shock install
Discussion in '1st Gen. Tacomas (1995-2004)' started by lucky13don, Apr 14, 2017.
  1. Apr 14, 2017 at 6:39 PM
    lucky13don
    lucky13don [OP] Well-Known Member
    Don
    Milton, fl
    R.I.P.04 tacoma prerunner, 04 sequoia 4x4
    Too many to list
    so i just my shocks from wheelers, now i need a idea on the install. any tips or tricks? the fronts look like a pita to do,but i think i can get the rears alright. thanks
  2. Apr 14, 2017 at 7:15 PM
    Itchyfeet
    Itchyfeet Well-Known Member
    The fronts are easy, just a good spring compressor and it will take 15 minutes a side.
    lucky13don[OP] likes this.
  3. Apr 15, 2017 at 4:02 AM
    Csmith8911
    Csmith8911 Well-Known Member
    Hill Country, TX
    96 4wd Ext Cab 5spd 3.4
    They're really not that hard. Go rent a spring compressor from the parts store for the fronts. When putting the front assembly back together make sure to line up the bottom mount on the shock and the 3 top bolts the way it will go into the truck. Look at how it is when you take the current assembly out and match that when putting back together. If they don't line up correctly it won't go back in the truck.
    The rears are a piece of cake. Just jack up the back end by the frame until the shocks are fully extended. Take the nuts off that hold the top and bottom mount and slide the shock off. Just stick the new one in its place and tighten the nuts back down.
  4. Apr 15, 2017 at 7:28 AM
    lucky13don
    Don
    Milton, fl
    Too many to list
    Should I get a alignment when the shocks are installed?
  5. Apr 15, 2017 at 8:40 AM
    Csmith8911
    Hill Country, TX
    That's up to you. Shocks shouldn't change anything with your alignment. If you feel the truck needs one, then go for it. But probably not necessary
  6. Apr 15, 2017 at 12:01 PM
    Timmah!
    Timmah! Well-Known Member
    TIM
    Hey Don, My buddy Sean and I have a video you could use as a reference. Like others have already mentioned, just rent the spring compressors at a local auto parts store for free. I call bullshit on 15 minutes per side though. Unless you're working at a 4 wheel drive shop and do this all day, everyday, you're not going to swap out the shocks in 30 minutes. If you have an impact gun, it helps speed up the process of compressing the spring. Pulling the strut/coilover out isn't hard, but if it's your first time using a spring compressor and you're doing it the manual way with a 1/2" ratchet, it can take a while along with giving you some sore arms from the effort.
    Here's the video:
    <iframe width="560" height="315" src="https://www.youtube.com/embed/0HJx6HH2yno?list=PLPMpPriBUyJDltxfqbrYHUmrKeRrLeLXM" frameborder="0" allowfullscreen></iframe>
    Sicyota04 and lucky13don[OP] like this.
  7. Apr 15, 2017 at 12:18 PM
    Timmah!
    TIM
    It is not necessary. If you're using the same spring, you're not changing anything.
  8. Apr 15, 2017 at 1:18 PM
    lucky13don
    Don
    Milton, fl
    Too many to list
    Thanks for the vid..
