Shocks and duration/degradation.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FlyTaco, Nov 4, 2017.
  1. Nov 4, 2017 at 3:42 PM
    FlyTaco
    FlyTaco [OP] Member
    2011 white doublecab sr5: 135,000+ mi.
    at 130k miles, I'm seriously wondering how long a set of shocks should last for us with majority highway driving. This ride was a former engineering company truck doing at least 20k a year. I have full records and it appears it has all orig. shocks. None of the typical signs of shocks going bad exist but I suppose they could just be getting stiff in old age? What I don't know, is what a fresh set should feel like on a truck that rides like a truck...
    I suppose It is getting to that time to start watching bushings too. If I do shocks, might as well do a full bushing and shock overhaul.
  2. Nov 5, 2017 at 4:41 AM
    httuner
    httuner Well-Known Member
    2015 Tacoma TRD-OffroadPckg
    AFe Rebel Catback Exhaust, AFe GT Momentum Air Intake, Method Wheels, Bilstein 5100, Rigid 30" SR2 Light Bar, Rigid 10" SR Light Bar. Lots of Love
    Shocks are either good or bad; I have never seen them harden up or get worned to the point where they feel different. They either work or don't work. I replace them when I see them leaking really bad or either the truck starts to bounce around on bumps.
    The bushings however do wear out over time. My old man's got 265k miles on his OEM shocks in his tundra and they still look and perform great, all hwy driving.
  3. Nov 5, 2017 at 5:19 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    I’ve always wondered how you can tell if shocks become bad. Our trucks bounce on road bumps even when brand new.
  4. Nov 5, 2017 at 5:36 AM
    badger
    badger Well-Known Member
    07 SR5
    The factory shocks aren't great to begin with. Easiest way to test a shock is to bounce the truck by pushing down on the fender or standing on the bumper if you have one. Get it bouncing and then stop. The truck should come back up and stop. If the truck keeps bouncing after you stop, even a little, the shocks are getting weak. Repeated bouncing after a speed bump is another sign. Leaking fluid is a physical marker, but leaking gas is not detectable. Most shocks don't last past 50k, but for all street driving they could last 100K. The shock's only purpose is to control the oscillations created by the spring.
  5. Nov 5, 2017 at 5:50 AM
    Clearwater Bill
    Billy
    Largo Florida
    I can promise you a case of Diet Coke that your dampers are well past prime.
    They have to be off the vehicle to 'hand test', or optimally tested on a specialty testing device (which most of us don't have ready access to).
    Call Marie @HeadStrong Off-Road and get her recommendation on a replacement set. You'll be surprised at the refreshed ride you have.
    HeadStrong Off-Road likes this.
  6. Nov 5, 2017 at 5:56 AM
    badger
    07 SR5
    Frankly, if I bought a brand new truck, the first thing I would do is drive it home, put it on stands and rip out the entire suspension system. The difference in ride and handling with quality suspension is transformative. As far as I'm concerned, it's broken right out of the box.
    PackCon likes this.
  7. Nov 5, 2017 at 6:12 AM
    oldtoyotaguy
    oldtoyotaguy Well-Known Member
    Peter
    Ontario, Canada
    2018 4 Runner ORP
    Stock but with a Warn 10s winch Used to be a lightly modded Tacoma
    Yeah, I hear you, badger, that’s pretty much what I did. I think I put about 2500 km on the truck while I ordered the parts and got set up to mod it . It’s sure nice to drive when there’s a good suspension on it.
  8. Nov 5, 2017 at 7:26 AM
    TexasWhiteIce
    Texas
    Luckily the shocks are very easy to replace in our trucks. Some people have said you don’t even need to jack up the truck to replace them.
  9. Nov 5, 2017 at 7:30 AM
    FlyTaco
    FlyTaco [OP] Member
    Well in this case of the replys, it appears my shocks are good but not great anyway and the bushings will get checked here today.
