shocks Struts and suspension
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DanTacomaNauman, Nov 4, 2014.
  1. Nov 6, 2014 at 10:47 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Zero issues.
    Just don't get the diff drop and make sure you get the carrier bearing drop kit.
    You can check out my build for all my specs and pics.
  2. Nov 6, 2014 at 11:16 AM
    DanTacomaNauman
    DanTacomaNauman [OP] Active Member
    Daniel
    Montana
    06 TRD Sr5 Sport
    K&N air filter
    How do you post a picture?
  3. Nov 6, 2014 at 11:17 AM
    DanTacomaNauman
    Daniel
    Montana
    06 TRD Sr5 Sport
    K&N air filter
    How long have you had your lift on? And how many miles do you have on your truck?
  4. Nov 6, 2014 at 11:19 AM
    geekhouse23
  5. Nov 6, 2014 at 11:21 AM
    DanTacomaNauman
    Daniel
    Montana
    06 TRD Sr5 Sport
    K&N air filter
    Ok ya I'm at around 90 and thanks I'll show you what I'm thinking of doing
  6. Nov 6, 2014 at 11:28 AM
    DanTacomaNauman
    Daniel
    Montana
    06 TRD Sr5 Sport
    K&N air filter
  7. Nov 6, 2014 at 4:43 PM
    streakmica07
    streakmica07 Member
    Holbrook, NY
    o7 off road
    none yet
    I have a 07 and just today had a spring shop beef up my leafs and the truck is 2 inches higher and rides like new money I'll let you know how it goes in a few days I also have billy 5100's fronts set at 1.75 and the Billy's 5100 in the rear
  8. Nov 6, 2014 at 9:10 PM
    DanTacomaNauman
    Daniel
    Montana
    06 TRD Sr5 Sport
    K&N air filter
    Thanks streak and yes please keep me updated!!
  9. Nov 6, 2014 at 9:34 PM
    TacoBrah
    TacoBrah Well-Known Member
    Sean
    Icon stage 1, 255/85/16 KM2
    Dont do Billstein or OME, get a 2.5" coilover it will blow them away.
  10. Nov 7, 2014 at 2:19 PM
    DanTacomaNauman
    Daniel
    Montana
    06 TRD Sr5 Sport
    K&N air filter
    I'm really leaning towards not lifting it:/
  11. Nov 7, 2014 at 6:46 PM
    TacoBrah
    Sean
    Why?
  12. Nov 7, 2014 at 7:22 PM
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Well this has all been one big tease...
  13. Nov 7, 2014 at 8:31 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Not lifting your Tacoma is like not putting a coffee can muffler on your Civic. It's just unheard of.
  14. Nov 11, 2014 at 12:03 PM
    DanTacomaNauman
    Daniel
    Montana
    06 TRD Sr5 Sport
    K&N air filter
  15. Nov 11, 2014 at 2:34 PM
    #35
    DanTacomaNauman
    Daniel
    Montana
    06 TRD Sr5 Sport
    K&N air filter
    Haha I know but it's soo much and if it causes strain on the front end in the long run, I don't think it's a great idea.
  16. Nov 11, 2014 at 2:39 PM
    #36
    DanTacomaNauman
    Daniel
    Montana
    06 TRD Sr5 Sport
    K&N air filter
    I will lift it I just don't want it to cause problems in the long run :\
  17. Nov 11, 2014 at 2:42 PM
    #37
    Ihatetacomas
    Ihatetacomas Because tacomas hate me
    Dylan
    Elko NV
    '12 White LB TRD Sport
    Used @ 23,283 Volant Intake (w/ scoop)(removed August 2016), BAKFlip G2 Tonneau Cover, (drain tube mod), Pop & Lock Tailgate Lock, Stampede Vigilante Premium VP Series Hood Protector, 5lb Extinguisher, Shovel & Axe mounted in bed, Shok Industries Sound Deadener, Mercury: (K62, MGR-1200, MGR-495) Triton 8" Subs, Custom-Made: Sub Box, Speaker Templates, Vapor Barrier, All-Pro Bumper w/Kickouts, hidden trailer hitch, wooden cup-holder Misc: Knukonceptz RCA, speaker, and power wires, Big 3 Upgrade, a very full Husky technician tool box
    Keep in mind that Borla's exhaust is a .25 inch smaller than the stock exhaust (2.25 vs 2.5 inches). Which ='s more low 'towing' power less high end power.
  18. Nov 11, 2014 at 2:55 PM
    #38
    Ihatetacomas
    Dylan
    Elko NV
    Im doing the same thing you are more or less.
    If budget is what your going for OME would be your best bet..
    OR
    you could go into coilovers, which replaces your shocks and coils up front but there expensive...
    This can get expensive. If you decide to do this then youll be changing out (or adding onto) your leafs and shocks (rear) and coilovers and Upper Control Arms, or UCA's.
    Coilover options go from:
    ICON (digressive)
    KINGS (progressive)
    FOX (progressive I think)
    and
    possibly Camburg or Total Chaos, iv only seen Long Travel kits for them...
    These companies also apply for rear shock companies.
    Differential Drop Kits drop your differential obviously. Check out the suspension topic stickys for more on that.
    For leafs you have the choice of either Add-A-Leafs or Leaf Packs, all depends on budget and you don't always need the top of the line.
    Another thing you might want to look into is progressive vs digressive valving. Im still learning, so don't quote me, but from what iv been told by a vender is that digressive would be more towards if your on the road most of the time. Progressive gets progressively stiffer the higher speeds your going.
    Also make sure to check out the vendors here, most have coupons or codes to use if your a Tacomaworld member.
    Any questions feel free to send me a message and to everyone else out there reading this if I missed something bring it up.
  19. Nov 11, 2014 at 5:51 PM
    #39
    TacoBrah
    Sean
    A lift wont do that.
    Just do things right the first time, get a nice coilover lift.
  20. Nov 11, 2014 at 7:30 PM
    #40
    DanTacomaNauman
    Daniel
    Montana
    06 TRD Sr5 Sport
    K&N air filter
    Cool thanks guys! Did you take a look at the second link I posted for pics of my truck?
