Shoe Creek Meet - 26 Jan 2013
Discussion in 'South East' started by DSully72, Oct 13, 2012.
  1. Jan 27, 2013 at 12:55 PM
    #981
    Slimwood Shady
    Slimwood Shady I love your mom!
    Linwood
    San Antonio, TX
    '23 TRD Pro Tundra; 996TT; '16 Odyssey
    #nomods
    :rofl: same thing happened to me when I first used it at Uwharrie.....got home and as excited to watch the video to find out I only took 3 face shots of myself. :laugh:
  2. Jan 27, 2013 at 1:05 PM
    #982
    tacoma89
    tacoma89 Money Pit
    Chase
    Richmond, Va
    08 sport dc lb
    Check build in sig.
    Ya funny was you cleared the rock when you drove straight but when your tires were turned you would get caught up. :eek: it was turned on just taking pics every time I thought I was taking video. got 1 video I will try to get posted.
    yup i got a couple face and hand shots and 1 video:(
    better luck next time I guess, still had fun
  3. Jan 27, 2013 at 1:11 PM
    #983
    ruggedT
    ruggedT The Sticker Guy
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    Nice. My yoke and pumpkin took a beating. Barley missed my tcase too :eek:
  4. Jan 27, 2013 at 1:34 PM
    #984
    jandrews
    '09 FourDubDee TRD OR
    Got my drum brake fixed this morning...basically, something froze and seized overnight, probably because I parked the truck right after dunking it in that stream crossing by second camp.
    Anyway, somehow the e-brake actuating lever worked it's way outside of the brake shoe and into the return spring, stretching the spring out, pushing it against the wheel hub, and causing the brake to adjust WAY too tight...the shuffling sound in the first vid is the brake dragging.
    Using two small prybars I was able to work the e-brake actuator back behind the shoe where it belongs, bent the lip on the back of the wheel hub so it cleared the (now no longer pooched out) return spring, and everything's back to normal.
    Final step was to adjust the passenger rear drum down quite a bit. This required a second removal of the wheel and drum. Fun fact about these tacoma drum brakes: You can adjust them tighter from the grommet access on the backing plate, but you can't adjust them looser. That requires pulling the drum, prying the ratchet mechanism back, and using a small prybar or screwdriver to turn the adjustment gear.
    Anyway, all is as it should be now.
    http://www.youtube.com/watch?v=YExmmXcuprg
    http://www.youtube.com/watch?v=FxlizK72fLw
    http://www.youtube.com/watch?v=wsgtARst62Y
  5. Jan 27, 2013 at 1:35 PM
    #985
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    I'm good from front to rear of transfer case on skids. Just the drive shaft I gotta worry about. I hope I fixed the engine problem. Found one of the cam sensors wasn't seated all the way but that shouldn't have thrown the code it did. Took what is usually the problem out and tested it and the oil control valve and it actuated like it was suppose to. Drove it and it did shutter and have a lack of power or shut off or any code like yesterday. Drove it
  6. Jan 27, 2013 at 1:37 PM
    #986
    wrmathis
    Bonaire, GA
    parts and stuff
  7. Jan 27, 2013 at 1:39 PM
    #987
    Slimwood Shady
    Linwood
    San Antonio, TX
    #nomods
  8. Jan 27, 2013 at 1:42 PM
    #988
    jandrews
    I'll edit the post with a full run down once the vids are done uploading.
  9. Jan 27, 2013 at 2:16 PM
    #989
    jandrews
    Fini.
  10. Jan 27, 2013 at 2:24 PM
    #990
    Slimwood Shady
    Linwood
    San Antonio, TX
    #nomods
    Sweet....now make another thread about this so someone else other than us can use your knowledge....
  11. Jan 27, 2013 at 2:26 PM
    #991
    jandrews
    I dunno man. Not really anything to tell. I'm not sure how it went wrong...something froze in the wrong place overnight...there's plenty of threads on here already covering drum brake anatomy. I'm not sure this is a problem that will reproduce for a lot of people.
  12. Jan 27, 2013 at 2:27 PM
    #992
    YotaMatt
    YotaMatt Livin Low, Ridin High
    West Point VA
    12 PreRunner DC TRD Sport
    Spidertraxx 1.25" spacers in front and rear, 4" Maxtrac Spindles,Billy 5100s at 0", OME 885 Springs, 1/4" top spacer on both sides, 1.5" AAL, 3" Block, 1.5" 4crawler driveshaft spacer, 17x9 XD Spys with 35x12.50 Nitto Mud Grapplers, Magnaflow offroad Stainless Exhaust, Volant Intake with scoop,Camo emblems, BHLM, Tinted tailights, Anytime fog mod,Alpine Type R 12, Kicker 1000 watt amp,600 watt 4 channel memphis and all memphis components, 35%tint front all the rest at 5%, Hella 500s with sylvania zxe bulbs, sylvania zxe headlights, sylvania zxe fogs, Weathertech digi fits, flyzeye blue/white, LED map dome license plate lights, Redline hood struts, Tailgate EZ Down, Custom TRD Camo Browning Edition Bedsides, Camo wet okoles, Ridgid Dually bed lights, SOS Concepts Tire Carrier
    Probably cuz some dumbass blinded you and you were just all messed up after that :cool:
  13. Jan 27, 2013 at 2:33 PM
    #993
    Slimwood Shady
    Linwood
    San Antonio, TX
    #nomods
  14. Jan 27, 2013 at 2:40 PM
    #994
    YotaMatt
    West Point VA
    New bedside decals I see :eek:
  15. Jan 27, 2013 at 4:36 PM
    #995
    FrustrationFabTaco
    FrustrationFabTaco Well-Known Member
    Luke
    Lexington, VA
    11 Duramax Grandpa Truck Special
    :spy:
    Like that sig pic Matt :thumbsup:
  16. Jan 27, 2013 at 6:33 PM
    #996
    YotaMatt
    West Point VA
    Thanks...Bandit took photo...I cropped it. .MGMtacoFF photoshopped it for me..:cool:
    Edit: just realized thats 3 matts involved :eek:
  17. Jan 27, 2013 at 6:38 PM
    #997
    FrustrationFabTaco
    Luke
    Lexington, VA
    :spy:
    Too many Matt's in here
  18. Jan 27, 2013 at 6:48 PM
    #998
    superwhite10
    superwhite10 Well-Known Member
    Garner, NC
    I know i was telling my gf who was who and i kept having to say matt, the big white truck or matt, the navy blue truck
  19. Jan 27, 2013 at 6:51 PM
    #999
    FrustrationFabTaco
    Luke
    Lexington, VA
    :spy:
    Nova group was talking about a mod day and I kept getting confused because there's another Luke there :confused:
  20. Jan 27, 2013 at 6:51 PM
    #1000
    ruggedT
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    Nice vids Linwood
