Shoot holes in this suspension option
Discussion in 'Suspension' started by imageomega, Jan 28, 2016.
  1. Jan 28, 2016 at 9:55 AM
    imageomega
    imageomega [OP] Well-Known Member
    Jarrod
    Haven't seen anyone with this setup, so would like the peanut gallery to proof the concept before going for it.
    Needs: Moderate lift to be used 85% highway and 15% offroad. Not into long travel but general over landing use. Hunting/fishing/backwoods camping/fire roads/etc.
    Budget: I'm all about value, not hard #'s. I'm well aware that $1500 gets me a more capable setup, but I just dont think I need it...
    Rear: OME/Dakar leaf pack for ~2.75". Stock shocks.
    Front: Low Range Offroads front spacer kit. 3", billet, well machined. Stock coils/shocks.
    ~3", capable enough, for under $600 with all taxes/shipping included.
    Would like to match with 255/85/16's. Have the right backspacing on my MB72's so I think rubbing will be minimal (have urethane mud flaps, not the bulky stockers).
    I'm against rear blocks for the same reason the rest of you are. What are the issue's/concerns with front spacers only and a decent rear setup? Do the same rules apply as would with coil/struts at 3" = new UCA's needed?
    thanks in advance
  2. Jan 28, 2016 at 9:56 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Just make sure your bumpstops are correct to prevent shock blowout. Most people don't, and let the shock become the bumpstop when it is compressed fully and then snaps.
  3. Jan 28, 2016 at 10:06 AM
    imageomega
    Jarrod
    Thanks @DCSBFTMFW
    Whats your opinion on diff drop kit requirement? seems both answers are available depending on where I look: Either its bull, or I cant live without it.
  4. Jan 28, 2016 at 10:11 AM
    T4RFTMFW
    I don't 4x4 these days and back when I did my Chevy didn't have all the lifting quirks our Tacoma's do, so I can't really answer that one.
  5. Jan 28, 2016 at 10:12 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Diff drop is bull.
    Can you run stock shocks with Dakars? didn't know that.. :notsure:
    SixthSnail likes this.
  6. Jan 28, 2016 at 10:12 AM
    Josh828
    Josh828 Well-Known Member
    Josh
    Avery NC
    14 White TRD Off road, Mid travel mountain truck
    FOX 2.5 extended travel, Fox 2.0 rears, LR UCA, XSPX rims, some light bars, and switches
    Spend a little extra to not have spacers in the front since you are actually going use the truck offroad, just the peace of mind off road would be worth it imo. Also diff drop is basically bs from what ive read up on. Then again I only wanted 2inches of lift soo
  7. Jan 28, 2016 at 10:13 AM
    T4RFTMFW
    Can't.
    I didn't really read the rear suspension idea.. :anonymous:
    You'll need extended rear shocks or shock extenders (which are janky).
    geekhouse23[QUOTED] likes this.
  8. Jan 28, 2016 at 10:14 AM
    zth25
    zth25 Well-Known Member
    Zach
    Atlantic County x Philly
    2005 DCSB TRD OR 4X4
    887 1.5 AAL JBA UCA's 285/70/17 Trail Graps 17x9 Fuel Hostage Custom Headlights
    Billy's at 2.5 w/ top plate spacer > 3" coil spacer IMO.
    ChadsPride likes this.
  9. Jan 28, 2016 at 10:14 AM
    geekhouse23
    Thought so lol
    Good option for you OP would be 5100 shocks on the front with stock coils and OME nitrochargers in the rear :thumbsup:
    Speedytech7 and Josh828 like this.
  10. Jan 28, 2016 at 10:17 AM
    Josh828
    Josh
    Avery NC
    idk, if you are going to use your truck 15% offroad IMO you need a real suspension, coils, shocks, rear shocks at least...
  11. Jan 28, 2016 at 10:17 AM
    tacomgee
    tacomgee just ain't care....
    Blake
    NorCal - Ukiah
    2009 DCLB SAS in the works
    Save the $600. Then when you save another $600, spend the $1200 on a complete OME kit shipped to your door. Don't waste your time buying a shitty setup!
  12. Jan 28, 2016 at 10:26 AM
    imageomega
    Jarrod
    Whats the "why" behind front spacers being a concern, or not as trustworthy? Slippage/breakage/etc?
    The ride is fine. I don't have additional weight up front. I will rarely if ever fully articulate it. So if I dont need additional capability (beyond ground clearance), whats the story?
    Appreciate all the input!
  13. Jan 28, 2016 at 11:04 AM
    zth25
    Zach
    From what I hear, the ride is far from fine. Also they allow you to bottom out your stock shocks and break them.
  14. Jan 28, 2016 at 11:07 AM
    T4RFTMFW
    :rolleyes:
    That's nonsense.
  15. Jan 28, 2016 at 11:11 AM
    SixthSnail
    SixthSnail I have no idea what I'm doing
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    I have 5100s up front and extended 5100s in the rear with all pros expo leaf pack. Highly recommend getting billies. Very cheap, under 400 for a full set up
  16. Jan 28, 2016 at 11:55 AM
    imageomega
    Jarrod
    The ride should be exactly like stock. Same spring rate. Bottoming out is an issue, but as DCSBFTMFW pointed out, you've got to make sure you're not doing this by adjusting/replacing bumpstops.
    From everything I've read, 5100's (at the 2.5 level) on stock coils is a crap ride. I'd rather have 3" and a stock ride. I'm really not against 5100's, but if you then have to add coils your sitting at around a grand real fast and still have to figure the rear end out.
