Shock/Spring Studs Spinning
Discussion in '1st Gen. Tacomas (1995-2004)' started by ltdpilot, Aug 17, 2023.
  1. Aug 17, 2023 at 10:54 AM
    ltdpilot
    ltdpilot [OP] Well-Known Member
    04 Tacoma TRD SR5
    I have 3 of the 6 studs for my shock/springs (stock) spinning freely. I assume I'm not the first to have this happen. What's the best way to get the nut off? (I'm installing OMEs) Any tricks?
  2. Aug 17, 2023 at 11:19 AM
    ChargedSHOTaco
    ChargedSHOTaco Well-Known Member
    Cut it off with a cut off wheel.
  3. Aug 17, 2023 at 11:22 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Put side load on the stud with a screw driver and hit it with an impact with a right angle adaptor :notsure:
  4. Aug 17, 2023 at 11:39 AM
    ltdpilot
    04 Tacoma TRD SR5
    Thanks, I appreciate the ideas
    I have a carbide tipped oscillating tool that may get in there easily, gonna try that
  5. Aug 17, 2023 at 11:58 AM
    H20man
    H20man USCG Polar Star WAGB-10
    The Rainy State
    2001 Tacoma Ext Cab 4x4 2.7L 5spd
    Bone Stock
    Removed my reply as it was not on topic for this thread
  6. Aug 17, 2023 at 1:52 PM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    It should be mentioned not to undo the nut in the picture above if you are trying to remove the coilover assembly. That nut is holding the top cap on top of the coil spring, undoing it will release the energy in the coil spring. There is a sketchy method where people use a jack and the lower control arm to change springs, but it should be avoided if possible. It's much safer to remove the coilover assembly and take it to a shop who have proper coil spring compressors.
  7. Aug 17, 2023 at 2:57 PM
    H20man
    The Rainy State
    Bone Stock
    Thank you for pointing that out! I had only done my rear shocks using my above methods.
  8. Aug 17, 2023 at 4:02 PM
    02hilux
    Planet: EARTH
    Huh? Your rear? Your 01 rear shock look like that?
  9. Aug 17, 2023 at 4:38 PM
    H20man
    The Rainy State
    Bone Stock
    Good catch, no. Trying to reply while at work, removed my comment.
  10. Aug 17, 2023 at 7:36 PM
    ltdpilot
    04 Tacoma TRD SR5
    Only removing the 3 nuts that hold the assembly, not touching the one on the right.
  11. Aug 17, 2023 at 8:27 PM
    rocknbil
    rocknbil Well-Known Member
    Bill
    2003 Taco Ext Cab DLX TRD 4WD MT 3.4L
    Aside from cutting them off, you could try these. It looks like you might fit them in on at least that one stud. If not, they're good for removing sway bar end links without mucking up the boots. +- $17 at Lowes.
    Andy01DblCabTacoma likes this.
