Shop near Lynnwood, WA to do a CMC?
Discussion in 'North West' started by ReelAddict, Dec 10, 2018.
  1. Dec 10, 2018 at 11:46 PM
    ReelAddict
    ReelAddict [OP] Well-Known Member
    Rob
    Lynnwood, Washington
    2018 TACOMA TRD OFF-ROAD DBL CAB
    SUSPENSION: Bilstein B8 6112 Off-Road Suspension Kit - 47-234413 (5/4 Setting) Bilstein 600lb Front Coils Bilstein 5160 Series Shock - w/0" to 1.5" Rear Suspension Lift SPC Adjustable Upper Control Arms (SPC 25470) Wheelers Off-Road Multi-Leaf Add-A-Leaf Set - 1.5" Lift 3 Leaf Progressive Wheeler's Front Superbump Set Wheeler's Rear SuperBump Bumpstop Set Tacoma 2005-2020 Toyota 4WD - Carrier Bearing Shim Kit by Old Man Emu 2016-2020 Toyota Tacoma 4x4 (2"- 6" lift) Front Differential Drop Kit by Revtek Front Strut Mounting Kit KYB SM5640 WHEELS & TIRES: Venomrex 602 17" X 9" -12 Offset Coal Black Venomrex Red Center Cap Inlay NITTO Ridge Grappler All-Season Radial Tire-LT285/70R17 C Rated Cab Mount Chop PERFORMACE: Toyota OEM Intake Flow Accelerator Mod Toyota OEM TRD Air Filter MBRP Cat-Back Exhaust System Single Side Exit 3" Black Series Toyota TSB Software Update (Transmission) KDMAX Performance Tune LIGHTING: AUXITO H11 LED Headlight Bulbs 80W 16,000LM (High & Low Beam) Complete Interior LED Lighting Kit (Xenon White) NAKOBO White 29mm Festoon Led Bulb (Vanity Mirrors) XSPEED 7440 7441 T20 LED Light Bulbs XSPEED 921 912 906 W16W T15 LED Light Bulbs XSPEED 7443 7440 7444NA W21W T20 LED Light Bulbs CaliRaised Side Shooter Ditch Lights R4T Smoked White Grille Lights Meso Customs Ultimate Turn Signal CaliRaised LED 18W Slim Flood Work Lights (Roof Rack) DV8 Offroad BS20E100W5W BS-20 20" SL8 Slim Series LED Light Bar iJDMTOY Yellow Fog Lights CaliRaised LED 18W Slim Flood Work Lights (Bed Rack) STYLING & ACCESSORIES: TRD Pro Grille W/ OEM Garnish Sensor Cover N-Fab Textured Black Nerf Steps Coverking Neosupreme Seat Covers Full Front and Half Hood CHIPPROTECT by IDENS 30% Front Window Tint Toyota OEM TRD Skid Plate Toyota OEM Bed Mat Toyota OEM Bed Cleats Toyota OEM Door Sill Protectors Toyota OEM All-Weather Floor Mats Toyota OEM Blackout Emblem Overlay Kit Matte Black TRD Off-Road Decals Bed Net Organizer Storage Box Center Console Organizer EGR Matte Black In-Channel Vent Visors TAC Fender Flares Sprayed W/Line-X Smittybilt Smart Cover Tonneau Cover AJT Key Fob CaliRaised Low Profile Ditch Light Brackets BFP Heavy Duty Recovery Tow Hook (Painted In Super Red 2) TufSkinz Red Glove Box Insert Center Console Armrest Cover Cup and Console Liners 7" Screen Protector R4T Off-Road Badges Prinsu Design Cabrack Anti Glare Hood Vinyl Custom Rocker Panel Vinyl Mountain Graphics TacoVinyl Pro Grill Decal Pelican Vault V770 Case (2) Blacked Out Side Mirrors X-Bull Traction Board's DV8 Toyota Tacoma Center Mount Winch Capable Front Bumper OEdRo D Ring Shackles Mountain Hatch Tailgate Insert (Red) Toyota OEM Tailgate Power Lock Custom Tailgate Vinyl by IDENS Kentro License Plate Holder AJT Steering Wheel Overlay (Red) AJT Cup Holder Ring (Red) Meso Custom Door Handle Covers Prinsu Ridgeline Handles All-Pro Off-Road Bed Stiffeners Rek Gen Mud Flaps (Red Lettering) Original Quick Fists (2) 3" Quick Fist (2) RotopaX RX-DLX-PM Deluxe Pack Mount (2) RotopaX RX-1.75G Gasoline Pack RotopaX RX-2G Storage Pack First Alert Fire Extinguisher Bond LH043 Red Fiberglass Shovel Gzila Awning Mount Thule 4.5' Overcast Awning CaliRaised DItch Lights Switch CaliRaised Zombie Lights Switch Nexar NEXS1 Smart Dash Cam Ironman 4x4 Fridge Slide Frontrunner RTT Quick Release Mounts Thule X Tepui Explorer Kukenam 3 Yakima Roadshower 7G Havoc Off-Road Running Boards JoyTutus Portable Car 42 Quart Refrigerator
    Hello everyone. I'm new to the forum and a first time Taco owner. I'm looking for any recommendations for a shop near me that will do a cab mount chop at a fair price. I have a little bit of rubbing going on, now that I have 1.25" G2 wheel spacers installed. I just like the more aggressive stance. I got a quote for $400 to do both sides from a place here in Lynnwood. I have been told on another thread that is on the high side. Where did you guys go and what did you pay?
