Shock replacement questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pibbles99, Mar 28, 2018.
  1. Mar 28, 2018 at 8:36 AM
    Pibbles99
    Pibbles99 [OP] One more cast
    Brian
    Southern NH
    21 OR dbl cab
    My second generation TRD with 73,000 on it seems to be running a little lumpy lately. I have been considering new shocks in the rear possibly the front if it's practical to do all four corners. It was suggested that unless they are leaking do not change them why waste your money? But if she's running lousy ,ride wise ,should I just change them anyway? Any thoughts? These are the original parts on my truck
  2. Mar 28, 2018 at 8:41 AM
    DukesTaco
    DukesTaco Well-Known Member
    AZ
    2nd Gen Double cab Pre Runner
    5100's all around.
    Armed in Utah likes this.
  3. Mar 28, 2018 at 8:43 AM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    You can look in the 3rd gen marketplace for trd bilstein shocks that someone took off and is selling. May save you some $$
  4. Mar 28, 2018 at 8:44 AM
    Ccrames2018
    Ccrames2018 Jack of some trades.
    Caden
    Nor Cal
    06 DCLB TRD Sport
    -Bilstein+OME suspension, ARB bumper w/Smittybuilt XRC winch, Aero exhaust, CMC, oddball size 275/70R17 General Grabber ATXs on 17x8 0 offset Pro Comp wheels, etc.
    Exactly what I would say. If you can do it yourself the total cost should only be between $300-400. Also if you want to you can level the truck. They give a better ride with less body roll too.
  5. Mar 28, 2018 at 8:44 AM
    BWilley
    BWilley Well-Known Member
    Brian
    Seattle
    2005 Tacoma DCLB Prerunner Desert Sand
    Skid plate, TRD Exhaust
    Yes replace all four. No need to wait till they're broken/leaking. You can go stock again or upgrade which is a loooong story but lots of info here. I replaced my tired shocks with low mileage take offs from a 2017 3rd gen OR. Ride is great and lifted the front an inch.
    taco2010trd likes this.
  6. Mar 28, 2018 at 9:10 AM
    TheRicksta
    TheRicksta Well-Known Member
    Ricksta
    San Diego
    2013 White Tacoma 4x4
    King 2.5 EXT with compression adj/Built Right UCA/Deaver Progressive 3 leaf pack/285 KO2s
    yeah just do all 4. 5100s is an affordable solution and huge upgrade from stock
  7. Mar 28, 2018 at 10:43 AM
    Pibbles99
    Brian
    Southern NH
    21 OR dbl cab
    The 5100s have different heights settings ,I'm aware of that. Do they come out of the package on the lowest height setting? And will I just be able to put them right in with out any adjustments needed? I just might put them in as they are on the stock height . Any recommendations on which height would be best suited to my needs.? I am mostly city driving but every now and then I go fishing out in the woods
  8. Mar 28, 2018 at 10:54 AM
    Ccrames2018
    Caden
    Nor Cal
    06 DCLB TRD Sport
    Yes they should come on the stock height setting but I would check and make sure when you get them. If you aren't going to get any bigger of a tire then you will be fine at the stock setting, which will also be the softest ride. And yeah you can just swap them out but make sure to get an alignment afterwards. You always need one whenever you change anything with the suspension.
  9. Mar 28, 2018 at 11:06 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    If your shocks are original from 2008 then change em
  10. Mar 28, 2018 at 11:56 AM
    JSB10
    JSB10 Well-Known Member
    2005 Tacoma
    I recently had my rear shocks replaced at the dealership when they changed my frame because they messed up mine. They broke the covers on the rear shocks and they put on new OEM shocks. Does anyone know how much front OEM shocks cost and how long it takes to change the front? I will take my truck to my mechanic who charges 70 an hour. Just wondering how long it takes to change the front. My truck is 05 regular cab 4wd.
  11. Mar 28, 2018 at 12:56 PM
    Pibbles99
    Brian
    Southern NH
    21 OR dbl cab
    Huge savings there versus about$115 -$120 per hour at dealerships. Dealership wanted to charge me $127 per stock strut. At AutoZone I got Bilstein 5100s for $114 each and $80 for rear . Also 5200 bilstein
    JSB10 likes this.
  12. Mar 28, 2018 at 12:57 PM
    Pibbles99
    Brian
    Southern NH
    21 OR dbl cab
  13. Mar 28, 2018 at 1:04 PM
    JSB10
    2005 Tacoma
    I wanted to put the 5100's on mine front and back but I had the rears replaced for free with OEM Toyota shocks. Could I still put the 5100 on the front?I thought about putting them on the .85 setting in the front. Would it matter that they are different brands?
  14. Apr 2, 2018 at 6:39 AM
    Pibbles99
    Brian
    Southern NH
    21 OR dbl cab
    So I replaced my rear shocks with the Bilstein 5100's
    But I neglected to put the little metal spacer back on that goes under bottom washer and bushing before I feed through the upper mount. Is this aserious problem? I noticed a guy on a video put it back on for some reason .I'm not sure if I did anything wrong.
  15. Apr 2, 2018 at 6:41 AM
    Pibbles99
    Brian
    Southern NH
    21 OR dbl cab
    I only did roughly 2 mile road test and it seems outstanding. I've got 40 miles to put on it today Up and back to work I'm hoping everything will be OK. Very concerned about long-term problems
  16. Apr 2, 2018 at 6:50 AM
    Pibbles99
    Brian
    Southern NH
    21 OR dbl cab
  17. Apr 2, 2018 at 6:51 AM
    Pibbles99
    Brian
    Southern NH
    21 OR dbl cab
    Any help Will be very much appreciated as usual. Everyone in this form been super helpful to me thank you
  18. Apr 2, 2018 at 6:58 AM
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    save money & buy all four 5100's at once......
    Headstrong Off Road.......best pricing @ $340 shipped all four
  19. Apr 2, 2018 at 7:04 AM
    Pibbles99
    Brian
    Southern NH
    21 OR dbl cab
    Yes I am doing all four corners with the 5100s. The front should be delivered in two or three more days from now.
  20. Apr 2, 2018 at 7:06 AM
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    If you missed the metal spacer now is a good time to put it back on before the threads get rusty, it won't take you long to fix, whatever was there before you should put back on in correct order.
