Shop said that T-Harnesses are nothing but trouble
Discussion in 'Audio & Video' started by Droz, Jul 1, 2021.
  1. Jul 1, 2021 at 5:50 PM
    Droz
    Droz [OP] FIDO
    2021 Tacoma TRD Sport DCSB
    I personally have no experience with a T-Harness when mounting an amp but it sure “seems” better than tapping or splicing the stock wiring harness.
    so do you guys tap or T?
  2. Jul 1, 2021 at 5:56 PM
    EricT
    EricT Well-Known Member
    Arizona
    '09 4x4 shortbed TRD Sport
    Do you mean for the main power source for your amp? I have heavy gauge dedicated lines, with a fuse block, running direct from the battery. That's pretty much industry standard. You don't want that power running in concert with your regular stuff, I don't think.
    Editing to add - you meant something else I wasn't understanding, so disregard this.
  3. Jul 1, 2021 at 5:58 PM
    Bishop84
    Bishop84 Well-Known Member
    For a head unit a harness makes sense, but for an amplifier you want clean power and ground, you make your own with a big fat fuse.
    EricT likes this.
  4. Jul 1, 2021 at 6:26 PM
    dolbytone
    dolbytone Well-Known Member
    South Carolina
    09 TRD Off Road
    T Harness if you plan to use the factory speaker wiring and need an amp turn on.
  5. Jul 1, 2021 at 6:50 PM
    Droz
    Droz [OP] FIDO
    Can you recommend a quality T Harness?
  6. Jul 2, 2021 at 2:26 AM
    dolbytone
    South Carolina
    09 TRD Off Road
    iData would be the first place I look. I think they make a harness for adding an amplifier for Toyota.
    Honestly IDK why anyone would prefer another method. Even if I had to build it myself using Metra connectors, I'd still be doing that over anything else.
  7. Jul 2, 2021 at 5:50 AM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    If a shop told you they DONT want to use a t-harness, just say “thank you for your time” and calmly leave. That’s not the shop I want anywhere near my expensive truck
    Philrab and Droz[OP] like this.
  8. Jul 2, 2021 at 6:18 AM
    Droz
    Droz [OP] FIDO
    And that is what I a doing... Thank you Dustin!
  9. Jul 3, 2021 at 6:43 AM
    jjglass535
    jjglass535 Well-Known Member
    Tampa, Fl
    2018 TRD Sport 4x4
    KDMAX Pro v.9
    I have an almost new Mr Marv t harness I'll sell. It's about 10" long
  10. Jul 4, 2021 at 8:43 AM
    Purpleman
    Purpleman Well-Known Member
    Anaheim
    15 PreRunner
    If theres a T-harness or Harnesses I can make into a T-harness, thats the route I take.
    When needed(rarely) I'll cut the factory harness making sure its able to go back to stock if needed.
    The problem with most shops is they don't care about the next person thats going to work on the vehicle, so the next person
    that usually ends up fixing the hackjob(usually me) gets F'd and has to work twice as hard to fix something that should have
    been done right in the first place.
    What are you planning on adding?
