Shocks Question
Discussion in 'Suspension' started by GoDeacsWFU23, Dec 17, 2011.
  1. Dec 17, 2011 at 5:21 PM
    GoDeacsWFU23
    GoDeacsWFU23 [OP] Well-Known Member
    Jonathan
    Clemmons, NC
    2013 Tacoma PreRunner TRD Sport
    I am going to be installing a spindle lift and the all pro 3" leaf kit within the next 3 or so months. Are the Bilstein 5100's suitable with this or should I upgrade to something else?
  2. Dec 20, 2011 at 2:30 AM
    samuelprz
    samuelprz Well-Known Member
    Samuel
    NoR CaL
    06 PreRunner TRD Off-Road,
    Eibach Coils Bilstein 5100s front Maxtrac Spindles SpiderTrax Wheel Spacers Bilstein 5100s rear*extended All Pro Expo Leafpack 6,000k HID's (Headlights and Fogs)
    BUMP...
    I am also interested because i want to purchase a spindle lift but already purchased all around 5100's from downsouthmotorports.
  3. Dec 20, 2011 at 5:57 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    The 5100's are not designed for 3" of lift in the rear. You should get the 5125's, they come in custom lengths. Call downsouthmotorsports to find out which is best for you.
  4. Dec 20, 2011 at 6:04 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Personally, I wouldn't get the 5125's on a 2nd Gen. There is a 5100 that will accomodate a 3" lift, just be careful with ones you order. The 5100's come in 2 lengths: 0 - 1.5" of lift and 3 - 4" of lift. The reason I wouldn't get the 5125's is because the adapter adds something like 1.5" to the shock length but does not increase travel. I'd look at the longer 5100's or at least consider them. KPT is correct though, the 5125's will work for your application, just wouldn't be my first choice.
  5. Dec 20, 2011 at 6:07 AM
    KPT
    09 Prerunner
    Thats true I forgot about the 5100's that are designed for the RCD drop bracket lift, which has a 4" block in the back.
