Shock collar adjustment stuck
Discussion in 'Suspension' started by Nalpak99, Jul 28, 2024.
  1. Jul 28, 2024 at 7:55 AM
    Nalpak99
    Nalpak99 [OP] Booty Hunter
    Kyle
    2005 Toyota Tacoma pre-runner
    mid travel
    I have a pair of icon coil lovers in the front of my Tacoma. I went to go adjust them to make them a little bit less stiff as the on road quality is a little too stiff for me. I am bending the tool and not able to adjust the collar it sees from either dark corrosion or both, is there any tricks to getting these unseized?
  2. Jul 28, 2024 at 8:03 AM
    Akguy
    Akguy Well-Known Member
    way up north
    23' Silver OR DCSB
    Try turning it the other way first
    Nalpak99[OP] likes this.
  3. Jul 28, 2024 at 8:04 AM
    Nalpak99
    Kyle
    mid travel
    Can’t believe I didn’t think of that. If i can get it to go the other way I can clean the threads and get it lubed up
  4. Jul 28, 2024 at 8:05 AM
    Akguy
    way up north
    23' Silver OR DCSB
    Is there a screw or allen bolt that locks the collar in place so it won't move on its own?
  5. Jul 28, 2024 at 8:07 AM
    Nalpak99
    Kyle
    mid travel
    There is, I took it all the way out and sprayed pb blaster in it
  6. Jul 28, 2024 at 8:17 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Compress the spring/remove the weight off the springs.
