely will in the compressor(I assume you are using the wall type).
  7. Jul 26, 2010 at 7:37 PM
    jason1kyle
    jason1kyle [OP] commander101
    JOHNSON CITY, TN
    08 double cab trd sr5
    77 series k&n 1inch throttle body spacer dual in single out catback exhaust (exhaust pros)
    well after kicking myself in the dick a little bit i got the shocks and springs installed today with the aal truck looks good pics to come
  8. Jul 26, 2010 at 7:42 PM
    bikewrench
    East Coast
  9. Jul 26, 2010 at 7:45 PM
    Coolidge
    Coolidge Well-Known Member
    So Cal, Ca
    2003 Pre Runner
    King coilovers frt +3". Bilstein 5100 shocks rear w/AAL, K&N FIPK, Magnablow exhaust, Billet grill, clear corner lights, Sony stereo, JBL, Sub etc.
    True that! ;)
  10. Jul 27, 2010 at 7:34 AM
    TexasTacoma37
    You you re-used the damaged shock? What height did you set them at?
  11. Jul 27, 2010 at 9:07 AM
    Masada
    Masada Well-Known Member
    Taylor
    Laveen, AZ
    05 Tacoma 4x4 TRD Off Road
    All Pro Steel Plate Front Bumper| All Pro Light Bar| All Pro IFS Skid Plate| All Pro E-locker guard| PIAA 510 Fog Lights| Hella 700FF| Fox 2.5 Coilover| Bilstein 5100 on the rear| BHLM| Grill Craft MX Series insert| Added two D-rings to bed|AVID Off Road sliders| AFE Dry Flow S| Gibson Cat Back| Custom Bedbar with hilift mount| Camburg 1" Uni-Ball UCA's| Hi-Lift 48" Extreme
    it won't affect anything, the samething happened to me and I ran them at 1.75" for a couple months and then 0" with 886. Never had an issue with the shocks.
  12. Jul 27, 2010 at 9:09 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    It WILL affect something. The integrity of the seat was compromised. Just because nothing happened to you, doesnt mean it wont to someone else.
  13. Jul 27, 2010 at 9:28 AM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    X2^^^
  14. Jul 27, 2010 at 10:01 AM
    bikewrench
    East Coast
    I don't think that is was the groove that was compromised. The clip spread at the break and slipped out of the groove beacuse is didn't have the perch over the clip the right way to reinforce it. All you need to do is mike it and check the depth and make sure the grooves shoulders are not rounded.
  15. Jul 27, 2010 at 10:51 AM
    #35
    Yoytoda
    Roland
    completely stock
    Just my .02 cents. A couple hundred bucks to buy new shocks would be a cheap price to know that the groove isnt comprimised. there would probably be no problem, so you hope. but i wouldnt risk an accident for $200. If a large impact ever happens you will always wonder. Over time there is a chance that due to the section being comprimised the ring can slowly work its way out of the groove. Not likely but its possible and not worth the risk to me...
  16. Jul 27, 2010 at 11:01 AM
    #36
    Masada
    Taylor
    Laveen, AZ
    This is what happened to me too. Because the coil seat wasn't over the snap ring it just pushed it out. The grove on mine wasn't affected so there wasn't an issue for me.
  17. Feb 22, 2016 at 3:05 PM
    #37
    hobiesan
    hobiesan Well-Known Member
    Austin
    2009 TRD Sport DCLB 4x4
    ARE Cap with removable plywood bed/shelf, Bilstein 5100s, LED DTRL, Satoshi Grill, TRD Black Alloy Wheels, Goodyear Duratrac Tires
    just put 5100s on the front of mine, set at 0.85. Yea, that little snap-ring really worries me. Doesn't seem beefy enough to support the weight of the truck, especially off-roading.
