Shop recommendations for CV axle bushing install
Discussion in 'Arizona' started by jc63, Nov 28, 2021.
  1. Nov 28, 2021 at 6:46 AM
    jc63
    jc63 [OP] Active Member
    Arizona
    2020 Cement TRD Sport DCLB
    Any recommendations for a reputable/reasonable shop in the East Valley that can swap out the CV axle needle bearing for a clamshell bushing would be much appreciated. Thanks in advance.
  2. Nov 28, 2021 at 7:01 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Looking into the same thing. Talked to the dealership here and was told they install the ECGS bushing on all their lifted trucks. They quoted me a price of $800. :eek:
  3. Nov 28, 2021 at 7:08 AM
    BrysonHart
    BrysonHart Active Member
    Bryson
    2020 cement taco
    I am a very simple human
    I deliver packages for a living and have zero mechanical skill.
    I watched ecgs videos and ordered their “special” tools with the bushing and did it myself, it was incredibly simple, most time consuming part is getting the cv axel out.
    Low Ranger and jc63[OP] like this.
  4. Nov 28, 2021 at 2:36 PM
    Brian007Taco
    Brian007Taco 007Taco
    If you ask. You don't know me very well!
    Mesa, AZ to NM to OK to UT back to Mesa
    2012 Red TRD OR 4x4 DCSB (aka Clifford the Big Red Truck)
    12 OR DCSB 4x4 265/75/16 Goodyear Ultra Terrain wrapped on MB352's. OME 886's w/5100's front and back, and Dakars. Derped Emblems. KM Fab sliders, Mobtown Front and back bumpers w/tire gate, KM Fab Bed Rack, Bestop Supertop, Matt Gecko bed lights. Tree Smashed Taco 06 OR AC Prerunner! OME 885 with 5100's in front, TSB and AAL with 5125's in back. 30" light bar in the valance.
    These are simple to install. The link below for the tool works wonders and makes it so much easier to push the cv axle out. You can even twist it with your fingers too. A friend of mine has one and we used it when replacing cv axles.
    ABN 4in 2-Jaw Gear Puller – Removal Tool for Gears, Pulley, and Flywheel
    I ended up buying a spring compressor from O'Reilly's that way its easier to to get the LCA on, but you can rent it too.
    Suggestion is to buy an hub bearing assy that's already compressed.
  5. Nov 28, 2021 at 8:20 PM
    BrysonHart
    Bryson
    2020 cement taco
    Don’t need to take the Lca off dawg, just pull the brake assembly off the cv axle and tie off to the side, it doesn’t get in your way, no need to remove it
  6. Nov 28, 2021 at 8:24 PM
    BrysonHart
    Bryson
    2020 cement taco
