shock replacement
Discussion in 'Suspension' started by JohnnyBlazin44, Dec 7, 2011.
  1. Dec 7, 2011 at 5:57 PM
    JohnnyBlazin44
    JohnnyBlazin44 [OP] Well-Known Member
    Sault Ont. Canada
    06 access cab TRD
    satoshi grill by myself....but many future plans
    Should I or could i replace factory shocks with the billies I orderd and set them at 1.75 by myself and put them on truck with out a hard time or is it not worth it. Should I just get a shop to do it?
  2. Dec 9, 2011 at 9:13 AM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    If you have a second vehicle or a friend to drive you, take the front coils and old struts off yourself, then take them to a shop with a coil spring compressor. They will probably charge only $10-20 for them to compress and install your new struts into the front coils. You need to have both left and right sides lifted in order to replace the coils back on your truck.
    Unless you have a means to SAFELY compress the coils yourself, you should not try it at home. There are several write ups for removing and installing shocks/struts here.
  3. Dec 9, 2011 at 9:20 AM
    jeremy_283
    jeremy_283 Super Member
    08 TRD Offroad Access Cab 4x4 Auto 4.0L
    Hella Rallye 4000 Cornering Lights PIAA 510 Fog Lights All Pro Front Bumper All Pro Rear Bumper All Pro Transfer Case Skid All Pro IFS Skid All Pro Rock Sliders All Pro High Clearance Hitch OME Dakar Leaf Springs OME Rear Shocks OME Front Shocks OME 885 Front Coils Wet Okole Seat Covers WeatherTech Floor Liners Sony Head Unit JL XD600/1 Amp 2 JL Audio 10” Subwoofers Custom Subwoofer Enclosure Kenwood Front Speakers Sony Rear Speakers Sound Deadening Mats LED Interior Lighting Pop N’ Lock Tailgate Lock Viper Alarm System Extra D-Rings In Truck Bed Maglite Seat Mount Disable Seatbelt Chime Rear Differential Breather Relocation Hi-Lift Bed Mount Flexible Front Mud Flaps 110v Inverter Always At 400w ABS Kill Switch Locking Center Console Removed Sway Bar
    Free rental at autozone for the tool. Possibly other auto shops as well.
  4. Dec 9, 2011 at 7:57 PM
    JohnnyBlazin44
    Sault Ont. Canada
    06 access cab TRD
    thanks guys I will probly take them out myself then to a shop to be put together. So after that I just have to have the front end on jacks to put them back in. Oh and to have at 1in and 3/4 what setting on the shock is that?
  5. Dec 9, 2011 at 8:05 PM
    crawldad
    crawldad Well-Known Member
    2016 TRD OR 4X4 Quicksand
  6. Dec 10, 2011 at 2:51 PM
    JohnnyBlazin44
    Sault Ont. Canada
    06 access cab TRD
    Hey thanks i will probly do that then:D