  2. Dec 10, 2018 at 11:49 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    What is your wheel tire combo? I used my adjustable SPC UCAs to move my wheel further forward in the wheel well to eliminate the need of any cutting and solved my rubbing issues.
  3. Dec 10, 2018 at 11:53 PM
    ReelAddict
    Rob
    The wheels are a 17x9 6x5.5 with 5.394 of backspace and +10mm of offset. Tires are 275/70/17 BFGoodrich KO2.
    Suspension:
    Bilstein 5100 Height Adjustable Front Shocks 2.75'' Lift (BIL 24-263108)
    Bilstein 5100 Shock Absorber (BIL 24-186728)
    OME 887 Front Lift Coils
    Pro Comp 1.5'' Medium AAL
  4. Dec 11, 2018 at 6:21 AM
    1cleanFG
    1cleanFG DialsGarage
    DialsGarage
    PNW
    2023 Sport 4x4 DCLB
    Toytec Alumaseries Coilovers OME El111R Camburg UCAs Scs sr8 17” 285/70/17 KO2
    Mule in Issaquah
    ReelAddict[OP] likes this.
  5. Dec 11, 2018 at 8:45 AM
    VewDew
    VewDew W7ZOM
    Seabeck, WA
    19 Taco TRD Pro / 13 LC200
  6. Dec 11, 2018 at 9:00 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Unsure if you can clear with 9” wide wheels and spacers, but have you tried rotating the cam on your SPC UCAs to move the wheel forward in the wheel well?
    I set mine 1 notch forward with similar diameter (though narrower) tires and fixed the rubbing issue. There are several more notches to push the wheel further forward in the wheel well to fix rubbing issues and avoid the CMC, so you may potentially not need to cut anything.
  7. Dec 11, 2018 at 9:41 AM
    ReelAddict
    Rob
    I will ask the shop if doing this will fix my rubbing issue. I'm also finding cheaper quotes (half the cost) for the CMC at other reputable 4x4 shops within my area. Thank you or the advice.
  8. Dec 11, 2018 at 11:56 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Are you game for TW'er that welds up good stuff (not me)?
  9. Dec 11, 2018 at 1:44 PM
    ReelAddict
    Rob
    Taking it to a well-known 4x4 shop in Everett with great reviews from customers.
    tonered[QUOTED] likes this.
  10. Dec 11, 2018 at 1:45 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That's cool. They look like they have the skills.
    I used to be in that area a lot and never knew they existed.
  11. Dec 11, 2018 at 1:47 PM
    Goran
    Goran Well-Known Member
    Jacob
    WA
    2023 Tundra Pro
  12. Dec 11, 2018 at 2:27 PM
    JimSnell
    JimSnell Well-Known Member
    Jim
    Puyallup
    2015 White Tacoma TRD Sport DCSB
    Thanks bud. I'm booked pretty solid right now, through new years. Also, I don't mind sharing the love with "a well know 4x4 shop in Everett".
    ST77, tonered and Goran[QUOTED] like this.
  13. Dec 11, 2018 at 3:33 PM
    ReelAddict
    Rob
    Which shop is yours in Everett?
  14. Dec 11, 2018 at 3:45 PM
    JimSnell
    Jim
    Puyallup
    Mine's actually in Puyallup, and shop is a strong word for it. I do chops in my garage when places like mule are all booked up.
  15. Dec 12, 2018 at 11:25 AM
    TimberTiger
    TimberTiger Get Western! ... ig @tcave87
    Tanner
    Arlington, Wa
    2014 DCSB Trd off road , 2002 Ext Cab Trd
    2014 DCSB: nitro 4.30 gears, Eaton/Harrop front locker, Bilstein 6112's w/ 650#, Camburg ball joint UCA's, Marlin cam tab gussets, Wheelers superbumps, Deaver U402 stage 2 leaves, bilstein b110's, u bolt flip, Archive hammer hangers, ADV weld co hybrid sliders, ADV weld co bed rack or Leer 180 w/ windoors, full RCI skids, SCS stealth 6, 35x10.5 kenda RT, ATH fab HC rear bumper, US offroad stealth front winch bumper, Smittybuilt x20 10k winch, ARB simpson III rtt, plenty of dents and scratches Now Sold 2002 TRD ext cab: 06 TRD Tundra coils, tundra 5100s, wheelers HD 3 leaf AAL, rear 5100s, ARB front bumper, SkidRow front skid, Leer commercial cap with windoors, 285/75r16 Kelly Safari TSR
    Aiden at Adventure Welding Co in Arlington, Wa. 425-231-3817
  16. Dec 30, 2018 at 2:43 AM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap
    Mule quoted me 250. Not a bad price at all.
  17. Dec 30, 2018 at 11:18 AM
    ReelAddict
    Rob
    I took mine to 4WP in Lynnwood and they priced matched a local shop. They charged me $259 out the door for parts and labor. I was very happy with the work they did.
  18. Dec 30, 2018 at 1:50 PM
    20somethingwidataco
    Will
    Washington State
    That's a decent price. I'd save that 9 bucks in gas just driving down the street Haha
