Shocks - Is there a set that will give you any lift?
Discussion in 'Suspension' started by AJYota, Jul 8, 2010.
  1. Jul 8, 2010 at 6:39 PM
    AJYota
    AJYota [OP] Member
    AJ
    Florida
    4x4 Tacoma
    4x4, three inch Toy Tech sup lift and Maxxis Big Horn tires 285 75 16
    My son has a 2007 Tacoma 4x4 with a 3 inch suspension life. He needs new shocks and we were wondering if there is a set that will give you any additional lift?
    What is a good set of shocks for a 4x4 that will add look, perfromance without breaking dad's wallet?
  2. Jul 8, 2010 at 7:51 PM
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    shocks in it of themselves do not give lift, they are simply dampers. springs give lift.
    the silver bilstein 5100s are a great set of shocks that will give up to 2.5" lift (adjustable coil seat) up front. you can pick up a set of 4 shocks for ~$300 from sonny at downsouthmotorsports.com. hes a great guy to deal w/. mention TW and you'll get a little hookup.
    also, dad's wallet?! make the kid pay for them himself...he's old enough to drive!!
  3. Jul 8, 2010 at 8:05 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    IF you want more than 3" of lift - you can't (shouldn't) do it with the suspension orientation that you currently have.
    You need to do some research and find the 4" or 6" lifts that are available for the tacomas.
  4. Jul 8, 2010 at 8:06 PM
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
    Custom Aluminum Camper
    X2
  5. Jul 8, 2010 at 8:07 PM
    747 function > form
    1st Gen.
    ^x3. Otherwise, billies.
  6. Jul 14, 2010 at 2:22 PM
    thinkingman
    thinkingman Well-Known Member
    redmond WA
    2006 dbl cab 4wd 6sp
    Foglights are for fog, not oncoming traffic!
    Not true re shocks....I have, on two vehicles replaced stock shocks with high-pressure gas shocks and gotten noticeable lift. I didn't measure before/after because I wasn't expecting it.
    I'd guess about 3/4".
    The shocks, btw, were Edelbrocks, one set on a Jeep Gr Cherokee, the other on a 2002 Durango.
  7. Jul 14, 2010 at 4:14 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    you can't go any higher than 3" susp lift with out putting on a drop bracket. you cv angles and ball joints will be maxed out w/ anything over 3" and failure of said parts will be the result.
  8. Jul 14, 2010 at 4:36 PM
    yosh2000
    CO
    '17 Tundra CM 5.7
    whatever you say dude...i know that i could compress my bils by hand... there is no way they would ever give the taco lift...
    why do you think you always have some sort of spring (coil, leaf, torsion rods) on a vehicle and then the shock?!
