Shock Valveing
Discussion in 'Suspension' started by chris4x4, Jan 16, 2009.
  1. Jan 16, 2009 at 6:55 PM
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
  2. Jan 16, 2009 at 8:24 PM
    Packman73
    Packman73 ^^^^ 3%er ^^^^
    The free state of Arizona
    2007 TRD Off Road
    Bilstein 5100's (front set @ .85"), OME 885's, chris4x4 anti-Taco-lean spacer on driver's side, Total Chaos UCAs, Rear Leaf Spring TSB, Toytec AALs, Black FJ TT Wheels, BFG 285/75R 16 AT Tires, TRD Exhaust, Viper Alarm, Fog Light Mod, De-badged, Blue LED Dome Light, EZ Clamped Tailgate, Wet Okoles, Satoshi Grill, 5% Tint, Engine Tick Fix, Black Rear Bumper, Black Center Valence, Exhaust Cut At Axle, Thanks for all the help chris4x4!
    Nice find! :cool:
  3. Jan 16, 2009 at 8:29 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
  4. Jan 19, 2009 at 7:12 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    I like it! Good find Taconator/chris4x4!!
  5. Jan 21, 2009 at 12:14 AM
    m_yota
    m_yota Well-Known Member
    Paradise
    08 4x4 dbl cab
    K&N airfilter, HID conversion for headlights/fogs. Wet Okole Seat covers, Kove Aphex processor Kenwood comp 6.5" and 6.5"coaxial 5100 billy shocks 2.5", 1.5" fabtech AAL,Epicenter and MTX Sub, debadged, tinted, kenwood dnx812, black mesh grill, led ext/int.
    this is a great fyi site.:cool:
  6. Jan 21, 2009 at 12:17 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    chris...out of curiosity...typically a springs rate is stamped on it correct?
    i forget the other numbers stamped...but i noticed when boxing my SAWs up they had a 675 on them...i was under the impression they were 650lb spring rate springs...
    any clue...or anyone else with some insight?
  7. Jan 21, 2009 at 6:55 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If that number was stamped on the spring, it would be its rate. If it was on the body of the shock, then Im not sure. I havent seen the dampening rates stammped on shocks in the past, but I never really looked for them.
  8. Jan 21, 2009 at 8:52 AM
    JimBeam
    JB
    2015 Tundra
    it was on the spring itself...i was just confused as i thought SAWs were 650lb rates...but mine DEFINATELY said 675
  9. Jan 21, 2009 at 9:36 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    They come in different rateings. From 600# all the way to 700# and in some cases even more.
  10. Jan 24, 2009 at 7:34 PM
    Downsouth Motorsports
    Downsouth Motorsports Downsouth Motorsport Vendor
    Lakeside, Ca. 92040
    2017 4-Runner Dirt King Long Travel King 2.5 Coil-Over / 2.5 Bypass Front and Rear ICON Rear Upper and Lower Arms ICON Rear 2" Springs 34" x 10.50" x 17 Toyo Tires on 17" x 9" RaceLine Wheels
    Keep in mind that this is just Bilstiens table, both King and Fox use different ratings to illustrate compression and rebound valving.
  11. Jan 24, 2009 at 7:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Right. But it gives people a good idea. With the rates listed, they can decide what might fit their style of driveing/off roading
  12. Jan 24, 2009 at 8:38 PM
    Lakeside, Ca. 92040
    Absolutely, I apologize if that came across the wrong way.... I wish they all would just find a common table and make it a universal system. It makes something that is already confusing, twice as confusing from one make to the other...
  13. Jan 24, 2009 at 8:41 PM
    brianr
    brianr go shit in your hat
    2010 4x4
    BUILT, not bought...
    wow, a crash course on shocks.
    great stuff!
