Shocks making noise
Discussion in '4 Cylinder' started by alexander323bc, May 12, 2011.
  1. May 12, 2011 at 3:03 PM
    alexander323bc
    alexander323bc [OP] Well-Known Member
    Eric
    Buffalo New York
    4cyl access cab
    So my 2011 access cab 4yclinder 4x4 is making sqeeking sounds from what appears to be the rear shocks. It just started doing it the other day and is getting more and more noticeable. I can hear it at low speeds inside the truck and outside the truck I am sure it sounds worse. Right after I got the truck I put a cover on the back that weighs around 50 pounds. Is this constant weight to heavy for the OEM shocks? Maybe its not the shocks but I thought when I crawled under the truck and moved the bed up and down the sound was coming from there. Anyone have any ideas before I call the dealer and ask them to take a look? If this a good excuse to upgrade shocks and throw in a 3 inch lift let me know :) Since its a 4 cylinder truck I wanted to post and ask about it here. I read in the forum it might be leaf springs so I am going to try and lube them up and see if that helps. Got the truck in november I am surprised this happening already
  2. May 12, 2011 at 3:55 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Have someone stand in the bed, and move around, while you are under it, and try to identify where the sounds are comming from.
  3. May 12, 2011 at 4:09 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    more than likely it's your leafs making the squeaks. they need to be cleaned/lubed. dirt in the leafs will make them squeak.
  4. May 21, 2011 at 4:49 AM
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    I washed the leafs out and just sprayed with wd40 and all the squeaks stopped! Next time I was the truck I will lube with some good grease thanks for all the help guys! I am still thinking about putting an ICON suspension on with a 3 inch lift at some point.
  5. May 21, 2011 at 6:40 AM
    maxpower29
    maxpower29 Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    x2. as simple as a caveman but effective lol
  6. May 22, 2011 at 5:11 AM
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    Ya the noise is coming from the leaf springs its been all quite this week until this morning. I was really hungover this morning driving around trying to find my dignity at 7 am but all I could find was the noise of squeaky leaf springs coming into my ears. Whats a good kind of lubricant so I don't have to do this every week? Would putting different leafs on solve the issue?
  7. May 22, 2011 at 6:22 AM
    maxpower29
    Jordan
    Nova Scotia, Canada
    I dunno but thats a funny way to put it lol
    Sucks, I remember my 2008 civic si when I bought it did the same thing and I almost lost my miind trying to figure it out. It did the whole "stop when you bring it to the dealership" too. After 4 months on and off it wasnt even the springs, it was the clutch but it was such a weird sound.
    All in all I feel your pain. Nothing pisses me off more then something new that sounds old
  8. May 22, 2011 at 8:58 AM
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    There is something called white lightening or lithium grease something like that supposed to be top end lube and not very expensive going to try that.
  9. May 22, 2011 at 9:09 AM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    lithium grease works wonders
  10. May 22, 2011 at 9:30 AM
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    Lithium grease it is! I still want a lift though so I can run nitto terra grapplers because they dont make them in a 245 :(
  11. May 22, 2011 at 7:27 PM
    Joels98taco
    Joels98taco Well-Known Member
    joel
    chino hills
    98 5 lug tacoma
    fabtech 3" spindles, icon aal, 10" bilstein 7100 rear shocks, daystar coil spacers, AFE Pro Dry-s drop in filter, sony head unit, 2 12" pioneer subs, pioneer 6.5s all around, custom 1.25 lift shackles, custom lower ball joint brackets fabbed by me
    sounds like a good excuse to lift :D
  12. May 22, 2011 at 7:59 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    You can fit up to 265/75-16 at stock height. Not to discourage you from a lift of course. :D
  13. May 24, 2011 at 5:07 AM
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    Ken thanks for the info. When my stock tires wear out I will upgrade :) first things first to try and making this squeaking stop for more than a week
  14. Jan 16, 2012 at 10:33 AM
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    Ok so we all now know its not the shocks but the leafs. I heard there was a TSB on this and even getting the xtra leaf for the 2011 but I asked the dealer they said there was not. Anyone have a 2011 and got the extra leaf or the new pad?
  15. Jan 16, 2012 at 2:09 PM
    frog13
    frog13 Well-Known Member
    alexander.........I do not have a Tacoma...yet,but I do remember there being a TSB or something of that nature awhile ago...4-7 months approximately.I believe there is a "sticky" in relation to TSB's???.
  16. Jan 17, 2012 at 11:19 AM
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    Frog- Thanks I saw the TSB just surprised the dealer said there was not one for 2011. I guess I will just call back :(
  17. Jan 17, 2012 at 3:02 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    i think whoever you talked to doesnt want to do it. keep trying
