Shop broke TPMS - replacements?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by clip, Jun 13, 2022.
  1. Jun 13, 2022 at 10:14 AM
    clip
    clip [OP] Well-Known Member
    VA
    15 OR
    pinstripes. lots of pinstripes.
    Got a shop to swap my tires and sensors to new wheels and in the process, both fronts now scan with my TPMS tool at 76 psi and the dash light stays on constantly. This is in addition to them chipping 2-3" of paint off of each wheel when dismounting the tires, not a happy camper.
    I talked to them today about replacements but have a feeling they'll be cheap/generic ones. Anyone experienced issues running cheap ones instead of OEM? Despite changing wheels/tires often and running low pressures off road, I'd still like to keep factory functionality so disabling the TPMS isn't on my list of options.
  2. Jun 13, 2022 at 11:56 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Average sensor battery life is about 7 years so getting new ones now is good timing.
    Generic ones with rubber stems are fine at most highway speeds. OE-style sensors with stronger metal stems are recommended for continuous driving above 100 mph.
    wi_taco and clip[QUOTED][OP] like this.
  3. Jun 13, 2022 at 1:12 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I've put Amazon Sensors in 3 different vehicles at about $20 each. They have all worked fine. Two of those vehicles I still own with no issues. Normally 7-10 years is the expected lifespan, but the ones were still working afte almost 13 years in my Tacoma. I replaced them proactively with the last set of new tires.
    clip[OP] likes this.
  4. Jun 13, 2022 at 1:21 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    I abandoned TPMS years ago, even buying new sensors from the dealer it seemed like one crapped out every other month and the one time I did have a puncture I could feel it before the light even came on.
    I have my mic for my head unit positioned to mostly block the annoying light since the "bulb" is an LED and can't be pulled and supposedly desoldering it causes other issues.
  5. Jun 13, 2022 at 1:34 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    Cheap ones work but probably (on average) won't last as long. OE if I'm not mistaken is Denso 550-0103 but some people/shops have had problems programming them in for some reason.
    Pacific 40005 is an OE equivalent you can get at Advance Auto but they are $60/each. Can confirm they work perfectly though for me, programmed fine for me using bootleg TechStream and I can read them using an Autel TS508 scanner.
  6. Jun 13, 2022 at 2:16 PM
    clip
    VA
    15 OR
    Thanks for the PN. I've got the TS501 that I should be able to program with. I've only used it to read the IDs so far.
    wi_taco[QUOTED] likes this.
  7. Jun 13, 2022 at 2:35 PM
    wi_taco
    Adam
    SE Wisconsin
    I feel real dumb saying this but I'm not sure how to program using my TS508. I've tried several times and it never seems to work. I also use it to read IDs when I do rotations and then program manually with my laptop & TechStream.
  8. Jun 13, 2022 at 3:15 PM
    Alealexi
    Alealexi Well-Known Member
    Houston, TX
    2007 Tacoma Prerunner
    You can find the same Denso sensor for $35 on rockauto.
    https://www.rockauto.com/en/moreinfo.php?pk=5707455&cc=1434686&pt=12036
