Shock travel length
Discussion in 'Suspension' started by Rogerdoger1993, Apr 27, 2014.
  1. Apr 27, 2014 at 11:02 AM
    Rogerdoger1993
    Rogerdoger1993 [OP] New Member
    Illinois
    2004 Tacoma 4x4 Base
    This is my first post. Could could anybody tell me where I can find the shock travel length of OME Nitrocharger vs Bilstein 5100 shocks. The reason I am asking is because I a trying achieve the most shock travel between the two.
  2. Apr 27, 2014 at 9:34 PM
    shr133
    shr133 Well-Known Member
    Muskego, WI
    2010 V6 Sport
    K & N filter, 275 70 17 Cooper AT3, OME Nitrocharger shocks, 884 Springs, Dakar leafs.
    The OEM are 1 inch longer than stock and have 9 inches of travel.......
  3. Apr 28, 2014 at 4:36 AM
    Rogerdoger1993
    Illinois
    Thank you. All I am trying to achieve is a little lift and articulation.
  4. Apr 28, 2014 at 2:48 PM
    steezinstangl
    steezinstangl Well-Known Member
    Elk Grove, Ca
    2008 FJ Cruiser
    I heard that 5100's are the same length as extended travel coilovers ? Maybe that's wrong idk, but I also read that 5100's are longer than OME shocks.
  5. Apr 28, 2014 at 2:59 PM
    RCOTaco
    RCOTaco Long Time Lurker
    Dalton
    Hamlet, NC
    Super White DCSB 4x4
    Bilstein 5100s on Stock Coils, Light Racing UCA's, Pro Comp Wheels, 265/75 Baja MTZ's, Cobra 18 WXST, 4' Firestik, UWS Toolbox
  6. May 1, 2014 at 2:51 PM
    shr133
    Muskego, WI
    2010 V6 Sport
    With the leafs in and 3" of lift, I'm 1 1/2 from the top of the travel with the OME shock I think the 2" longer shocks are the way to go with lift....
  7. May 2, 2014 at 9:43 PM
    Rogerdoger1993
    Illinois
    That is what I am wondering too. I am thinking about getting the All Pro leaf pack. And when I do, should I try compressing both sides of the suspension in the rear to see what length shocks I need based on the compressed length?
  8. May 15, 2014 at 11:18 AM
    shr133
    Muskego, WI
    2010 V6 Sport
    It looks like most shocks have 9" of travel so I'm shimming my shocks so they are 2" compressed with a empty truck full tank of gas. So far on logging trails I'm ok but the dunes will be the real test... You also have to factor in loaded height with a load the back could sag another inch...
  9. May 15, 2014 at 11:30 AM
    shr133
    Muskego, WI
    2010 V6 Sport
    So I just measured my front and I have 2" of sag in the front with OME struts and 884 springs. so I have 2" of sag front and rear. Old man EMU and ARB do lots of testing so this is how I'm going run the dunes in july.... So we'll see...
