Shock replacement for 2009
Discussion in '2nd Gen. Tacomas (2005-2015)' started by QChawks, Aug 26, 2019.
  1. Aug 26, 2019 at 9:31 AM
    QChawks
    QChawks [OP] Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    one of my rear shock is leaking (Bilstein 48530-AD051) and I called the local dealership and they told me they replace with 48530-09B60 made by Maxorber. I've never heard of that brand.
    After doing some searching online it shows 48530-A9680 as a possible Bilstein replacement.
    anyone have any idea if that would work on a 2009 Sport DC?
    I'm looking for a decent shock, but I don't so any off-roading so there is no need for high performance wither. Thanks!
  2. Aug 26, 2019 at 9:48 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The A9680 should fit.
    If you never do much Off-Road stuff or hual heavier loads then it really doesn't matter.
    I do however, recommend you replace BOTH shocks at the same time. It's not really a hard jab to do. A floor jack and basic hand tools. If you can operate a ratchet and wrench, you can do the job easily.
    81shark and QChawks[OP] like this.
  3. Aug 26, 2019 at 10:44 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Bilstein 5100's all the way around.
  4. Aug 26, 2019 at 12:24 PM
    QChawks
    Davenport, IA
    2009 TRD Sport DCLB
    thanks, I was planning to change out both myself and have been soaking the bolts with PB Blaster for awhile. The winters around here are brutal on metal :(
    TnShooter[QUOTED] likes this.
  5. Aug 26, 2019 at 7:02 PM
    81shark
    81shark Well-Known Member
    I used a dremel to cut off the top nut. Fun stuff
    TACOMA2NDGEN and Thuguon2.7 like this.
  6. Aug 27, 2019 at 7:53 PM
    Tacomafella
    Tacomafella Member
    Nik
    Lake Elsinore California
    2013 Tacoma TRD sport
    Bilstein 5100's Method grid 309 Bfgoodrich k02 CBI aluminum skid plate Aero turbine muffler
    Bilstein 5100’s have been treating me well
