Shop cant get bolts off for alignment!
Discussion in 'Suspension' started by Tacomalover303, Aug 7, 2015.
  1. Aug 7, 2015 at 4:38 PM
    Tacomalover303
    Tacomalover303 [OP] Well-Known Member
    Colorado
    08 TRD Sport
    I need help here. Just put a lift on my 2008 sport. Did it myself.. two struts with coils and a AAL. Went to get a alignment and they cant get the cambers off. They said they need to cut the bolts out and torch the bushings. I found online I can get all 4 camber washers with bolts and new bushings for like $170.00 shipped to me. My questions is how hard will it be to cut the old ones out? What do I use? Im thinking a sawzaw will not do the trick. I'm not about to spend $1,000 for a shop to do this.
  2. Aug 7, 2015 at 4:40 PM
    la0d0g
    running for the hills
    For crawling not hauling
    Grinder? :notsure:
  3. Aug 7, 2015 at 4:48 PM
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    post over in the colo bs section there are a couple great toyota whispers over there..@lotsoftoys Jace helped with my seized bushings..maybe he has a few pointers to help out.. :)
  4. Aug 8, 2015 at 5:06 PM
    Tacorriendo
    Tacorriendo Well-Known Member
    Fred
    Texas
    2009 DCSB 4x4 Off-Road
    Front lift, ride rite air bags, side steps, rear camera switch.
    if you get the moog bushings, be advised that the front one will be slightly smaller than required which will produced the "clunk" noise many have reported here. I ended up putting two weld tacks on each side so they could stay put. My bushings and bolts were frozen. What I did, was that after loosing up the nut, I positioned flushed with the end of the bolt and went jihad on them with a sledge hammer till they gave up. If that does not work, I would recomend a reciprocal saw, but be careful not to cut the "ears" or LCA bracket.
  5. Aug 8, 2015 at 6:04 PM
    Tacomalover303
    Colorado
    08 TRD Sport
    Thanks for the heads up
  6. Aug 8, 2015 at 6:24 PM
    Trent_G
    Trent_G Well-Known Member
    Central Oregon
    What about spraying it with some penetrating oil (liquid Wrench or something similar). Let it sit overnight and try again. Wouldn't hurt.
  7. Aug 8, 2015 at 6:58 PM
    weldo
    weldo Well-Known Member
    Pittsburgh, pa
    2014 base ac 2.7 5-speed 4x4
    I've heard great things about a 50 - 50 mix of automatic trans fluid and acetone. Never tried it myself but read an article where it proved to be much more effective than any commercially available product.
    Taco Nation and Bentrodder like this.
  8. Aug 8, 2015 at 7:03 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Seized cam bolts is a pretty common issue
  9. Aug 8, 2015 at 7:08 PM
    weldo
    Pittsburgh, pa
    If you have access to a torch you could try heating the bolt up red hot, let it cool completely and then try turning it.
  10. Aug 9, 2015 at 6:53 AM
    Tacomalover303
    Colorado
    08 TRD Sport
    Yeah I got some and have been soaking it in there for a couple days. Going to take it to a different shop and see what happens.
  11. Aug 12, 2015 at 8:09 PM
    CASHORT
    CASHORT Well-Known Member
    Cory
    Whidbey Island WA
    2006 Black Sand Pearl TRD Off Road 98k miles
    Custom shovel, axe, fishing pole holders, Lumber Rack
    went through 2 ratchets on one and a breaker bar on an other thank god for life tie warranties
  12. Aug 12, 2015 at 9:30 PM
    Tacomalover303
    Colorado
    08 TRD Sport
    Screw it I'm getting new Lower arms with bushing in already. Going to cut the bolts out.
  13. Aug 12, 2015 at 10:57 PM
    Tacorriendo
    Fred
    Texas
    If you have the means, sure why not? FYI if you thought removing the bolts was hard, you would have had something else coming when trying to remove the old bushings, so I guess in your case, you made a smart move!
  14. Aug 13, 2015 at 4:31 AM
    weldo
    Pittsburgh, pa
    Anti seize the crap out of the new ones.
  15. Aug 13, 2015 at 7:32 AM
    Tacomalover303
    Colorado
    08 TRD Sport
    Don't they have grease points on some ?
  16. Aug 13, 2015 at 9:09 AM
    OZ-T
    Peter North
    British Columbia
    There are threads on the replacement LCA cam bolts and so far general consensus is fail
    Use the stick ones and lube them prior to install
  17. Aug 13, 2015 at 11:22 AM
    weldo
    Pittsburgh, pa
    I use a bit of anti seize on almost every bolt. If I take a bolt off, 9 times out of 10 I'll dab some anti seize on the threads before I put it back. Especially on things that come on and off somewhat frequently like lug nuts, caliper bolts and brake pad slide pins. It's a very rare occurrence to break the head off a bolt trying to remove it if it was anti seized. Using even a little will help future disassemblies go very smoothly. Also sometimes you need some kind of thread lube just to achieve the proper tightening torque.
  18. Aug 13, 2015 at 1:27 PM
    Tacorriendo
    Fred
    Texas
    Those will be the moog (problem solver), more like "problem added". I noticed that the grease would loosen the bolts over time. I realized this a year after aligment when I had to do another job that required me to loosen up the LCA bolts; they were very loose. I ended up removing them completely, removed all the grease and re-torque again to specs.
  19. Aug 13, 2015 at 2:34 PM
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Agreed, fuck the Moogs, all of my washers stripped out.
  20. Aug 13, 2015 at 6:43 PM
    Tacomalover303
    Colorado
    08 TRD Sport
    Good to know thanks guys
