shocks tighten
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Slade1, Jun 4, 2021.
  1. Jun 4, 2021 at 3:37 PM
    Slade1
    Slade1 [OP] Member
    Mitch
    2020 Tocoma Sr5 4x4
    None yet
    I think if i ditch the locking Nuts It should work tighten up and then use another nut with lock washer will try tomorrow ace hard ware closed now only place to get bolts and nuts in my area
  2. Jun 4, 2021 at 6:44 PM
    SilverSkyTRD
    SilverSkyTRD Well-Known Member
    sounds like a solid plan. ace is the place!
    Skydvrr likes this.
  3. Jun 4, 2021 at 6:45 PM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    Well that could be good and that could be bad.
    Skydvrr likes this.
  4. Jun 4, 2021 at 7:04 PM
    Slade1
    Slade1 [OP] Member
    Mitch
    2020 Tocoma Sr5 4x4
    None yet
    And some LockTite as well with 2 bolts and lock washer between themk
  5. Jun 4, 2021 at 7:08 PM
    Bishop84
    Bishop84 Well-Known Member
    The days of shocks loosening off are long gone. If they don't fit, something is installed incorrectly.
    Mark77 and Chew like this.
  6. Jun 4, 2021 at 7:15 PM
    Anderson5290
    Anderson5290 Well-Known Member
    Brandon
    Corona, Ca
    2018 Tacoma TRD OR 4x4
    Tuned Fox 2.5 resi with dsc, JBA HD UCA, total chaos knuckle gussets, rear trd pro fox shocks, Deaver U402 stage 1 rear leafs, archive garage u bolt flip with fox 2.0 air bumps, White knuckle off road rock sliders, BAMF 1/4” steel skids, Magnaflow exhaust, Archive Garage Hammer Hangers, Cbi high clearance rear bumper, 285/75/16 tires.
    I’m so confused, is there a question? Or are you just needing to be reassured your plan will work?
    Junkhead, tinker_troy, Mark77 and 3 others like this.
  7. Jun 4, 2021 at 9:03 PM
    CaptainBart45
    Bart
    Work in progress...
    The question to the answer is usually asked from within.
  8. Jun 4, 2021 at 10:25 PM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    Let us know when you get your hands on some nuts.
    As always use blue loctite. Let us know how it pans out.
    CaptainBart45 likes this.
  9. Jun 5, 2021 at 5:29 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    I'm glad I wasn't the only one,,,,
  10. Jun 5, 2021 at 12:05 PM
    Slade1
    Slade1 [OP] Member
    Mitch
    2020 Tocoma Sr5 4x4
    None yet
    shocks new just got them Now need for front // The problem was the threaded rod was all threads so when you tried to use the lock nuts they would only turn a few threads and the the rod would spin. the the threaded rod did not have a square top or anything to grab. I took regular #10 metric Nuts and blue loctite which tightened down no problem rod did not spin. then I used the lock nuts on top so all good now and thanks for all the info and concern
  11. Jun 5, 2021 at 12:10 PM
    Mark77
    Mark77 Well-Known Member
    Mark
    2021 White TRD Off-road
    Nothing yet
    Is English your second language or are you using talk to text?
    Honest question. Some punctuation and complete sentences would help immensely.
    My bug thumbs cause tons of typos. So i get it.
  12. Jun 5, 2021 at 12:23 PM
    Slade1
    Slade1 [OP] Member
    Mitch
    2020 Tocoma Sr5 4x4
    None yet
    Ok here an honest answer if you cant understand what is written just pass on it,, not here for your approval
    Skydvrr likes this.
  13. Jun 5, 2021 at 1:13 PM
    Anderson5290
    Brandon
    Corona, Ca
    Not sure he was being a dick. I think he honestly didn’t understand the question, because I still don’t. Some pics would be extremely helpful in this situation. And by threaded rod are we talking all thread? Or are we talking about the upper stud mount on the rear shock? I think I get it now, you can also hold the shock shaft by hand if it’s accessible and that will usually be enough to stop it from spinning to tighten the lock nut.
    Junkhead, Mark77 and tinker_troy like this.
  14. Jun 5, 2021 at 1:29 PM
    Mark77
    Mark
    Nothing yet
    This. If i was going to be a dick, id have just ignored the thread. And yes, photos would have helped too.
  15. Jun 5, 2021 at 1:44 PM
    Slade1
    Slade1 [OP] Member
    Mitch
    2020 Tocoma Sr5 4x4
    None yet
    well asking if my second language and adding.. Some punctuation and complete sentences would help immensely. I find that out of bounds. regardless If there is a way to delete my account let me know if not ill Just stop visiting . Thank you
  16. Jun 5, 2021 at 1:55 PM
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    Lol what the hell?
    Mark77, SpeySquatch and Junkhead like this.
  17. Jun 5, 2021 at 2:00 PM
    Pro-Taco
    Pro-Taco Well-Known Member
    Lou
    Commiefornia
    2019 OR DCSB 4X4 Prem/Tech Cement
    All TRD Pro parts
    As in any forum, sometimes you'll get responses you were not looking for, no need to delete your account because of that. And yes, your original post was a bit confusing. I couldn't understand what you were looking to achieve until post #10.
    Back to your question. I had the same problem with my PRO Foxes. What I did is I used wise grips to hold the rod in place and prevent it from spinning. The key is to use a piece of rubber hose or electrical tape around the rod to not scratch it with the wise grips. Worked like a charm for me. Better luck next time.
    Mark77, BOZOJUICE and Junkhead like this.
  18. Jun 5, 2021 at 2:12 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    :notsure:
