SHOCKS! SHOCKS! SHOCKS! Can't find correct length.
Discussion in 'Suspension' started by ndcmack, May 24, 2013.
  1. May 24, 2013 at 7:24 PM
    ndcmack
    ndcmack [OP] Well-Known Member
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    I've researched and researched. I've posted on a few existing treads. Still no good answer. I've installed Dakars w/aal (Allpro flip w/Timbren bumps) and replaced my shocks with Billy 5160's, the problem is they are over 3" to short on full extension. I know many will say run OME shocks, but the reality is these two shocks have almost identical specifications (5160=13.84"x23.23",OME=13.85"23.93").
    I can't be the only guy running Dakars w/aal that has found this. I'm looking for options. Custom maybe? Who makes them? I'd like to hear what othersare running with my current setup. Any and all feedback appreciated!
    Side note: Almost brand new 5160's will be for sale when I solve this...
  2. May 24, 2013 at 7:30 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    those b110 5100s maybe? 16.3"x 27.3"
  3. May 24, 2013 at 7:43 PM
    bzzr2
    bzzr2 Well-Known Member
    procomp; 32551X 25.75extended 15.04compressed 10.71travel, mounting-Stem Loop 2.36
    i plan to swap to these at some point, i currently run the sky jacker h7045 with my dakars on my reg cab tacoma, no add a leaf but we're probably very close in ride height due to truck variances. anyway my sky jackers are 24.75 extended and the extra inch will make a difference in those off road situations where only a tiny bit more makes the difference. i chose these because they were almost an inch longer than the ome's and less than half the price and am happy i did. the procomps run about 65-75 for a pair and for the money i think are worth a try. with my shocks my brake lines still have room to play, not much though but another inch should still be non issue. there is a thread somewhere that shows how a guy made a new mounting bracket for next to nothing to loosen up the lines at the axle. not sure if your lines are extended. i know you are looking for 3 inches more length but the two on this shock should put you in a good place. if you need more later at least this cost very little and gets you going.
  4. May 24, 2013 at 7:43 PM
    ndcmack
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    I looked at those, but my compressed is less than 16.3. I suppose I could modify my bump stops but...
    I was hoping to find something with a reservoir. And would love to not modify bumps or shock mounts.
  5. May 24, 2013 at 7:49 PM
    ndcmack
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    I looked at the Pro Comps(and they would be much better by length), but really looking for reservoir shocks. I have Toytec extended brake lines so no issue there. I'd recommend them to you.
  6. May 24, 2013 at 7:49 PM
    bzzr2
    my h7045's are 14.54 compressed and there are no issues running stock bump stops, the truck is wheeled and gets fully flexed and compressed. i am not worried to go the extra .5 for the procomps as there seems to be room to breathe on that, not sure exactly how much though but enough.
  7. May 24, 2013 at 7:53 PM
    bzzr2
    cool, i'll be curious to see what else comes up in your search. the procomps might be cheaper in the states, i'm in canada, for 40-50 bucks might get you by for a while until you find something with reservoirs to beat on! had the procomps been available when i needed them i'd be running them now.
  8. May 24, 2013 at 8:03 PM
    bzzr2
    one more just a bit longer, gets that extra 3 inches;
    32651X 26.79 15.56 11.23 Stem Loop 2.36
    i'll stop now since you may have already seen these..
  9. May 24, 2013 at 8:10 PM
    ndcmack
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    Thanks for the Pro Comp info!
  10. May 24, 2013 at 8:13 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    i would cycle the rear and take measurements and get a shock to match.
  11. May 25, 2013 at 6:26 AM
    ndcmack
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    I did cycle it and have some rough measurements, 15" compressed and 26+" extended. I say these are rough because they are static measurements.What I've been looking for an Icon, King, Fox, Bilstein, with a reservoir that will work with these measurements
  12. May 28, 2013 at 10:00 AM
    ndcmack
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    Bump... still looking for resi options
  13. May 28, 2013 at 10:06 AM
    kbauman92
    kbauman92 Well-Known Member
    Kyle
    North Bend
    98 tacoma ext cab
    King 2.5x6 RR coilovers eibach coils Light Racing UCA Spidertrax spacers Fiberwerx fenders
    im pretty sure your either going to have to get longer bumps or move the mounting location if you want to run that long of a shock, id look on http://downsouthmotorsports.com/ and see if you can find anything close
