Shock Valveing
Discussion in 'Suspension' started by chris4x4, Jan 16, 2009.
  1. Dec 23, 2010 at 1:36 AM
    #41
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    Sonny! Thank you for my brand new truck!!! Boy a world of difference!!! - Then again, I had two blown shocks so the improvement was even more impressive! :)
    Thanks again - It drives great. Just did 75 mile drive with the new set up! Very nice!
  2. Mar 2, 2012 at 2:02 AM
    #42
    Manwithoutaplan
    ID
    Can some one explain to me what to get on the length of a shock because i want upgrade my shock from pro comp to some thing better. I have the pro comp 6 inch lift. I called pro comp they said that their COil over is 26 inch in length with 6 inch of travel. The mx6 mono tube has 27.3 inch length and has 10 inch of travel.
  3. Mar 2, 2012 at 8:03 AM
    #43
    Downsouth Motorsports
    Downsouth Motorsports Downsouth Motorsport Vendor
    Lakeside, Ca. 92040
    2017 4-Runner Dirt King Long Travel King 2.5 Coil-Over / 2.5 Bypass Front and Rear ICON Rear Upper and Lower Arms ICON Rear 2" Springs 34" x 10.50" x 17 Toyo Tires on 17" x 9" RaceLine Wheels
    Good morning,
    King already has the spec for the front shocks for a lifted application and if you are running the strut spacer, The King shock will be set up to remove that spacer and just have the King coil-over bolt into the stock locations.
    They Offer one for the rear as well for a lifted application and the I believe ICON does as well for the front I am sure, we would have to check on the rear.Also I believe RADFLO has specs for the front and rear shocks for a lifted application as well to bolt directly into the stock locations.
    Length of shock travel is second to making sure the compressed and extended lengths are correct for this type of suspension lift.
    The R & D has already been done..
    Hopes this helps..
    Thank you,
    DSM
  4. Mar 2, 2012 at 9:09 AM
    #44
    Manwithoutaplan
    ID
    Thank you so much :)
  5. Jan 29, 2014 at 10:00 PM
    #45
    Spencer
    Spencer Future President
    TIGGLEBITTIES
    Upland, Chino... all of 909.
    2013 DCSB 4X4 6cyl Sex Machine
    Redline hood lift, Flyzeye cabin lights, tailgate lock, SPOD Power block, VIAR onboard air, Cobra CB radio, Firestick 4' Antenna, Hot Blonde CoPilot Mod, SIX 9" Hella 4000 HID conversion with external 55W ballasts, Six 6" LED bars, Napier Bed Tent, Mudflaps delete using rocks, Roof rack by Brute force, Rock sliders by Brute force, Bed LED lights, Underhood LED automatic lights, Constant 12V bed plug, Rugged race radio, ICON uniball UCA's, KING 2.5 700 rate coilovers, Deaver rear leaf springs, KING 2.5 resi rear shocks (Flat 0.15 stack on compression shims), Scangauge, Empty wallet Mod Bug disease, AllPro Apex front bumper, On board heat exchange shower & water pump (Heater Core intercept mod), On Board Air - Viair for now, ARB when it dies-, allpro Skids back to gas tank- Tepui RTT on the shittiest "Bed Rack" ever made.... AllPro U Bolt flip kit with timbren bumps NEXT UP- expo leafs & bed rack, hydraulic bumps in rear, Total Chaos stock LCA's w/ Bypass, Rear 12" shock hoop relocate
    Hey can anyone tell me what the KING OEM replacement shock valving numbers are? They feel wayyyy too soft- I have the 2.5 with reservoir extended travel coilovers up front and OEM 2.5 resi in rear. I'm trying to find out what they came "stock" so I can decide what shims to move to- I want it way stiffer than it is now to handle larger stuff. I bottom out like crazy in the rear and go bucking all over when I go fast :(
  6. Jan 30, 2014 at 7:47 AM
    #46
    HBMurphy
    Paul
    So California Coast
    None
    There is only one person that I would ask... Sonny from Down South Motorsports.
  7. Mar 25, 2014 at 12:06 PM
    #47
    ComaRyder1
    ComaRyder1 Well-Known Member
    Dakota
    Las Vegas
    2000 tacoma 4x4 5speed caged FOX shocks
    2.5" bypass remote resevoir FOX shocks(front), caged(almost done) stage 3 clutch, cold air intake, flowmaster dump, 33x12.5 BFG A/T tires, 15x10" american racing rims, touchscreen dvd player with gps, 2 12" subs with 1000 watt amp n capacitor
    FOX makes an application for the front of your tacoma for 2.5" bypass remote resevoir shocks that bolt right up to your stock suspension. the pre load is set to give you 2" of lift, but the important part is the performance gains you get from this product. cost is $1500 if you shop it right.
    i just installed mine yesterday on my 2000 tacoma 4x4 TRD. my truck rides like a cadillac on the street now, and the highspeed offroad ability my truck now has is unimaginable. i used to be slow and cautious when getting onto the trail, now i just pull off into the dirt and floor it. i feel like im driving a sandrail almost.
    these shocks were very easy to install, it took me about an hour and a half with with clean up and putting my tools away.
    these shocks are literally the best, most effective, bang for my buck investment ive made for my truck yet.
    ________________________________
    my rig: 2000 tacoma v6,4x4,TRD, 5speed manual, 2.5"fox coilovers, caged front to back(still under construction), 33x12.5 BFG A/T tires, 15x10" american racing rims
    TheMailman521 likes this.
  8. Mar 25, 2014 at 12:46 PM
    #48
    Lakeside, Ca. 92040
    Just so that you are aware, that is not a bypass shock. It is a remote reservoir coil over shock.
    Great part, I am sure you will be very happy with them.
  9. Mar 29, 2014 at 9:14 PM
    #49
    HBMurphy
    Paul
    So California Coast
    None
    And if Sonny drives the shock valving of these puppy's you'll be elated. :)
  10. Apr 30, 2014 at 2:37 PM
    #50
    HOJeepster
    HOJeepster Active Member
  11. Apr 30, 2014 at 8:38 PM
    #51
    Spencer
    TIGGLEBITTIES
  12. Sep 26, 2016 at 6:30 AM
    #52
    WendyTaco
    WendyTaco Well-Known Member
    Kyler
    2017 TRD Off-Road
    0210 likes this.
  13. Nov 3, 2016 at 3:11 PM
    #53
    WhiteRhino
    WhiteRhino Well-Known Member
    Virginia Beach
    1999 Toyota Tacoma 2.7L 4x4 Auto
    Pioneer Head Unit 2 12" kicker subs in ported Box, Black 15x10 rims 33" General Grabber At2's billsteins 5100 up front and 5125s in the back, eibach coils, dakar leaf packs Trail gear low pro bumper with weld on light bar Custom swing out tire carrier rear bumper re geared to 5.29s Spartan ratcheting locker in the front Elocker axle swap In-dash switch panel (paranoid fab)
    hmmm interesting
