Shocks
Discussion in '1st Gen. Tacomas (1995-2004)' started by Scottdl99, Nov 22, 2009.
  1. Nov 22, 2009 at 7:42 AM
    Scottdl99
    Scottdl99 [OP] Well-Known Member
    Indianapolis
    06' DC
    5100's w/884's @0, Sliders, Headlight bake w/eyelids, Rears blacked,5% tint. AFE Pro dry S, All LED interiors, Sridertrax, a few more
    I own a 98 tacoma....will newer model oem rear shocks fit and work on my taco? Also the fronts?
  2. Nov 22, 2009 at 7:43 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Newer model meaning 2nd gen? 05-current? No, they won't.
  3. Nov 22, 2009 at 7:48 AM
    Scottdl99
    Indianapolis
    06' DC
    yeah that's what I was looking for. Bummer.
    What year ranges will fit?
  4. Nov 22, 2009 at 7:51 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    95.5-04
    Are you looking to replace yours?
  5. Nov 22, 2009 at 7:59 AM
    Scottdl99
    Indianapolis
    06' DC
    Yes, I need to replace them all around. I would like to find some that would lift it a little more, but not nessasary
  6. Nov 22, 2009 at 8:08 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    There are several affordable choices for that. Billy 5100's are well liked and run on this board. There are adjustable in the front. The Toytec lift is also well liked and used here too. You can get a member discount also.
  7. Nov 22, 2009 at 8:10 AM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Shocks don't provide lift, that is unless you have the Bilstein 5100 shocks. These provide lift for the front only. For the rear you'll need to get either blocks (not recommended), shackles, AALs or new leaf packs.
  8. Nov 22, 2009 at 8:16 AM
    Scottdl99
    Indianapolis
    06' DC
    Ok all that helps. Now just to find someone parting with theirs, or some stock one's with low miles
  9. Nov 22, 2009 at 8:18 AM
    humanoid
    humanoid bite me
    Sunny SoCal
    Why not pick up new shocks instead of replacing them with used ones? New shocks aren't that expensive IMO.
  10. Nov 22, 2009 at 8:20 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Or just piece them (buy fronts now, rears later) and install them together.
  11. Nov 22, 2009 at 8:28 AM
    Scottdl99
    Indianapolis
    06' DC
    Where is the cheapest place to find them? Also a sway bar...is this an add on part? Or is there already one on my truck?
    The reason I ask is my truck rocks left and right alot. I was told to replace the rear shocks first and go from there....
    Thanks for your help guys!!
  12. Nov 22, 2009 at 8:30 AM
    humanoid
    humanoid bite me
    Sunny SoCal
    You already have a front sway bar, maybe you need to have the sway bar bushings replaced. Go to wheelersoffroad.com and pick a set up from there. That will help with the swaying along with getting new shocks, your current ones seem to be on their last legs.
  13. Nov 22, 2009 at 8:31 AM
    humanoid
    humanoid bite me
    Sunny SoCal
    Almost forgot, if you're going to pick up the Billy 5100 shocks then pick them up from Sonny at downsouthmotorsports.com, he's got the best prices around.
  14. Nov 22, 2009 at 8:35 AM
    Scottdl99
    Indianapolis
    06' DC
    Are you talking about these: http://www.wheelersoffroad.com/tacoswaykit.htm
  15. Nov 22, 2009 at 11:28 AM
    humanoid
    humanoid bite me
    Sunny SoCal
    Yup, those would be it.
