Shock Shaft Guards
Discussion in 'Suspension' started by OffroadToy, Oct 9, 2021.
  1. Oct 9, 2021 at 8:30 AM
    OffroadToy
    OffroadToy [OP] pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Anyone know if the Fox shaft guards come in a size that will work on a 2.5" Icon RXT shock? I like the boots (live in a dry climate so moister is not a concern) but Icon says their boots won't fit this shock (lower mount is different.) Looking for an alternative.
  2. Oct 9, 2021 at 12:19 PM
    Tacomod
    Tacomod Well-Known Member
    OffroadToy[OP] likes this.
  3. Oct 14, 2021 at 8:10 AM
    eurowner
    eurowner Duke Sky
    Scoty
