Shock Problems. Help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hami252, Mar 28, 2013.
  1. Mar 28, 2013 at 9:20 AM
    hami252
    hami252 [OP] Member
    Okay, So I just had a leveling kit installed on my tacoma. I bought new front shocks but I wanted to hold out on buying rear shocks until i saved up a little more to buy 5100s. I was under the impression( and still believe I am right) that the stock shocks would still fit...I only raised the rear end up an inch. I was told my my mechanic that the stock wont fit and then was rushed to order new shocks...I order some bilstien hds cuz I still haven't saved up for the the 5100s. My question is do these shocks or even the stock shocks actually fit? I think my mechanic might be a dumbass...what do you think?
  2. Mar 28, 2013 at 9:20 AM
    hami252
    hami252 [OP] Member
    Also If I can run the stock shocks should I return the hds? My origonal plan was to buy new tires and then save up for the 5100s. What do ya'll think?
  3. Mar 28, 2013 at 9:21 AM
    BigHeadTaco
    BigHeadTaco GFY
    Big Head
    Full OME lift 885's with Dakar leaf springs. LR UCA's. ImMrYo relocation bracket.
    Stock shocks should work with a leveling kit, instead of buying the leveling kit you could have purchased all 4 5100's
  4. Mar 28, 2013 at 9:54 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    I have 1.5" AAL with the stock bilsteins.
