Shock damage with single AAL lift only? weight in bed...
Discussion in 'Suspension' started by Evomike1, Apr 25, 2018.
  1. Apr 25, 2018 at 9:59 AM
    Evomike1
    Evomike1 [OP] Well-Known Member
    Glenwood Springs, CO
    2017 Tacoma Off-Road
    Sorry if this is a stupid question... 2017 Tacoma, I have about #200 pounds of constant weight on the rear, often much more, with bikes and camping gear it gets up there. I have lost about 1 inch just with the #200, and loaded down the truck is not fun to drive.
    My big question is, if I get a 1.5 inch lift out of the AAL above factory height (for me, 22" from the center of the wheel) do I need a set of longer travel shocks? Is there any danger with jacking up the rear 1.5 inches and not changing the shocks?
    I've thought about Hellwig helpers, not doing sumo springs, so lets not go there, haven't ruled them out completely. Thank you!
  2. May 1, 2018 at 8:32 AM
    Depoxy
    Depoxy Well-Known Member
    SoCal
    2010 Regular Cab 5-speed 4x4
    URD S/S, Eibach pro-truck @ 0.8" lift, hanook 265/75r16 AT
    Stock should work without a problem, but good shocks in the rear will work better and help reduce the amount of down travel lost. Bilstein 5100 or Eibach pro-truck shocks aren't too expensive and are much better than the stock ones.
    Evomike1[OP] likes this.
  3. May 2, 2018 at 1:25 PM
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    Unless he buys extended 5100s they will not be any better than stock. They are the collapsed and extended length as stock, which would not help with down travel.
  4. May 2, 2018 at 2:39 PM
    Evomike1
    Well, I kinda bit the bullet and ordered an set of ADS coilovers and resi rear shocks. Onward and upward. Thank you for the help! Haha
  5. May 2, 2018 at 3:30 PM
    Depoxy
    SoCal
    Looked it up and you are correct, same length but better valving for an aal. The eibachs are longer at 24" extended, so I thought the bilsteins would be as well. Either way, looks like OP bought nicer suspension than either option.
    Sub_Par[QUOTED] likes this.
