Shocks -can you get any extra lift?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AJYota, Jul 8, 2010.
  1. Jul 8, 2010 at 6:34 PM
    AJYota
    AJYota [OP] Member
    AJ
    Florida
    4x4 Tacoma
    4x4, three inch Toy Tech sup lift and Maxxis Big Horn tires 285 75 16
    My son has the 2007 Tacoma 4x4 with a 3 inch supsenion lift. Is there a shock that will give him any extra lift?
  2. Jul 8, 2010 at 6:36 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
  3. Jul 8, 2010 at 6:36 PM
    Brunes
    Brunes abides.
    Rotorhead
    Lifting above 3 inches without a drop bracket for a 4x4 is a bad idea...Not good for the CV joints.
    There is no shock that will help out safely...
  4. Jul 8, 2010 at 6:42 PM
    AJYota
    AJYota [OP] Member
    AJ
    Florida
    4x4 Tacoma
    Thanks
  5. Jul 8, 2010 at 6:47 PM
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
    Normal shocks will not add any lift, shocks are just for dampening purposes. Air shocks on the other hand could give you lift. What you need to give you lift is coil springs (used on the coilovers) or leaf springs (for the rear)
  6. Jul 8, 2010 at 7:03 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    or RCD 4.5" drop bracket lift
