shocks Struts and suspension
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DanTacomaNauman, Nov 4, 2014.
  1. Nov 4, 2014 at 8:32 AM
    DanTacomaNauman
    DanTacomaNauman [OP] Active Member
    Daniel
    Montana
    06 TRD Sr5 Sport
    K&N air filter
    Looking at lifting my 06 toyota tacoma 3", what recommendations do you have for brands or any advise I should know about?
  2. Nov 4, 2014 at 8:42 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    What will the use of the lift be? Function or Form?
  3. Nov 4, 2014 at 8:42 PM
    DanTacomaNauman
    Daniel
    Montana
    06 TRD Sr5 Sport
    K&N air filter
    Function, living in montana hunting getting into mud and huge ruts I need some more clearance. I'm curious as to a reasonable price range, if I get seperate shocks and suspension or just buy the entire kit for a 3" lift front and back. I have nothing done to my truck but a K&N air filter but I really would like to start getting my ride better looking. I think I will also replace my filter with a cold air intake instead.
  4. Nov 4, 2014 at 8:42 PM
    DanTacomaNauman
    Daniel
    Montana
    06 TRD Sr5 Sport
    K&N air filter
    I will post a picture tomorrow
  5. Nov 4, 2014 at 9:48 PM
    DPC08
    DPC08 Well-Known Member
    FL
    09 DCSB
    Getting there...
    Budget would be 5100's with an add a leaf or OME with an add a leaf. The general consensus on this forum is that the K&N air filter isn't good if you plan on going off road. OEM is less maintenance and proven reliability. And a CAI doesn't seem to do much without other performance upgrades.
  6. Nov 5, 2014 at 6:16 AM
    geekhouse23
  7. Nov 5, 2014 at 6:25 AM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    I am running Billie 5100 at the 1.75 setting in the front and TSB 4 leaf on my '11 AC and 265/75-16 AND 265/70-17 fit perfectly with FACTORY WHEELS with no rub and no trimming...
    I am NOT a big fan of K&N air cleaners. The factory intake works just fine. Now a Borla catback exhaust would be on my list. I also live up in the mountains and clearance is good.
  8. Nov 5, 2014 at 8:50 AM
    DanTacomaNauman
    Daniel
    Montana
    06 TRD Sr5 Sport
    K&N air filter
    I'm thinking an aFe magnum force cold air intake, MagnaFlow exhaust, JBA headers, old man emu? Let kit... but they don't have any going up to 3"... still a big self debate lol
  9. Nov 5, 2014 at 9:23 AM
    geekhouse23
    I have a full 3" OME kit :confused:
  10. Nov 5, 2014 at 10:19 AM
    Thegenerik1
    Thegenerik1 Well-Known Member
    Erik
    NorCal
    18 DCLB OR
    AAL in the rear and Fox 2.0 front coilovers. I love the ride of these and you can adjust height to setup how you like your trucks stance.
  11. Nov 5, 2014 at 10:43 AM
    FatTony415
    FatTony415 Well-Known Member
    Tony
    San Francisco, CA
    '20 DCSB 4x4 TRD Off Road
    Stock for now
    ^ This.
    You can get a full OME kit with Dakars from Toytec for $1,133 (after the 5% TW discount).
    Remember once you start approaching 3" of lift, you'll need new upper control arms, which are $400+. If you keep it at 2.5", you can probably stick with your OEM upper control arms.
    Alternatively, you may want to consider a more moderate 2" OME lift, using lighter coil springs in the front, and an AAL or progressive 3 leaf pack in the rear. That would keep your lift at about $800, and give you plenty of clearance for dirt roads and moderate offroading. Check my build for this option.
  12. Nov 5, 2014 at 11:54 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    You can do 3" with the OME. Just depends on your coil choices. Usually on a double cab with no bumper or winch, I suggest the 885 coils with a 10mm Enhancer kit. This will get you close to 3" while still keeping the ride good.
  13. Nov 5, 2014 at 11:58 AM
    Mr Salty
    Mr Salty "Give up the good to go for the great"
    Hermmy
    SoCal (Bro Capital of the world)
    White SR5 Pre-runner
    Lots of chrome
    The total I got from TT was $1134.29 and that does not include the carrier bearing drop, you got to compare apples to apples.... just saying :p
  14. Nov 5, 2014 at 3:35 PM
    DanTacomaNauman
    Daniel
    Montana
    06 TRD Sr5 Sport
    K&N air filter
    Holy moly... this like a different language when getting technical into the lifting language
  15. Nov 5, 2014 at 4:28 PM
    DanTacomaNauman
    Daniel
    Montana
    06 TRD Sr5 Sport
    K&N air filter
    Is the front of an 06 tacoma independent suspension?
  16. Nov 5, 2014 at 4:29 PM
    geekhouse23
  17. Nov 5, 2014 at 7:19 PM
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
  18. Nov 6, 2014 at 5:54 AM
    DanTacomaNauman
    Daniel
    Montana
    06 TRD Sr5 Sport
    K&N air filter
    I don't think I want add a leaf and thankyou geek house, sorry I haven't gotten around to the picture yet.
  19. Nov 6, 2014 at 6:04 AM
    geekhouse23
    I'm guessing since you are an 06, the stock leafs are sagging. An AAL will not last long. Best bet would be to replace the leaf pack entirely. Ask me how I know..lol
  20. Nov 6, 2014 at 10:43 AM
    DanTacomaNauman
    Daniel
    Montana
    06 TRD Sr5 Sport
    K&N air filter
    Haha that's what I'm thinking also, experience it first hand? Have you experienced any strain on your front end, any problems with tie rides or anything?
