Shock / Spring question
Discussion in '1st Gen. Tacomas (1995-2004)' started by jrallan26, Apr 30, 2008.
  1. Apr 30, 2008 at 3:27 PM
    jrallan26
    jrallan26 [OP] Well-Known Member
    Iowa
    2004 White D-Cab TRD
    The leaf springs on my truck have a negative bow. The bow is is going up instead of down. This is from a camper shell being on the truck forever plus the Tacoma springs are pretty lame. While I am at it, I am going to replace the rear shocks.
    Question #1 Where is the best place to order a set of stock height leaf springs?
    Question #2 My truck is a TRD version, Are the stock shocks Tokico?
    One more thing my truck has the dredded lean also. Will this cure my lean?
  2. Apr 30, 2008 at 11:16 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    1. try these: or you can have them custom made by Deaver or Alcan. If you're going to have a shell or some sort of camper on the rear, I would suggest getting the Timbren suspension kit as well: 2. depending on the year, yes, your truck probably came stock with those Tokicos
    3. no, it is inherent with Tacos. The lean is caused by the gas tank, battery and driver all being on the same side.
