Shock Replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by North Idaho DonC, Jan 20, 2025.
  1. Jan 20, 2025 at 11:56 AM
    North Idaho DonC
    North Idaho DonC [OP] New Member
    Don
    2010 4x4 crew cab TRD Tacoma
    TRD, leveling kit, 18Inch wheels and tires, Magnaflow exhaust, Heated Leather seats,
    Greetings from the far North Idaho, new member here, North Idaho Donc.
    I searched some of the forums and didn't see the answer to my question.
    I have a 2010 Tacoma 4x4 crew cab TRD with what appears to be a 2" Leveling Kit installed by Toyota of Renton,Wa. i need to replace the shocks, it currently has Bilistein 4600 shocks that were part of the TRD Package. I need to replace them but can't get a straight answer on whether the OEM style shocks will work of do i need to go with something designed for the leveling kit. I have spoken with three dealerships and can't get a straight answer. Help
  2. Jan 20, 2025 at 12:00 PM
    Clearwater Bill
    Billy
    Largo Florida
    How is it 'leveled'? Spacers up front and blocks in the rear?
    Any reason you don't want new 4600s?
    tcBob likes this.
  3. Jan 20, 2025 at 12:08 PM
    North Idaho DonC
    Don
    Looks like both.
  4. Jan 20, 2025 at 2:24 PM
    Garymvvvvvv
    Garymvvvvvv It's easier to get forgiveness, than permission.
    Gary
    La Grange Texas
    2022 Tacoma SR5
    TRD pro grill, Raptor Grill Lights, 2 color fog lights, rock flood lights, light bar with powder coated front bumper, X-Bull winch, K&N cold air intake, RIPP ignition coils, oil catch can, E3 iridium spark plugs, 275/70 R17 BFG KO3 tires, OPT7 tail gate light bar, black out mirror caps and rear bumper caps, sprint booster, LED interior-exterior light bulbs. Flashing 3rd brake light, infinity tail lights and Alpha Rex Nova black headlights, Seat covers, Mr. hood scoop with 18 inch amber light bar inside. 2 inch lift front/rear. 1.5 inch wheel spacers. Fender flares,
    I recently added a set of old man emu 2"lift coil springs with Bilstein 5100 height adjustable shocks to the front. Adjusted the passenger side shock to zero lift and the drivers side at the .55 inch lift due to the weight on that side. it worked, as both front sides ended up with a 2" lift. I went with Eibach 1.5" lift blocks in the rear with bilstein 5100's as well. I chose the lift blocks instead of an "add a leaf" because I do not have any additional mods on the bed and rarely haul anything. Even with the lift, the taco rides like it was OEM
    tcBob likes this.
  5. Jan 20, 2025 at 2:33 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    4600 were not part of the TRD Package.
    The “real” 4600’s are a lager diameter shock. And arguably “better”.
    OE shocks look like 4600, but they are not.
    I’d go 5100’s and toss the spacers.
    Or 4600 if you are fine with the spacers?
    Primo 95 likes this.
  6. Jan 20, 2025 at 2:39 PM
    Primo 95
    Primo 95 Well-Known Member
    Primo!
    San Antonio, TX
    2012 DCSB 4X4
    265/75/16 S/T Maxx 16X8.5 Level 8 Trackers 5100 1.75 HID, LED interior, 3" N-Fab step bars
    A pic of your front suspension would help us answer. Right now I am going to assume as others have, you have a 2"spacer lift in the front.
    4600 are the direct stock/OEM replacement shocks from bilstein and are typically used for trucks with no lift. (like my Dads.)
    https://offroad.bilstein.com/en-us/products/bilstein-b6-4600/
    I also did confirm with Bilstein, that 4600s are identical in performance as 5100, there are just a few slight differences.
    https://www.tacomaworld.com/threads...-your-normal-one-either.800441/#post-28689116
    Having 2" of lift on stock shocks may be working but probably not the best idea. I believe they are under constant compression & will bottom out quicker and thus lead to failure
    If you want to do it right, get the Bilsteins 5100 adjust them to 1.75" and remove the blocks in front. This will set you right without spending a ton of money. And you will need to get an alignment when you are done. 5100s are very close in price to 4600s and you are going to have to take the coils off either way. So there should be no difference in labor going either route.
    Don't go the dealership for answers, they are only there to make money, not help you.....go to your local 4x4 shop.
    Email customer/tech support and they will answer your question. But be sure to confirm you have a 2" spacer lift on front, and I am also questioning weather you actually have 4600s or the OEM/stock shocks that are yellow & Blue, but skinnier than actual 4600s (there is a difference as some stated above)
    https://academy.bilsteinus.com/knowledge
    Good Luck
  7. Jan 20, 2025 at 4:39 PM
    ROGUE OFFROAD
    ROGUE OFFROAD Well-Known Member Vendor
    Shawn
