Shock question???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 10trdtaco, Dec 2, 2016.
  1. Dec 2, 2016 at 7:49 AM
    10trdtaco
    10trdtaco [OP] American Infidel *DON'T TREAD ON ME*
    Shayne
    Lynchburg, VA
    2010 Tacoma TRD Sport DCSB
    4" lift 33-12.50-17 Atturo Trail Blade M/T 17" HELO TRD Satoshi Blackout Grill Tinted headlights with caliraised led headlights ... More to come
    Have ome coilovers up front (885) replacing the ome front shock with some bilstien 5100's ... what lift preload do I need to set the 5100's to mimick my ome shocks?
  2. Dec 2, 2016 at 7:51 AM
    justinalldredge19
    justinalldredge19 Well-Known Member
    Justin
    Arab, Alabama
    Set it to 0 lift or the bottom notch.
  3. Dec 2, 2016 at 7:57 AM
    Pigpen
    Dan
    Northwest Montana
  4. Dec 2, 2016 at 9:25 AM
    phum86
    phum86 Active Member
    Conway AR
    2014 Prerunner SR5
    I'm looking to buy suspension lift for my 2nd Gen 2014 4 door. Im curious to know why your replacing the OME with Bilstein?
  5. Dec 2, 2016 at 11:46 AM
    10trdtaco
    Shayne
    Lynchburg, VA
    I'm more of a bilstien fan myself ... ome is good but like the ride of the 5100 better ... preference
