Shocks
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Johnm2491, Apr 20, 2016.
  1. Apr 20, 2016 at 8:57 AM
    Johnm2491
    Johnm2491 [OP] Well-Known Member
    2024 TRD Off Road DCSB
    Frigg-off Barb
    How can you tell if your shocks are shot? I'm at 80,000 miles if that matters
  2. Apr 20, 2016 at 8:59 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Usually if you press down on the rear or front it should just bounce back up and not keep bouncing. I believe, I am not a shock guru.
  3. Apr 20, 2016 at 8:59 AM
    Clearwater Bill
    Billy
    Largo Florida
    Remove one and test it.
    You can even do that by hand, assuming you have a new one to compare it to.
    Unchained 5150 likes this.
  4. Apr 20, 2016 at 9:10 AM
    Johnm2491
    Frigg-off Barb
    Do you guys know what that part is and is it supposed to be paralle/level to the ground? LCA maybe? Sorta just starting out in the mechanic stuff thanks!
  5. Apr 20, 2016 at 9:11 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
  6. Apr 20, 2016 at 9:20 AM
    Johnm2491
    Frigg-off Barb
    Thanks yes I've noticed on there that it's pointed down more and mine level so idk if it's cause mine is a base model and not a trd. Or if an old worn out shock would
    Be the problem
  7. Apr 20, 2016 at 9:24 AM
    digitaLbraVo
    digitaLbraVo Derka Derka
    Covered in stickers and chrome stick-ons for extra horse torques and foot powers. Icon sticker gets me tons of travel, dozens of milimeters.
    Springs hold weight, shocks keep springs from endlessly rocking back and forth/bouncing.
    A lower control arm pointed towards the ground/downwards is typically normal or slightly lifted. One pointed up may indicate a sagging spring.
  8. Apr 20, 2016 at 9:31 AM
    Clearwater Bill
    Billy
    Largo Florida
    For optimal handling (street/road) level is the goal.
    I've seen many an autox car 'slammed' on the premise that lower is better, not considering they were ruining steering geometry.
    As digitaL says, shocks or struts don't raise or lower anything. They just dampen (hence the correct name 'damper') the spring action.
    digitaLbraVo likes this.
