Shock Valveing
Discussion in 'Suspension' started by chris4x4, Jan 16, 2009.
  1. Apr 7, 2010 at 7:34 PM
    TacomaTSP4
    TacomaTSP4 Go Big or Go Home!!
    Travis
    Rohnert Park, CA
    how do i know what body and length to get?
  2. Apr 7, 2010 at 8:49 PM
    Downsouth Motorsports
    Downsouth Motorsports Downsouth Motorsport Vendor
    Lakeside, Ca. 92040
    2017 4-Runner Dirt King Long Travel King 2.5 Coil-Over / 2.5 Bypass Front and Rear ICON Rear Upper and Lower Arms ICON Rear 2" Springs 34" x 10.50" x 17 Toyo Tires on 17" x 9" RaceLine Wheels
    TacomaTSP4:
    Safest thing would be to get us a ride height measurement from mount to mount with the truck sitting there under its normal weight and then get us the measurement from the bumpstop to the bumsptop contact point and then let us know what the suspension set is and what type of driving you will be doing?
  3. Apr 8, 2010 at 7:18 PM
    TacomaTSP4
    Travis
    Rohnert Park, CA
    I was just hoping that someone would have a 6" lifted front and 5" lifted rear and could let me know the right shock body and height that i need to buy cause i want to have the shocks before i start my lift install. I already know im gunna go the standard 255/70 valving
  4. Apr 9, 2010 at 3:42 PM
    Lakeside, Ca. 92040
    TacomaTSP4: It would most likely need to be an 11" Travel 5150 with there stem conversion on it...But the valving in a 5150 in 11' is 170/60
    12" would most likely work, but it will be long on compression..
  5. Apr 9, 2010 at 6:19 PM
    TacomaTSP4
    Travis
    Rohnert Park, CA
    isnt 170/60 valving for if you arent going to have weight in the bed of the truck, like racing? What does it me to have long compression with the shocks? Any problems with it?
  6. May 12, 2010 at 10:31 PM
    wolfeye
    wolfeye Well-Known Member
    Wow great post. :popcorn:
  7. May 13, 2010 at 7:23 AM
    Lakeside, Ca. 92040
    TacomaTSP4:
    170/60 is a very light valving..Bilstein #'s are reverse of everyone else's.
    60 is compression (Very Light) and 170 is rebound (All Most more of a medium)
    255/70 is more of a general purpose valving I guess you would call it.
    Sorry what I meant by long on the compression is that the shock may bottom out before the suspension bumps out.
    Your bumpstops should make contact and compress before the shock would bottom out so that you do not ruin the shocks.
    If you are driving hard off road, yes that could be bad, you may break a shock or at the very least a shock mount.
    Hope this helps.
    Sonny
  8. Jul 17, 2010 at 6:37 PM
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    08 PreRunner SR5 Long-Travel
    King 10" coilovers w/ resi. 3.5" over long travel kit. Factory spindles w/ ALLPRO gussets. Total Chaos tower gussets. Energy Poly cab mounts and steering rack mounts. Glassworks fenders and bedsides. Home fabbed bed cage. King 2.5x16 bypass shocks in the rear. DMZ long travel rear end. Race radio (2meter). Removed secondary carbon air filter. Exhaust dumped before the axle / no muffler. Phram fresh air cabin filter. K&N replacement filter, After market stereo, Grillcraft grill, custom fabled roof rack with 7" HID's, PRP race seats.
    For those people who have already purchased their coilovers such as Icon for example, and want more out of your shocks in the way of dampening, you can take them in or send them in for modification.
    In my case I have Icon coilovers and I wanted some more dampening for my trips out to Ocotillo Wells. I called Icon and the tech guy said bring them in and for a small charge we can make some changes to the valving. I took them in and got them back the same day. Brought them home and re-installed my shocks with amazing results. Ofcourse there's no free lunch, as my street ride suffered a little, but the offroading was awesome. I'm sure DownSouth would be happy to do the same thing for those running King and Fox.
    Just thought I would share this information ;)
  9. Jul 18, 2010 at 7:18 PM
    Lakeside, Ca. 92040
    Good afternoon,
    I hope everyone is enjoying there Sunday, and you are correct we have always offered a "1" time free re-valve on Fox and King and we are also offer the same for ICON and Radflo when they are purchased from us as well.We also offer the same "1" Year warranty against leaking under normal use of the ICON coil-over shock and if something happens to the shock under normal driving conditions and it begins to leak, we will re-build the shock for no charge, all you pay is the shipping to and from us.
    What I mean by normal driving conditions is if we find a You Tube video of you jumping the canal and the shocks blew out and you say to us "Hey they just started leaking"...That would be "No" they are not covered..
    Enjoy the rest of your Sunday and any questions, just shot us a PM..
    "Via con dios"
    Sonny & Marco
  10. Dec 18, 2010 at 1:30 PM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    You know if I hadn't rebuilt motorcycle and bike shocks (and also want to know my truck the best I can) I would drop my shocks off with Sonny when I found a dead shock yesterday.
    I have some 2" adjustable resis that I purchased from a shop in Southern California that has a Rock Crawling champion as an owner. I called and asked about valving on a Taco vs a DC. The GM didn't know.
    That was then then this is now. I will be tearing down my shocks tomorrow or Sunday and was wondering how can I find out what valving would be best for my application. I do a good combination of running fast in the desert (not as fast or comfortable at least as you LT guys) as well as some pretty good technical rock crawling.
    When I am using as a grocery runner I typically have my full size spare, 10# CO2 tank, shovel and a hi-lift. When I am out exploring and camping, I probably have another 200-300 pounds (Roof Top Tent, camping supplies etc.).
    In the front I have Fox 2.5" resi (not rebuilding those today). In the rear I am running Dakars.
    After I find out what's in there, I need to find out the volume of oil and what valving I should start with.
    Any help would be GREATLY APPRECIATED.
  11. Dec 18, 2010 at 1:46 PM
    Lakeside, Ca. 92040
    What brand shocks are you working on that you need to know the valving?
  12. Dec 18, 2010 at 3:30 PM
    HBMurphy
    Paul
    So California Coast
    None
    Fox 2.0 resi adjustable... they look like this but they are the newer black ones. Thanks!
  13. Dec 18, 2010 at 4:35 PM
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    Can those be re-valved with different shims? When my buddy re-built his 2.0 smooth bodies I believe he valved them pretty darn stiff. I'll find out what shims he used. Maybe a stack of 15s or 20s. All depends on angle though. He had a cage and the shocks are vertical. Factor mounts are slightly angled.
  14. Dec 18, 2010 at 5:41 PM
    Lakeside, Ca. 92040
    I think you had said the shocks were for a leaf sprung application "Dakars"?
    Yes the 2.0" Resi can be re-valved the same as most Fox shocks...
    The compression adjuster is works by metering the fluid traveling between the reservoir and the shock..
    Still same valve stack and same standard 2 bleed hole piston in there...
    Most of the time for a soft ride they have been running a Fox #20 which is all .006" shims on compression and either a #60 on rebound which is a 10's on initial and .012" on the high speed side or #70 which is all .012" on rebound...
    I myself like the #60 on rebound and the #20 on compression and then use the CD Adjuster to dial it in from there and run 200 psi...
    Hope this helps...
    Let me know if you have any questions....
    Happy Holidays from DSM...
    Sonny
  15. Dec 18, 2010 at 7:08 PM
    #35
    HBMurphy
    Paul
    So California Coast
    None
    Sonny I greatly appreciate your insight! You certainly live up to your reputation as being the 'go to guy' on shocks! I will let you know how it works out for me. Although my knowledge is less useful for driving trucks, if there is anything I can do for you please let me know.
  16. Dec 18, 2010 at 9:58 PM
    #36
    Lakeside, Ca. 92040
    Let me know if you need me to send you the valve stacks..
  17. Dec 18, 2010 at 10:12 PM
    #37
    HBMurphy
    Paul
    So California Coast
    None
    That would be greatly appriciated!! Also, what volume of oil?
    Thanks again! :)
  18. Dec 18, 2010 at 10:33 PM
    #38
    Lakeside, Ca. 92040
    Call me on Monday at the shop: 1-888-973-6967 ext. 2
    and I will walk you through the dividing piston depth and you can
    let me know where to ship the Valve stacks...
    No worries...
  19. Dec 20, 2010 at 2:48 PM
    #39
    HBMurphy
    Paul
    So California Coast
    None
    One more satisfied... wait a second! I was going to say satisfied customer but I'm not his customer yet... but I will be anytime I need what he sells.
    Sonny took care of me!
    Thanks Sonny!
  20. Dec 21, 2010 at 2:14 PM
    #40
    HBMurphy
    Paul
    So California Coast
    None
    Got the shim stack!
    Thanks!
    Hope to rebuild them tonight or Thursday! :)
