Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
  1. Nov 6, 2020 at 8:29 AM
    #2101
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    I meant it as shaving one off but a heavy unibrow would be okay with me too o_O
    cory02taco[QUOTED] likes this.
  2. Nov 6, 2020 at 8:44 AM
    #2102
    Gregthespy
    Gregthespy Well-Known Member
    Greg
    Orlando
    2015 Blue Ribbon Metallic TRD Sport 4X4
    So, update on my mom’s mower deck. I cancelled the order that’s been pending for months, and ordered one from a (slightly sketchy) Ariens website. Says it should be here Tuesday, and that’s not a day too late! Here’s the current situation. I’m going to stake a tarp down under where she parks it so the ground moisture doesn’t attack it again.
    But for an 74 year old woman, I must say, she’s pretty capable to be mowing her 2 acres on her own.
    I keep offering to mow it, but she is like me and insists that she knows her yard and that I’d hit things and not mow it correctly. :notsure:
  3. Nov 6, 2020 at 8:54 AM
    #2103
    CrippledHo
    CrippledHo I'm calling about your car's extended warranty
    Eric
    Biggest Little Dumpster
    2016 DCSB Diet Coke
    Dents and a rattle can
    the superleggera version
  4. Nov 6, 2020 at 8:58 AM
    #2104
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Built in toe nail clipper area!
    I've repaired some that have been bad but I'd have to pass on that one :rofl:
  5. Nov 6, 2020 at 9:02 AM
    #2105
    Gregthespy
    Greg
    Orlando
    I told my mom that I could just put a “NO STEP” sticker over it and run it some more!
  6. Nov 6, 2020 at 9:07 AM
    #2106
    DLRIII
    DLRIII Well-Known Member
    David
    Baton Rouge
    2018 Quicksand SR5 DCSB V6
    Just in case you wondered how you cut a 23 CM diameter tube.
  7. Nov 6, 2020 at 9:09 AM
    #2107
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Is that a diamond blade or something else for cutting glass?
    Bigdaddy4760 and Gregthespy like this.
  8. Nov 6, 2020 at 9:12 AM
    #2108
    DLRIII
    David
    Baton Rouge
    Yep its a diamond coated blade, I think they're usually used for cutting ceramic. Most of the tools and machines we use were intended for different purposes. That saw is the only one with a large enough range of adjustment to cut the biggest tubes we have.
  9. Nov 6, 2020 at 9:18 AM
    #2109
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    That tube, is that something you can order to size and then make what you want with it or did you make that in house?
  10. Nov 6, 2020 at 9:23 AM
    #2110
    Gregthespy
    Greg
    Orlando
    I notice the tube is on rollers, is that so you can rotate it against the diamond blade? I assume it would be risky to plunge cut something like that, if it binds I can imagine it’d be a costly disaster.
    Also, I just noticed it’d be impossible to plunge cut it in full since the blade diameter is restrictive of it.
  11. Nov 6, 2020 at 9:28 AM
    #2111
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Powdercoater has the hitch burnt off, now he’ll sand blast it and paint it green or textured black next week :confused:
  12. Nov 6, 2020 at 9:30 AM
    #2112
    CrippledHo
    Eric
    2016 DCSB Diet Coke
    We've used the same technique with concrete form tubes. Just cant plunge a blade all the way so it's easier to hold it steady and rotate the tube
  13. Nov 6, 2020 at 9:32 AM
    #2113
    DLRIII
    David
    Baton Rouge
    We order all of the tubing and rod we make everything out of, the factories that make the material are massive. They have furnaces the size of rooms, its and industry of its own.
  14. Nov 6, 2020 at 9:33 AM
    #2114
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Kind of like a steel mill but for glass, got it :thumbsup:
  15. Nov 6, 2020 at 9:37 AM
    #2115
    DLRIII
    David
    Baton Rouge
    Yep you got it, even if there were enough exposed blade the likelihood of binding and breaking is very high. Even with small tubes we usually spin it to get a good score on it before plunging through, then if it cracks its almost always in the cut zone anyway. Larger tubes are way more likely to crack because their own weight acts against them when they're close to breaking free
  16. Nov 6, 2020 at 9:38 AM
    #2116
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    How long does it take to cut tube like that?
    Bigdaddy4760 and six5crèéd[OP] like this.
  17. Nov 6, 2020 at 10:07 AM
    #2117
    DLRIII
    David
    Baton Rouge
    I cut it into rings 1.61" tall, 34 of them, and it took probably 2 hours total. Each one i cut has a rough edge so I take them to the lapper to get them flat and smooth again so I'm going back and forth between the saw and lapper the whole time.
    Each cut took maybe 2 minutes or so, i go slow to minimize breaks and improve the cut edge.
  18. Nov 6, 2020 at 10:30 AM
    #2118
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
    *sigh*
    "That's not how I do it."
    Repeat as necessary. :laugh:
  19. Nov 6, 2020 at 10:38 AM
    #2119
    Gregthespy
    Greg
    Orlando
    :rofl::rofl:
    I’m not about to argue with her as she’ll win for sure!:argue:
  20. Nov 6, 2020 at 10:40 AM
    #2120
    Bigdaddy4760
    Maner
    Poolville Texas
    Don’t be building no super sized crack pipe
