shock questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bigjake450, Nov 13, 2012.
  1. Nov 13, 2012 at 8:38 PM
    bigjake450
    bigjake450 [OP] Member
    jake
    bay area
    2011 4x4
    ok so im 21 years old i bought a 2011 access cab and put the 3 inch spacer lift in fron 2 in back im pretty much a rookie to all this its my first 4wd any ways just wondering if i can put the blissies 5100s on with the spacer lift and would it benifit me at all. would i be better off loosing the front spacer and putting the 5100s on to make up for the spacer?
  2. Nov 13, 2012 at 8:44 PM
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    DONT DO IT! DO not stack lifts. The 4x4's cant be lifted more than 3" with out a drop bracket lift.
    SEARCH! SEARCH! SEARCH! SEARCH! SEARCH! SEARCH! SEARCH! SEARCH! SEARCH! SEARCH! SEARCH! SEARCH! SEARCH! SEARCH! SEARCH! SEARCH! SEARCH! SEARCH! SEARCH! SEARCH! SEARCH! SEARCH! SEARCH! SEARCH! SEARCH! SEARCH! SEARCH! SEARCH! SEARCH! SEARCH! SEARCH! SEARCH! SEARCH! SEARCH! SEARCH! SEARCH! SEARCH! SEARCH! SEARCH! SEARCH! SEARCH! SEARCH! SEARCH! SEARCH! SEARCH!
  3. Nov 13, 2012 at 8:52 PM
    bigjake450
    jake
    bay area
    2011 4x4
    ok thats why im asking. im thinking im gonna sell the spacer and do it right with the suspension lift
  4. Nov 13, 2012 at 8:59 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Bilstein 5100 adjustables and get rid of your spacers. Better ride. The spacers essentially do the same thing thing as the adjustables tho... you're just getting a tad better shock.
  5. Nov 13, 2012 at 9:00 PM
    brian
    Elizabeth City, NC
    Best thing you could do is get rid of the AAL you likely have in the rear and get a good progressive leaf pack or better tho. The ride will be 10x better
  6. Nov 14, 2012 at 7:45 PM
    bigjake450
    jake
    bay area
    2011 4x4
    right on thanks
  7. Nov 14, 2012 at 7:50 PM
    superswamper003
    superswamper003 Taco
    Hendrik
    N. Snottsdale Arizona
    1998 4wd TRD 3.4l Tacoma Xcab 313k miles!!!
    Fox Xtended travel coilovers w/resis, AllPro UCA's, AllPro 3 inch leaflets, 1" Diff Drop, 285/75/16 Bfg KO, 16x8 Black Pro Comp Steelies, AP 1.25" wheel spacers in front, 8 inch Rockford Fosgate sub that bumps like your mother, old school deck, downey headers, cold air intake, grey wire mod, e-locker, hurst shift knob, LED Strips, USMC Decals FTMFW, Fox decal, Billet grille, Alarm with no remote, Straight piped to the side of the truck
    Hey if you have alot of money to spend, get some high end coilovers. Such as Fox, King, Icon, Sway a way, and donahoe. The ride is amazing both on and offroad. :)
  8. Nov 15, 2012 at 6:58 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    To clarify:
    A spacer lift allows the truck to bottom out the suspension before the truck hits the bump stops. The strut is the weak link and fails.
  9. Nov 15, 2012 at 7:29 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
