Shocks....again
Discussion in '3rd Gen. Tacomas (2016-2023)' started by slevy951, Apr 8, 2025.
  1. Apr 8, 2025 at 8:00 AM
    slevy951
    slevy951 [OP] Member
    2023 Toyota Tacoma SR5
    2023 SR5 4wd here.
    I'm thinking about shocks. But, my main concern is on road ride, not off-road. I find the truck a bit floppy. I'd like to tighten it up. My choices are Bilstein 4600 or 5100.
    Thoughts?
    TIA,
    Scott
    Tocamo likes this.
  2. Apr 8, 2025 at 8:02 AM
    Toyotas4Tots
    Toyotas4Tots Well-Known Member
    NC
    2023 Tacoma SR5
    5100’s will firm it up on road. It would be a great choice for what you’ve described you're looking for.
    SandyTaco4x4, 71tattooguy and Burns like this.
  3. Apr 8, 2025 at 10:25 AM
    andy044
    andy044 Well-Known Member
    NH
    Black 16 TRD Sport AC 6sp
    If you don’t plan on lifting. True 4600 would be my suggestion unless you dislike the blue/ yellow scheme.
    jmneill and Steves104x4 like this.
  4. Apr 8, 2025 at 11:44 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    Find someone with TRD Sport take-offs. They will be a bit stiffer. The 5100's on stock springs and stock ride height will be softer as they are meant for a little more offroading.
  5. Apr 8, 2025 at 11:45 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    Both will be an upgrade from the stock SR5 Hitachi's, but the 4600's ride tremendously softer than 5100's on the road. 4600 would be my choice. I don't care for the 5100's much, I find them overly stiff for no reason.
    jmneill likes this.
  6. Apr 8, 2025 at 11:51 AM
    JHK
    JHK Active Member
    2023 Toyota Tacoma OR DCLB
    Stock
    According to Bilstein, The 4600 and 5100's are pretty much the same shock. 4600's are for stock applications and 5100's are for lifted applications.
    Tocamo and Steves104x4 like this.
  7. Apr 8, 2025 at 12:16 PM
    slevy951
    I've driven the Sports and they were better. What would be the next step up in stiffness from those shocks?
  8. Apr 8, 2025 at 12:20 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    Sport's are the stiffest OEM shocks for these trucks. If you like those you will probably like the 5100's. Most of us find them to be harsh and many owners swap them for a softer option.
  9. Apr 8, 2025 at 12:21 PM
    MGMDesertTaco
  10. Apr 8, 2025 at 12:25 PM
    Cheesetoast
    Cheesetoast Active Member
    Dale
    SoCal
    2023 TRD off-road 4x4 DCSB
    OTT Tune
    If I was looking to save a few bucks and keep the truck as it is, I’d shop for some OR takeoffs.
    If I was looking to buy new, I’d spend a little more and get the 5100s.
  11. Apr 8, 2025 at 12:55 PM
    airforceb2cc
    Don
    KCMO
    OR take offs are the softest made...even softer than the OP's SR5's. The Sport is the stiffest.
  12. Apr 8, 2025 at 12:56 PM
    airforceb2cc
    Don
    KCMO
    Usually people find them harsh because they are using them to lift as well and the pre-load is causing the rough ride. The valving in the 5100's are just as soft as the OR shocks from my experience.
  13. Apr 8, 2025 at 1:09 PM
    Johnsmyname
    Johnsmyname Active Member
    How do the 6112 compare to the 5100's for on road stiffness?
  14. Apr 8, 2025 at 1:27 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    Big disagree.
    YF_Ryan, jmneill and na8rboy like this.
  15. Apr 8, 2025 at 1:48 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    double big disagree. or shocks are like pogo sticks compared to 5100s. significantly different
    YF_Ryan and drizzoh[QUOTED] like this.
  16. Apr 8, 2025 at 1:52 PM
    MGMDesertTaco
    5100's are noticeably stiffer than stock OR bilstein's, but I definitely wouldn't consider them harsh or overly stiff for on road. There's not a lot of other shock options in that price bracket either. I'd still recommend the 5100's for a daily driver and mild off road use.
  17. Apr 8, 2025 at 2:05 PM
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    I just got TRD Suspension Upgrade which are the Bilsteins 5100s...My Sport is now Lifted:
    2" in the front, 1" in the back.
    These 5100s are definitely WAY better than the Hitachi ones removed.
    My truck is daily driver and mostly road miles for now.
    I can compare the ride to 2024 Tacoma Limited because it was the Loaner while my Sport was getting worked on.
    The suspension felt almost identical...the ride height is just about the same...the Limited has 18" wheels.
    Much better grip on the road are the Bilstein 5100s and a firmer ride but not too harsh.
  18. Apr 8, 2025 at 2:31 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    If if was me, I would lift the front 1" with Bilstein 5100s, just to eliminate the oem brake dive, which I considered floppy! You don't even need to raise the rear.
    Good luck Scott.
  19. Apr 8, 2025 at 2:31 PM
    Danner488
    Danner488 Well-Known Member
    2016 TRD Sport
    I have the 5100 with 2885 coils front and 5125 rear with RXT @ 2 and think they firmer compared to the Sport stock suspension. I prefer the 5100 and they were the best bag for the buck considering my application. Less brake dive and cornering body roll.
    My understanding is that the 4600 and 5100 are the same with the exception of the height adjustment. Same shock diameter and valving.
    I wonder how many of the people that dislike the 5100 reused the stock springs? Or perhaps it is the digressive valving.
    This is what Bilstein says about the two....
    B6 4600 Versus B8 5100
    GaMGMTaco likes this.
  20. Apr 9, 2025 at 6:10 AM
    slevy951
    Thanks for the link. Since I don't want to lift, sounds like the 4600 is the one.
