303Shocks
Discussion in 'Colorado' started by TMFF, May 12, 2015.
  1. May 12, 2015 at 7:57 AM
    TMFF
    TMFF [OP] Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    COTW,
    303Shocks is an authorized ICON service center!!!
    I'm offering up my services for TW members that have shocks that need rebuilt or just want to change the valving for a ride that matches their driving style.
    I can rebuild any shocks that can take a nitrogen charge. IE: King, Icon, ADS, SAW, Fox, and even FOA's.
    Any questions feel free to PM me
    Thanks,
    Tim
    Davis85WV, GQ7227, romafern and 5 others like this.
  2. May 12, 2015 at 8:09 AM
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
  3. May 12, 2015 at 8:19 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I already recharged my shocks, but meet Tim a few days ago. Will be heading his way when I have to work on them in the future.
  4. May 20, 2015 at 6:05 PM
    ffemt2987
    ffemt2987 Shut up Hippie!
    Austin
    Golden
    Cement 3rd gen that was supposed to stay stock
    Rack, sliders, softopper, tjm bumper, eibach temp suspension
    Saving for later....
  5. May 20, 2015 at 6:14 PM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    Best of luck in the shock rebuilding business...BTW, would you do motorcycle shocks too?
    Howard
  6. May 21, 2015 at 10:10 AM
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    I haven't done many but it's not much different than a off road shock.
  7. May 21, 2015 at 11:21 AM
    hetkind
    Howard
    Johnson City
    Oh good, I will post your contact info on some of my motorcycle forums and you receiving dock might be overflowing with Works, Ohlins, Hagans, Koni and every other off brand ones we are using...
    Howard
  8. May 21, 2015 at 1:09 PM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Oh wow. You and I are going to become best friends. Do you happen to know JD? Anyways I'm building a long travel set up right now and I'm going to need to recharge my triple bypasses after I cycle the rear. I'll keep in touch and your not that far from me either. (Sub)
  9. May 21, 2015 at 2:15 PM
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    JD that works were?
    What bypasses do you have? @SilverGhost
  10. May 21, 2015 at 2:29 PM
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    JD, long travel taco in AZ. He's one of the guys that's been helping me with info on setting up the long travel. Anyways. I'm going to get 16" fox triple bypasses. I don't have them yet. Monies is going into Fab right now. I'll pick them up closer to the end of the yr.
  11. May 21, 2015 at 3:01 PM
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    Gotcha,
    Let me know if you have any questions. I can guide you in the right direction with LT and shock questions.
    I have some Kuster 3.0 bypasses that I might sell, I'm still undecided what I want to do with my truck.
    SilverGhost[QUOTED] likes this.
  12. May 21, 2015 at 3:41 PM
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    X2
  13. May 23, 2015 at 6:57 AM
    303tacoma
    Rebecca
    Noob ? I have Icons how can you tell gave much nitrogen pressure is in the front..can you check & fill through the fitting on top of shock?
    Thanks
  14. May 23, 2015 at 7:09 AM
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    200 psi is the normal charge but can range from 150-300
  15. May 23, 2015 at 7:42 AM
    303tacoma
    Rebecca
    can the pressure be checked and filled with the fitting at the top of the coilover? or does the coilover need to be removed? Just curious mine are pretty new...just wonderng what that fitting is for. thanks :)
  16. May 23, 2015 at 7:53 AM
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    If there is room to get my gauge in I can check the pressure on the truck. Your icons probably take a nitrogen needle to fill or charge them, not a normal Schrader valve.
  17. May 23, 2015 at 8:18 AM
    303tacoma
    Rebecca
    Thanks for your replies Tim. I might have to look you up soon
  18. Jul 3, 2015 at 8:04 AM
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    Got @dtacow's 2nd gen Icons on the rebuild table this am. f20303964c642322f3cf80f18714887b_790739d381ba478e0b4bff9267c3bafc9d1ddff5.jpg
    jubei, Willbeck, Alfred and 1 other person like this.
  19. Jul 8, 2015 at 9:03 PM
    dtacow
    dtacow Well-Known Member
    ^Ha! Just saw this. Thanks!
  20. Jul 9, 2015 at 11:23 AM
    JWaldz
    JWaldz It puts the Joe Dirt in the hole
    Waldo
    Colo Springs
    99 4Runner LTD
    Might have to take advantage of this.. Just sucks you're an hour and half from me. PM'ing you
