Shock travel with ucas
Discussion in 'Suspension' started by Rinzler, Jan 18, 2020.
  1. Jan 18, 2020 at 12:59 PM
    Rinzler
    Rinzler [OP] Member
    Mississippi
    2006 DCLB SR5 4x4 v6 AT
    285/70r17 Nitto Ridge Grapplers, 17x9 SCS Ray 10's, JBA UCA's, HD leaf pack, Sundown X12 with 2000 watt amp, Archive Garage Hammer Hangers, Bilstein 5100s in the rear, Ultimate headlight mod, LED map/dome lights, Plate rear bumper with reverse LED pods, Weathertech floor mats, Double din HU
    I have been looking all over tacomaworld but I can't seem to find how much travel I can get with jba ucas and some king 2.5s. The options that I've seen talked about are 6", 8", and 10". What length should I get with the jbas? Thanks for the help
  2. Jan 18, 2020 at 6:41 PM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
  3. Jan 23, 2020 at 9:03 AM
    AccuTune Offroad
    AccuTune Offroad Well-Known Member Vendor
    El Cajon, CA
    A standard extended length coilover is what you will want. Anything longer than that, you will need to look into a Long Travel Kit. Extended length Fox coilovers have about 4.890" of travel. Since there is a motion ratio on the control arm, you are getting about 9" of tire travel.
  4. Jan 25, 2020 at 8:49 PM
    Yota_Ivan
    Yota_Ivan Geaux Tigers!
    Arlington, TX
    2006 Tacoma DCLB 4x4 TRD Sport
    A little bit of this, a little bit of that...
    Is this recommendation standard with any 05+ Tacoma with JBA UCAs for the weekend warrior or will you need a more in-depth analysis to recommend a suspension?
  5. Jan 27, 2020 at 7:59 AM
    AccuTune Offroad
    El Cajon, CA
    Aftermarket upper control arms allow more droop, and better alignment. You will need those if you are lifting the truck more than 2", or plan on really using the truck off-road often. After that, you are still limited by other components including shock length options. Mid travel kits are pretty straight forward.
    JCWages likes this.
