Shock Relocation
Discussion in '1st Gen. Tacomas (1995-2004)' started by SafetyDang, Jun 5, 2011.
  1. Jun 5, 2011 at 2:12 AM
    SafetyDang
    SafetyDang [OP] get your facts straight
    Dang
    Anaheim, CA
    DC with 4x4 & MT Conversion
    Swapped to Manual Trans & 4x4
    First I removed my camper shell by sliding it on to my brothers truck.
    Shells off
    Then we took the bed off. 6 Bolts, and disconnect the tail lights. And up and over the gas filler neck.
    My trucks nude!
    Start removing shocks.
    Grinding for "boxing plates" for the cross member
    Chalk the truck and jacked it up to check shock location.
    Got too windy to weld so we moved the truck into the garage. Here's a random picture of it out on the street.
    Started getting windy out..
    In the garage about to weld the "box plates" on the frame. :welder:
    Here is my bottom weld.
    Top Weld
    Found out that the weld blocked my Cross member from going in. :saw: Time to grind some welds down.
    Tried again, didn't fit had to regrind some more!
    Let my brother weld it up.
    Tacked the bottom shock tab
    Then let our friend have a turn.
    1 shocks in and flexing it out to find Bump
    Everything in working order
    Mind the bad welds.. they are not mine.
    All done! Rides great. Just need to add larger bump stops to save the leaf springs.
  2. Jun 5, 2011 at 2:29 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Hey as long as the metal around the weld breaks before the weld itself does, its a good weld bro', you should see mine....:eek::eek::eek:
  3. Jun 5, 2011 at 3:14 AM
    03taco
    03taco Well-Known Member
    someplace
    03 tacoma lifted 6in on 35s
    fabtech 6in lift, 35.12.50.16s,on mt classics
    shoot just causeit dont look like rol of dimes doesnt mean that its not strong enough to hold, when i first started mine looked like ass but the xrays showed that they were gonna hold for a long time
  4. Jun 5, 2011 at 5:24 AM
    RAT PRODUCTS
    RAT PRODUCTS Raw Strength Equipment
    Farmington, MN
    Cummins Coal Rollin SOB
    Smokin with a smarty.
    Does the bed clear that bar alright now?
  5. Jun 5, 2011 at 8:56 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Nice job OP. Looks are just that...looks. Nobody will probably ever see the welds but you. As long as it sticks, who cares.
    I see you already have a nice leaf pack. Did you do the relocation in plans for a SUA or a U bolt flip? It's nice that the shocks are relocated but it doesn't look like you gained much travel from the stock setup.
    Couple things
    1) No need for a lock washer on the shock mounts. The pressure from the rubber bushing will act as a lock and you'll get better contact on the shock mount tabs with the nut.
    2) You should cut your exhast right after the muffle and dump it with the quickness. As it sits right now, you're going to cook your right resi hose and shock.
  6. Jun 5, 2011 at 12:08 PM
    SafetyDang
    Dang
    Anaheim, CA
    Thanks guys. Clears the bed by less then a centimeter. I just figured out how to fix the E-brake cable so now I'll be moving on to the exhaust drop down.
    My buddy came over and welded the bottom tabs.. They look like dimes so if anything the top welds will break first. He showed me what I was doing wrong and with in 5 mins I was also welding dimes. Went back over 2 of the the top tabs.
    I don't mind not having loads of travel. I just wanted to utilize all of my Deavers. I have full drop travel now. And when the leaves are flat I still have a little left on the shock. I need to extend my bumps a little to make sure I don't blow out my shock.
    BTW Spare does fit back there. And shocks are 7100's Short Bodies 10" Stroke.
  7. Jun 5, 2011 at 5:42 PM
    Littlebro 5
    Littlebro 5 Well-Known Member
    Tyler
    Wilsonville or
    01 4x4 3.4L sr5 manual all-pro lift
    6" deck plate mod, sweet bed bar.
    I rilly like your shock mount. What size are your shocks I would like to do a shock mount like yours. Nice pics.
  8. Jun 5, 2011 at 5:47 PM
    rcbs204
    rcbs204 Well-Known Member Vendor
    Whats the point of this mod?
  9. Jun 5, 2011 at 11:17 PM
    SafetyDang
    Dang
    Anaheim, CA
    [FONT=Arial,Helvetica][SIZE=-1]10"[/SIZE][/FONT] [FONT=Arial,Helvetica][SIZE=-1]Reservoir Shock - Short Body (8 Inch)[/SIZE][/FONT][FONT=Arial,Helvetica][SIZE=-1]180/75[/SIZE][/FONT] [FONT=Arial,Helvetica][SIZE=-1]Yes[/SIZE][/FONT] [FONT=Arial,Helvetica][SIZE=-1]$188.00[/SIZE][/FONT] [FONT=Arial,Helvetica][SIZE=-1]$178.60[/SIZE][/FONT] [FONT=Arial,Helvetica][SIZE=-1]Part #:[/SIZE][/FONT]
    [FONT=Arial,Helvetica][SIZE=-1]AK7110SB03[/SIZE][/FONT]
    [FONT=Arial,Helvetica][SIZE=-1]Shaft Diameter:[/SIZE][/FONT]​
    [FONT=Arial,Helvetica][SIZE=-1]14mm[/SIZE][/FONT]​
    [FONT=Arial,Helvetica][SIZE=-1]Extended Length:[/SIZE][/FONT]​
    24.29"​
    [/SIZE][/FONT]
    [FONT=Arial,Helvetica][SIZE=-1]Collapsed
    [FONT=Arial,Helvetica][SIZE=-1]14.06"[/SIZE][/FONT] [FONT=Arial,Helvetica][SIZE=-1]Finish:[/SIZE][/FONT]
    U bolt flip
    More Clearance
    Longer Shocks
    More Travel
  10. Jun 6, 2011 at 12:03 AM
    Anthony250
    Anthony250 Fabricator
    Anthony
    San Gabriel Ca
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    Nicely Done!
  11. Jun 6, 2011 at 12:42 AM
    ilove_taco_ma
    ilove_taco_ma Well-Known Member
    fresno, california
    95 tacoma 4wd LX
    nothing, all stock expect got a OE replacement air filter K&N.
    well done man
  12. Jun 6, 2011 at 9:45 AM
    SafetyDang
    Dang
    Anaheim, CA
    Thanks guys! :D
  13. Jun 6, 2011 at 9:49 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Looks good man I'm glad to see more guys doing this on this site.
  14. Jun 6, 2011 at 9:51 AM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    Gahhhh can't see the pics
  15. Jun 6, 2011 at 1:58 PM
    SafetyDang
    Dang
    Anaheim, CA
    I'm usually on TTORA, figured you guys could use a "write up" of some kind.
    56ker! =P
  16. Jun 6, 2011 at 2:00 PM
    JLee
    Jerry
    Bay Area NorCal
  17. Jun 6, 2011 at 4:26 PM
    atvlifestyle
    atvlifestyle Well-Known Member
    Michigan
    01 trd tacoma
    supercharged with lots of midtravel bling.
    looks good. I am in the process of doing the same thing just need the time to finish it.
  18. Jun 7, 2011 at 3:39 PM
    SafetyDang
    Dang
    Anaheim, CA
    Just remember mine was for my Deavers Over Axle. Shock position depends on shock length and leaf springs. Measure Measure Measure!
