Shock help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dctaconny, Sep 16, 2015.
  1. Sep 16, 2015 at 5:10 PM
    Dctaconny
    Dctaconny [OP] Well-Known Member
    Don
    Watertown, ny
    2021 T4R sr5p
    Ok so I have toytec aal on its way to me and I'm trying to get a set of 5100s for the rear as well but all I see is shocks for 0 to 1 inch lift. Anyone have a link to a site for the correct shocks I need. The aal kit says 1.5 to 2 inch lift
  2. Sep 16, 2015 at 5:12 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    The 0 to 1 will be fine as the AAL only really adds a 1/4 to 1/2 to the leaf pack.
  3. Sep 16, 2015 at 5:17 PM
    Dctaconny
    Don
    Watertown, ny
    2021 T4R sr5p
    Ok good to know. I was confused because the reviews on this aal said most achieve 2 inches of lift when installed is this correct?
  4. Sep 16, 2015 at 5:19 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Yes had them once
  5. Sep 16, 2015 at 5:30 PM
    Taco Nation
    Taco Nation Well-Known Member
    Zack
    Clinton, MS
    94.5 F350, 77 F150, 74 F100, 11 Jeep Grand Cherokee
    Lift, wheels, tires
    I'm have trouble understanding how adding 1/2" to the spring pack matters with the shocks. Maybe if you were measuring for u bolts it would matter. But the lower shock mounts are on the axle and the axle is being moved 2" away from the upper mount. Meaning you need 2" longer shocks. 5100's will be fine though.
  6. Sep 16, 2015 at 5:37 PM
    Dctaconny
    Don
    Watertown, ny
    2021 T4R sr5p
    What's your setup now
  7. Sep 16, 2015 at 5:43 PM
    Taco Nation
    Zack
    Clinton, MS
    Lift, wheels, tires
    I never had an AAL or the standard 5100's but I do have the 5100's rated for 3-4" of lift and ran them with 4" of lift and now with 7" of lift. What your looking at will work fine.
  8. Sep 16, 2015 at 5:49 PM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