  14. Jan 24, 2009 at 8:42 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I dont think its that confuseing. Most of the dampening rates are in Nuetons. And many of the popular shocks are valved the sme as the Bilstiens, in what I have found, anyway. But, regardless, Its a good starting point, and then if some one wants a different set up, hopefully, you guys can accomodate. ;)
  15. Jan 24, 2009 at 9:35 PM
    Lakeside, Ca. 92040
    Most of the performance rebuildable shocks are typically rated upon what shim stacks they are using for compression and rebound. Allot of the stacks are made specific to the application for slow and high speed dampening. A shocks characteristics are a result of the amount of fluid that it lets pass through its piston. On the top and bottom of the piston there are shims- ranging in size and thickness. The easier the shock oil passes by the piston the faster the shaft speed resulting in a "soft" shock. The shims are made to flex to allow the fluid to pass, the shims are arranged in a descending pattern so the lower in the stack you go the harder it is to flex. Trail and error is what it really comes down to along with experience- knowing what shim configurations do what to the characteristics of the shock. The piston itself also plays a big role in the performance of the shock as well, there are different pistons with
    different styles of bleed holes.
    For this reason alone is why it is so important to know your getting when purchasing a aftermarket performance shock. Not all vehicles need the same valve stacks, so there is not a "universal" valve stack that will work for all vehicles. All performance racing shocks are built to order, meaning that they do not build the shock until the valving is specified. Many Off Road retail stores like to have a large inventory of these shocks because they are popular, but many of them order "popular" valving configurations. So Joe Blow comes in off the street and wants 4 reservoir shocks for the front of his F-250. John C. Counter guy himself is unfamiliar with valving and goes to his inventory and gets the right size and travel and away Joe Blow goes....... He installs the shocks on the front of his F-250 and thinks that he got the right shocks for his specific truck, meanwhile he received a
    "popular" valving that was more suited for single shock application on the front of a torsion beam VW.
    It's there job to ask the questions necessary to give you the customer a
    "quality sale". Never settle for whats in stock! Demand the proper valving for your vehicle, the best way to do this is have them special ordered. The same goes for bolt on coil over kits- Not all Tacoma's are the same, some are single cab, extra cab, double cab- have a winch, winch with bumper, prerunner bar with lights........ the list is endless. The point is that all of these differences add weight to the vehicle, therefore changing the way the shock preforms. Allot of people do not realize what a difference a properly valved shock can do to a trucks ride. Take for example the Off Road Trophy Trucks- they can do over a 100mph over the nastiest terrain out there! They all have different weights and suspensions that have been properly tuned or preped allowing them maximize there performance...
    If you have a aftermarket performance shock or coil over get the full potential out of your suspension! Find out what valving or shim stack you have and find out if it is in fact what you need...!
  16. Jun 17, 2009 at 11:09 AM
    Seagrave
    Seagrave Well-Known Member
    2009 DC LB 4x4 Sport
    I have heard that some coilovers have different types of valving. Apparently some have "linear" or "digressive" valving. It sounds like digressive is the better of the two. Do all aftermarket CO's have digressive valving?
  17. Jun 17, 2009 at 11:14 AM
    KMN-BLU
    KMN-BLU less work/more play
    Destin, Fl
    2018 Tacoma TRD PRO
    I know on my Camburg setup I went with a firm valving setup like the Tundras due to the fact that I will be running a Heavier winch bumper.
  18. Jun 17, 2009 at 7:09 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No. As far as I know, Icon is a digressive valving. I prefer a linear valveing, but alot of it depends on the off roading you do.
  19. Apr 7, 2010 at 8:38 AM
    TacomaTSP4
    TacomaTSP4 Go Big or Go Home!!
    Travis
    Rohnert Park, CA
    Im going to be having 6" lift in the front and 5" in the rear and want to which 5150's i should purchase. Anyone know?
  20. Apr 7, 2010 at 5:29 PM
    Lakeside, Ca. 92040
    5150's will only come in a few different valving options off of the shelf...
    The 5150's in the rear would most likely be a 255/70 valving and they also have a
    stem conversion kit the 5150 as well for the 05-10 Tacoma upper factory shock mount...
