Shock valving
Discussion in 'Suspension' started by Brice, May 1, 2018.
  1. May 1, 2018 at 9:10 AM
    Brice
    Brice [OP] Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    My 05 Prerunner V6 is gonna need new shocks soon. I'm pretty sure the ones currently on it are OEM. I was looking into valving and from what I gathered the 5100's have digressive valving? Which I guess means they don't handle smaller bumps as well and linear or progressive valving? My question is basically what shocks have progressive or linear valving? I have 4600's on my 99 but they are pretty stiff (fine for that truck) but the 05 is my daily and I would like to retain comfort.
  2. May 1, 2018 at 9:13 AM
    Jibbs
    Jibbs "When in doubt, throttle out!"
    Josh
    Cincinnati
    2017 SCREW Raptor Lightning Blue
    Whoooooooshchchch
    This is covered in a variety of places but basically:
    Digressive: stiff at low speeds, so superior for handling and softer high speed rapid compression (bombing through the desert) All Icon's and All Bilsteins (that I'm aware of) are Digressive.
    Progressive: stiff at high speeds (so arguably better for actually *racing* where you don't want to wallow everywhere), softer low speed rapid compression (crawling, 'commuting' speed potholes, offroading). Fox, Kings, OME are all Progressive.
  3. May 1, 2018 at 9:18 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Uhhh.......no.
    To start, please keep in mind that any perceived ride quality is subjective. Hence why I keep mentioning "tunable" (in addition to serviceable). What is comfortable and complacent for driver1 can be very different than the requirements for driver2. Second, I'll refer to "counter damping" below, which essentially means the force provided by the shock to counter the forces inflicted by the terrain. Mathematically speaking, this is modeled as a force F= -cv. Where F is force, c is the damping coefficient, and v is velocity. Cliff notes, the damping force is velocity (shaft velocity) dependent that acts against the direction of the shaft movement.
    A digressive shock means the counter force produced by the damping of a shock decreases as the speed of the shaft increases. Specific to ICON, they use a two piece dished piston that preloads the valve shims (compared to a flat piston with shims that are not preloaded and lay flat directly against the piston). From the perspective of the passengers in the vehicle, the vehicle will feel stiff over slow shaft speeds because the velocity of the shaft is not fast enough to overcome the preload of the valve shims. With typical street and track vehicles, this is predominately preferred because it doesn't feel like the vehicle rolls as fast in corners (again keep the whole "subjective" topic I started with). Now change terrain to offroad where you hit washboard, whoops, or uneven terrain in general, the shaft speed (not vehicle speed) increases to compensate for terrain. The shock overcomes the valving preload and perceived ride quality improves. However...as you overcome the valving preload, you also loose counter damping force at higher shaft speeds. Meaning if you have a big hit (large whoop, rock, consecutive uneven whoops, etc.) because you already overcame the valving preload, there's nothing left to slow down the shaft speed and inherently you bottom out the shock because you just blew through all the valving.
    Progressive (sometimes referred to as linear) on the other hand, the relationship between counter force and shaft speed is progressively linear. Slow shaft speeds don't have the same perceived ride quality where you can feel every pebble and cigarette butt you drive over. It gives that "Cadillac" ride quality as there is no preload on the valve shims and the oil bends past the valving predictably and consistently. Now again, change terrain to the higher shaft speeds, the valving characteristics don't change. The shims bend at the same rate as there's no preload to overcome. The shock will progressively increase counter force as the shaft speed increases. Hit some bigger terrain and the counter force increases instead of decreases.
    TL;DR
    Digressive: hitting stuff slower= more force, hitting stuff faster= less force
    Progressive: hitting stuff slower=less force, hitting stuff faster=more force
    All that said, as many know, I'm a bit of snob. I have very high expectations of my shocks and don't like making compromises. I start with a base valving and tune to my preferences, my rig, and my driving style. Anyone can buy a shock off the shelf and run it. Most people makes concessions because they paid money for something, so they will defend their purchase. I'm a bit different. If I don't like something, I have no problem stating it was a shit purchase and move on to something else, or tune it until I'm satisfied. I could not tune my ICONs to my subjective preferences and be even close to satisfied. I like predictability, a soft ride around town, and balls to the walls damping in the dirt.
  4. May 1, 2018 at 9:22 AM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
  5. May 1, 2018 at 9:33 AM
    Brice
    Brice
    Texas
    Thank you this makes sense. I'm looking for progressive valving I suppose then on my daily. OMEs are looking like the option I would like better on the DD. I'm thinking more expensive coil overs would be best but I'm not sure they're gonna be in the budget.
  6. May 1, 2018 at 9:34 AM
    Jibbs
    Josh
    Cincinnati
    Whoooooooshchchch
    I'm unclear on where we are disagreeing. What you said, as well as the Summary of the article linked above, seem to both align with what I said :notsure:
  7. May 1, 2018 at 9:42 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    I edited the "even close" bit almost right after I posted it.
    I completely disagree with what the "superior handling" on slow speed digressive though.
  8. May 1, 2018 at 9:49 AM
    Jibbs
    Josh
    Cincinnati
    Whoooooooshchchch
    I guess I should have clarified that when I was talking about handling, I was referring specifically to on-road cornering, where a digressive shock won't feel like it 'dives' as much. That's my mistake for being vague. I was basically trying to convey the same thing you said above.
    I imagine a progressive shock would be better at enthusiastic cornering offroad, but I don't really have any experience with 'racing' offroad. I've been limited to cars and motorcycles on tracks.
    jberry813[QUOTED] likes this.
  9. May 1, 2018 at 9:55 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Gotcha.
    I'm a big fan of digressive for on-road vehicles that have limited travel. I always ran digressive in my track cars, but you are talking like 3" of suspension travel. Some find it helpful with our trucks on-road as well particularly with no sway bar (for the reason you pointed out). But when it comes to dirt, I like my shocks being soft over wash but be able to take a bigger hits when the terrain gets rougher, not the other way around.
    Brice[OP] likes this.
  10. May 1, 2018 at 11:49 AM
    Brice
    Brice
    Texas
    If im not buying full on coilovers what kind of progressive shocks would you recommend?
  11. May 1, 2018 at 5:31 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Well our trucks come with coilovers stock. It’s a verbiage faux pas. But I’m assuming you mean tunable and height adjustable coilovers.
    I’m no help here. I only buy rebuildable and revalvable shocks. King and ADS are my personal preference.
    Brice[QUOTED][OP] and bullaculla like this.
  12. May 1, 2018 at 6:00 PM
    Brice
    Brice
    Texas
    That's what I meant, shoulda been more specific. Thanks.
