shock travel with bilsteins
Discussion in 'Suspension' started by markc6606, Dec 24, 2011.
  1. Dec 24, 2011 at 9:20 AM
    markc6606
    markc6606 [OP] Well-Known Member
    SoFlo
    '13 Off-Road
    Doe anyone have any idea how much down travel would be lost with bilsteins adjusted to 1.75? Would it be a true 1.75 or closer to the width af the spring clips on the shock itself which I guess would be closer to an inch.
    Does the spring compression add any more to either of these numbers?
    Thanks
  2. Dec 24, 2011 at 3:37 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    It would be a true 1.75 of down travel at the wheel. It is less actual travel on the shock itsself.
    Think of a see-saw, if you move the fulcrum up 1", it actually moves the high end of the see-saw up more than an inch. That's the nature of an IFS.
