Shocks (other then billy's)
Discussion in 'Suspension' started by JayARRGHH, Apr 28, 2011.
  1. Apr 28, 2011 at 6:22 PM
    JayARRGHH
    JayARRGHH [OP] Well-Known Member
    Jay
    Bellingham, MA
    03 Tacoma SR5 TRD
    285/75/R16 Eldarado MTZ, Alpine CDE-102 Deck, DIY Snorkel, 2" Spacer Lift, Uniden Bearcat 880 CB, Custom over head console w/ map lights, CB Mount, and external CB speaker, 2 12" Kenwood Subwoofers, 300 Watt Alpine Amp, Alpine 3" lift 500# capacity
    Ok so i apologize i've searched everywhere and all I get are "GET BILLY 5100s!!" More than likely i am going to get them but i'd like to keep my options open. Any other suggestions? My chevy friend is always telling me to get skyjackers or ranchos but i feel like thats just because he's a chevy meat head. I was looking at these pro comps
    http://www.4wheelparts.com/Lift-Kits-Suspensions-and-Shocks/4-Procomp-ES1000-shocks-with-4-black-shock-boots.aspx?t_c=1&t_s=90&t_pt=101006&t_pl=101369&t_pn=ShockingES1000
    but I don't know anything about them. Also, I have an 03 tacoma with stock coils and leafs and 31s.
    Thanks for any input.
    -Jay
  2. Apr 28, 2011 at 6:25 PM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    3rd gen Tacoma
    Chicken lights, chrome and smoke tunes.
    If you want to spend money and do it right get these, scroll about 3/4 of the page down.
  3. Apr 28, 2011 at 7:32 PM
    JayARRGHH
    Jay
    Bellingham, MA
    03 Tacoma SR5 TRD
    i also should have mentioned I only do small weekend warrior/trail runs. I think, if I looked at the right ones, those were more hardcore than what I need. Thanks for the suggestion though.
  4. Apr 28, 2011 at 7:35 PM
    Phuket
    Phuket Well-Known Member
    Travis
    Los Angeles
    03 4X4 TRD
    Eibach/Toytec coils, bilstein 5100's all around, Kenwood DNX7100 Navigation
    honestly the bilsteins are great compared to stock. Everyone uses them and loves them! so why not get them? haha
  5. Apr 28, 2011 at 7:42 PM
    JayARRGHH
    Jay
    Bellingham, MA
    03 Tacoma SR5 TRD
    well that was my thought exactly, you know everyone on here uses them so they obviously must be good but I just wanted to keep my options open and see if there were any other suggestions, especially with my money situation right now.
  6. Apr 28, 2011 at 7:45 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    In order of robustness and increasing cost:
    Spacers -> Bilstein 5100 -> OME Nitrocharger -> Coilovers
  7. Apr 28, 2011 at 7:53 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    I vote some nitrochargers and corresponding coils. This is the only set up that doesn't really pre-load your suspension
  8. Apr 28, 2011 at 7:54 PM
    Max-4_Yota
    Michael
    South Carolina
    3rd gen Tacoma
    This, I would go OME before 5100
  9. Apr 28, 2011 at 7:58 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    Look into rancho 2.5" quick lift. Pretty cheap and you can adjust the stiffness of the shocks.
  10. Apr 28, 2011 at 7:58 PM
    JayARRGHH
    Jay
    Bellingham, MA
    03 Tacoma SR5 TRD
    Alright So I need front coilovers, can I use the stock coils with the OME Nitros? and best place to find them?
    Thanks guys.
  11. Apr 28, 2011 at 8:00 PM
    DocCisco
    DocCisco Well-Known Member
    David
    Utah County, UT
    LB TRD Sport 4x4
    Noob question, what is the benefit of not having preloaded suspension? I assume pre-loaded is not as good?
  12. Apr 28, 2011 at 8:02 PM
    Max-4_Yota
    Michael
    South Carolina
    3rd gen Tacoma
    Less travel, stiffer suspension.
  13. Apr 28, 2011 at 8:25 PM
    malander
    max
    01 limited trd 4x4
    And premature wear. The shock will want to "fight" with the spring to get back to it's original position. Spacer lifts and bilstein 5100s preload the suspension and when coilovers are cranked up to a certain amount of lift, they too are preloading the spring. However bilstein 5100s and coilovers are both good options, just at different spectrums of the market (ones relatively cheap, the other not so much). Spacers are what you should really beware of.
  14. Apr 28, 2011 at 8:27 PM
    malander
    max
    01 limited trd 4x4
    You won't gain amylose with stock coils and nitros. They are not ride height adjustable. What cab size, engine size, gen are you? Any extra weight up front?
  15. Apr 28, 2011 at 9:21 PM
    JayARRGHH
    Jay
    Bellingham, MA
    03 Tacoma SR5 TRD
    I'm 1st gen, 2003, extracab, v6 (3.7 i believe?) and there is no extra weight but I do plan on getting a relentless or ARB type front bumper.
    04_24_11842 by JayRodenhiser, on Flickr
    ^^Thats my truck, almost all the weight is on the back with that ladder rack but its probably 100 pounds maybe, it basically levels off the truck.
  16. Apr 28, 2011 at 9:52 PM
    malander
    max
    01 limited trd 4x4
    I'd recommend the 882 springs if you're getting a bumper as well, but to level it out you will need to do something about the rear
  17. Apr 28, 2011 at 10:05 PM
    JayARRGHH
    Jay
    Bellingham, MA
    03 Tacoma SR5 TRD
    yea really what im going to do is get my leafs re-arched because they're sagging pretty bad, but im just trying to find a good set up for the front with coilovers. On the cheap too lol.
  18. Apr 28, 2011 at 10:06 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    I just installed the OME lift , very impressed so far
  19. Apr 28, 2011 at 10:39 PM
    JayARRGHH
    Jay
    Bellingham, MA
    03 Tacoma SR5 TRD
    if you dont mind me asking, how much did it run you and did you do all 4 shocks and coil overs or what?
  20. Apr 28, 2011 at 10:48 PM
    OZ-T
    Peter North
    British Columbia
    I got mine in Canada
    Here is a link to give you an idea on pricing in the US
