shock flip kit?
Discussion in 'Suspension' started by eight3one_offroad, May 6, 2010.
  1. May 6, 2010 at 10:01 PM
    eight3one_offroad
    eight3one_offroad [OP] Honey your two French Fries short of a Happy Meal.
    Richard
    Santa Cruz, California
    TRD Sport 4x4 with a few things.
    Optima Red Top 34R, OME 885 / N140S + 5100 rear, TSB leaf pack, Camburg Ball Joint UCA, Wheelers Diff drop, AEM Brute Force Intake with filter wrap, Summit Super Turbo muffler, Llumar 5% tint, Pioneer single din head unit, PIAA 510 Ion Crystal Fogs in stock location, Sonar LED tails. Sway Bar removal. Charcoal filter delete. Stant 11509 Locking Gas Cap.
    Hey guys,
    Where can I find the mount tabs to flip my current Bilstein rear 5100s? I need some type of brackets so the eye on the bottom of the shock is at the top end rather then bottom.
    Thanks,
    Richard
  2. May 6, 2010 at 10:02 PM
    RelentlessFab
    RelentlessFab Tacoma offroad armor fabricating beast Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 6mt to 03 SR5 to 08 Sport and 17 6MT TRD OR
    I think procomp makes some of those eye to stud adapters IIRC
  3. May 6, 2010 at 10:05 PM
    eight3one_offroad
    Richard
    Hmm... I can't find anything on those
  4. May 6, 2010 at 10:05 PM
    Dellosa89
    Dellosa89 Love peace and Taco Grease
    Brian
    Murrieta CA
    07 Prerunner TRD Off Road
    Fox 2.5 Coilovers, Camburg 1.25" UCA's, Icon RR, Icon aal,EVS foam bump stops, Borla Catback, HID Headlights and fogs, Defiant light bar, 3 hella 700 hid, Satellite Radio, Sony hu with 10'' sub, custom jetski rack, TRD seat covers, secondary air filter removed.
    Im pretty sure Total Chaos makes some
  5. May 6, 2010 at 10:07 PM
    eight3one_offroad
    Richard
  6. May 6, 2010 at 10:14 PM
    RelentlessFab
    Eric
    looks like it man! :)
  7. May 6, 2010 at 10:15 PM
    Dellosa89
    Brian
    Murrieta CA
  8. May 6, 2010 at 10:19 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    what does this do for the truck? i dont get it, i have seen guys do inverted forks on bikes, is this similar?
  9. May 6, 2010 at 10:20 PM
    eight3one_offroad
    Richard
    Schweeet, nothing like a search button a yahoo... so it can be possible to flip my current Bilstein 5100s the other direction with this bracket, correct boys?
    - Rich
  10. May 6, 2010 at 10:21 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    this lets you fit longer shocks ie the 5150's
    why are you wanting to flip the 5100's?
  11. May 6, 2010 at 10:21 PM
    eight3one_offroad
    Richard
    I think you get a little more travel but I'm not quite positive on that answer.
  12. May 6, 2010 at 10:22 PM
    eight3one_offroad
    Richard
    I thought maybe it would have soaked up the bumps better?
  13. May 6, 2010 at 10:24 PM
    08pretaco
    Oliver
    az
    oh...ok then try it and report back :)
    any rational behind this? any research or anything that makes you think it does or whatever?
  14. May 6, 2010 at 10:27 PM
    eight3one_offroad
    Richard
    Well I had a mountian bike with inverted forks and on the rough sections the inverted forks seem to ride smoother along the rough spots, rather then regular forks that compress from the top end. I'm not sure what made me think about doing this just another thing to do on the side...
    - Rich
  15. May 6, 2010 at 10:28 PM
    08pretaco
    Oliver
    az
    fo sho sounds likle a plan keep us posted!
  16. May 6, 2010 at 10:30 PM
    eight3one_offroad
    Richard
    Definantly, I'll buy it from Summit and see what its all about and let you know!
  17. May 6, 2010 at 10:32 PM
    08pretaco
    Oliver
    az
    if anything the things from summit will just make you get a rear lift and throw on some 5150's
  18. May 6, 2010 at 10:33 PM
    RelentlessFab
    Eric
    I may be wrong, but I think that the 5100's are only designed to be used in one orientation and they won't properly damp when the oil is on the other side of the shock? IDK maybe I'm wrong, but I think I remembered this from when a few guys bought the 5125's and installed them in the same orientation of the regualar replacement 5100s and they ended up having to flip them to make 'em work properly.....
  19. May 6, 2010 at 10:35 PM
    eight3one_offroad
    Richard
    Hmm I'll have to contact Bilstein and see if I can flip those 5100's the other direction, if not 5150s might be another route... but aren't those for lifted applications?
    - Rich
  20. May 6, 2010 at 10:37 PM
    eight3one_offroad
    Richard
    Good question there Relent... I'm going to call up peeps and see if this is possible or not, will get back and post here.
    - Rich
