Shocks (and springs?) for highway use, topper + weight occasional towing.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AJColorado, Aug 29, 2025 at 4:40 PM.
  1. Aug 29, 2025 at 4:40 PM
    AJColorado
    AJColorado [OP] Member
    AJ
    1999 Tacoma 3.4 4x4 SR5
    I have a 2007 Tacoma double cab 4x4 TRD, v6 auto. I put on Bilstein 4600 front and rear 30k miles ago. The rear is feeling a bit squishy now with less control.
    This is a work vehicle and I always have the topper + about 100-150lbs of tools in the bed. Occasional towing with a small utility trailer, usually balanced and light load, but on the rare occasion over-loaded. I land up on dirt roads a lot and do some light off-roading with a very very rare trip up to a cabin on more serious of- road.
    I don't want a lift, highway performance and dirt road is priority. I was thinking of going to Bilstein 5100's in the rear and see how that goes.
    Any thoughts or recommendations?
  2. Aug 29, 2025 at 5:28 PM
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    I had similar requirements, added a topper and I often pull a 4x8 trailer and allot of camping gear. The back springs definitely weren't up to the weight of the topper, not to mention the gear in the back and a trailer connected and the OE front springs weren't much better after 18yrs. I took the budget approach, I swapped in some ome 884s on the front and general spring HD leaf pack on the rear. It gave the truck about 1.5" of lift which I like because it's on the mild side heightwise. I did require an EGS bushing with the lift. It handles better everywhere then then with the OE springs. All said and done performs well doing what you described.
  3. Aug 29, 2025 at 6:29 PM
    AJColorado
    AJ
    Nice, looks like the same truck! I'm pretty set against any lift, unless it settles back over time... But what shocks are you using?
  4. Aug 29, 2025 at 8:07 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    I doubt it’s your shocks. The 4600’s are really great shocks. They are replacement shocks for OEM but are way better, far superior to OEM’s. They should last 70000 to 100000+ miles. I think the problem may be your rear leaf springs. Get some upgraded heavier duty springs. Also fyi 4600’s and 5100’s are the same shock almost exactly internally. The difference is that 5100’s are for lifted trucks. Keep the 4600’s , get heavier duty leafs.
    I have 4600’s on my truck. Have a camper shell, tow a boat and off road into some remote country. The shocks are awesome. I also had new leafs installed about 5 years. The overall suspension is solid.
    spitdog likes this.
  5. Aug 30, 2025 at 5:12 AM
    ridefreak
    NM
    2006 DCSB TRD
    minor tweaks
    5100s, my problem was never the shocks and when I replaced them prior to the other work they didn't improve the ride much and did nothing for the extra weight. I doubt you're going to get much additional load carrying capacity without the truck lifting some unless you go with something like airbags or sumo springs. One could go with stiff rear springs that didn't lift the truck but the ride would be as bad or worse then it is now.
  6. Aug 30, 2025 at 8:05 AM
    Sprig
    Ken
    Again what you describe is your springs not shocks. You don’t have to replace them with heavy duty springs that make your truck ride like a buckboard. You can simply add a leaf or just get new oem leafs. You have lots of options with springs that will fix your problem and not make for a rough stiff ride. Leaf springs are wear items that do degrade over time and need replacement. Sometimes they also crack or break. You should also examine them for cracks or breaks. Or take it to a suspension shop and get an opinion. Dont lift your truck, you may be creating more problems. If it were me I’d get new springs and if it didn’t do what I want I’d add a leaf.
  7. Aug 30, 2025 at 2:12 PM
    AJColorado
    AJ
    Thanks for the replies, I probably should have checked first, but my leaf springs are indeed entirely flat! I will start there and just get some OEM replacements or a slight upgrade.
    Also am considering Sumo springs or Road Active suspension... any thoughts on those?
  8. Aug 30, 2025 at 2:14 PM
    70m4h4wk
    70m4h4wk Well-Known Member
    Paris of the Praries
    23 Silverado LT, CCSB, 2.7L Turbo
    2/2 Drop, Ram Daytona Spoiler
    I would go for 5100s up front and 5160s in the rear. When you replace your rear leafs get a progressive leaf pack.
    Air bags are going to be a lot nicer than either sumo springs or RAS when unloaded but if those are the two you're going with, I'd probably pick the RAS.
    And if you dont have one, get a rear sway bar
  9. Aug 31, 2025 at 8:11 AM
    AJColorado
    AJ
    Do you have recommendations on a progressive leaf pack? Most of the ones I see add about 2" of lift.
  10. Aug 31, 2025 at 10:22 AM
    70m4h4wk
    I was going to say Deaver but it looks like they only have a 1.5" lift option.
    I know Alcan can make you a set that'll be exactly what you want. Not sure what their prices are like these days.