    Since a nice ride is a nice ride ill plan a fix. The deal is its the commute vehicle and family go camping truck. The mileage is 90% highway with 10% gravel roads and trips to see the occasional ghost mining town on a low grade state trail or two but really nothing id need an 8" lift and 33s for...im rolling stock size wheels n tires. 17" summer 16" winter.
    Besides 51xx 'steins and bushings, what else to do while under there fits that bill?
  10. Nov 5, 2017 at 7:56 AM
    eon_blue
    Azusa, CA
    If you're on the factory coils still, I'd replace those too. If you're not looking to lift it, another set of stock coils with the Bilsteins set at 0 will work fine. Not sure if OME or Eibach make springs that don't provide lift but they might.
  11. Nov 5, 2017 at 8:06 AM
    Boyk1182
    Boyk1182 Well-Known Member
    Northern Colorado
    When they’re bad the truck doesn’t stop bouncing. My Jeep got this way, bouncing slightly still 5 seconds after a speed bump.
    httuner likes this.
  12. Nov 6, 2017 at 5:51 PM
    HeadStrong Off-Road
    HeadStrong Off-Road Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
    Thank you so much @Clearwater Bill :fistbump:
  13. Nov 8, 2017 at 10:16 PM
    navynuke
    navynuke Well-Known Member
    Lake Wylie, SC
    2014 TRD Off Road DC
    I just hit 90k on my truck and think I may have finished mine off out in Wyoming on all the washboarded dirt roads on a hunting trip.
  14. Nov 9, 2017 at 10:59 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    :crazy:
    To replace the struts (not shock) you have to remove the coilover, compress the coil, and remove the strut.
    Would love to see someone attempt to do this without jacking up the truck. Heck I’d just like to see someone replace them without taking off the wheel. That would be impressive.
    b_r_o likes this.
  15. Nov 9, 2017 at 11:54 AM
    Boyk1182
    Northern Colorado
    Hold my beer..
    PackCon[QUOTED] and b_r_o like this.
  16. Nov 9, 2017 at 12:17 PM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Highway driving may not drive the shock all the way through its travel, but I would bet it is just as hard or even more on a shock than off-road use (and I mean slow off-road use, not driving fast on washboard gravel roads). Bumps are smaller, but coming on faster, driving the shock up and down at a much higher frequency.
    On pretty much all my Toyotas, the stock (non-Bilstein) shocks worked fine up to about 50k miles. The Bilsteins may last a bit longer, but I still replaced the yellow stock ones with 5100's at 50k. And the ones on the 4Runner. A very noticeable difference on the 4Runner, less so on the Tacoma but still better. Even if it is not fully blown, there are multiple circuits and oil inside (and sometimes a gas charge) that stop working optimally over time. Longest I would expect decent performance on any shock would be 100k miles. But I am picky -- I hate cheap/worn shocks and tires and tend to replace earlier rather than later.
  17. Nov 9, 2017 at 12:38 PM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    at 180k miles my original shocks are doing ok for me
    once they leak or bounce too much, its time to replace
  18. Nov 9, 2017 at 1:15 PM
    5.0 Hatch
    5.0 Hatch Well-Known Member
    My truck has all highway miles and i changed all 4 at 100k miles. The front were fine but the back were shot.
  19. Nov 9, 2017 at 2:25 PM
    80schild
    80schild Well-Known Member
    Chad
    Flori-Bama
    2007 TRD Sport Access Cab
    101k on mine and original shocks and struts seem fine, no bounce at all.
  20. Nov 10, 2017 at 8:46 AM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    To each his own, but I don't think bouncing is a true test of whether they are working like they should. Obviously it is an indication of complete failure, but not a real test. Regardless of the way the truck is used, I have a hard time believing a shock will still be performing optimally past 100K miles. I think the Bilsteins may last longer than the standard shocks, but it's a cheap way to restore performance even if you go with Bilsteins.
    FWIW, I've tried the cheap ones like Gabriel and Monroe, and they are terrible. Spending just a little more on KYB or Bilstein is the way to go.
