Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
  1. Aug 21, 2021 at 2:02 PM
    My Name is Rahl
    Looks like a crane/bucket truck stabilizer pad.
    T-yoda, Fargo Taco, tacotoe and 2 others like this.
  2. Aug 21, 2021 at 2:21 PM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    Could be. I’ll find a use for it sometime :D
  3. Aug 21, 2021 at 2:26 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Well fellers, by now it should be apparent that occasionally the things I buy aren't all that practical... :confused:
    In this latest installment of "what the heck did rusty drag home" I have corrected this.
    It has been hot so I bought an air conditioner -- (...wait for it...)
    -- built about 1952. :crazy: I found an advertisement.
    The stickers remind me of a famous unicorn truck. :boink: The round grill turns 360 degrees (by hand) to direct the air how you want.
    Lift the metal lid to access the controls and filters.
    Naturally I needed my elderly helper to unload, this thing probably weights 120 pounds.
    As this hadn't operated for unknown years (decades) a bit of cleanup/inspection/lubrication was in order.
    Compressor contact, maybe people were smart enough back then to not take the cover off and touch things?
    It doesn't have a thermostat - just a cool position and high & low for the fan. The exhaust position runs the condenser fan only and is used with the door in the exhaust position.
    This door opens to the outside in two positions - ventilate and exhaust. There is a screen to keep critters out. Closed when cooling.
    The indoor (evaporator) fan, there is a coil on each side along with a mesh filter.
    Plug not polarized or grounded.
    Wiring diagram, back when folks fixed appliances. Notice the monster of a compressor lurking in the background. It is mounted on coil springs too.
    So I plugged her in --
    -- from a distance --
    -- and --
    Let 'er rip tater chip!
    Running with the cover off here in the garage it is quieter than the modern unit in my living room.
    :thumbsup:
    So there, I bought something practical -- as practical as a 120 pound, 69 year old air conditioner gets. :crazy:
  4. Aug 21, 2021 at 2:37 PM
    My Name is Rahl
    Now...install it in a window without your elderly helper...
  5. Aug 21, 2021 at 2:41 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Need to be a big sturdy window. It is 26" wide and 16" high. :benchpress:
    The fork lift is my do all helper, I use it for all kinds of things here. Just need to stay off the grass, the times I have thought "it is just a couple feet, shouldn't get stuck...". Yeah, it doesn't work that way...
  6. Aug 21, 2021 at 2:42 PM
    My Name is Rahl
    Ah, so more of a split unit than a window unit.
  7. Aug 21, 2021 at 2:49 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    It is all in one like a modern window unit, just giant and heavy for a 9000 btu machine.
    I would sure split something it I tried to pick it up off the floor.
    six5crèéd[OP], T-yoda and tacotoe like this.
  8. Aug 21, 2021 at 3:20 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    That had to be fun picking up
  9. Aug 21, 2021 at 3:35 PM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Good score!
  10. Aug 21, 2021 at 3:38 PM
    tirediron
    Guessing it might make the old electric meter spin a skootch faster than a modern unit...
  11. Aug 21, 2021 at 5:23 PM
    Tacoma Mike
    Southern Maine
    Great
    A $2000.00 ash tray
  12. Aug 21, 2021 at 5:46 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Update: I found an advertisement for my new unit from 1952.
    About 16 amps full load so just about double a modern unit of similar capacity -- just like the size and weight.
    What I found unusual is that there in no thermostat, when you set it to cool the compressor comes on and stays on. The evaporator fan has a high and low setting but the compressor runs constantly. I have found units from the 60's that had thermostats just like the modern units.
    Slender and stylish 1952 lady in her air conditioned bedroom.
  13. Aug 21, 2021 at 6:17 PM
    DLRIII
    DLRIII Well-Known Member
    David
    Baton Rouge
    2018 Quicksand SR5 DCSB V6
    The list was basically inclusionary, not exclusionary and nowhere in any of the regulations were goats even mentioned, which is kind of odd I think. Can't be that they'd let me start breeding them and keeping 20 goats around. As far as nosey neighbors, the neighbor I see all the time next door has no problem with it, the other is a single (divorced/separated) guy who works 2 jobs and is basically never home. The level of neglect of his back yard would make it laughable if he decided to start making calls on me. He could actually use some goats to clean his yard up lol.
  14. Aug 21, 2021 at 6:58 PM
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    ARE Topper, Icon aal, OEM Audio+
    That some cool stuff Rusty. I recall a former coworker telling me about the days before or before many people could afford a refrigerator. There was a place where you would go and buy a large block of ice to keep goods cool.
  15. Aug 21, 2021 at 7:00 PM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    Only 42 lb. 1/3 of @RustyGreen's "new" A/C.
    Use your goats to clean his yard.
  16. Aug 21, 2021 at 8:24 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Up until the early 1930's when refrigerators became affordable and reliable every town had an "ice man" who came around daily. There is a family business in town that sells bagged ice, 5 or 6 generations ago they delivered ice with a horse drawn wagon.
    I remember when I was a kid the old folks talking about the ice man and how women delivered the ice, coal and other items during World War 1. It was a big deal for ladies to be driving trucks back then.
  17. Aug 21, 2021 at 9:19 PM
    tirediron
    Sell it to the military?
  18. Aug 22, 2021 at 3:25 AM
    Tacoma Mike
    Southern Maine
    $4000.00 then
  19. Aug 22, 2021 at 4:38 AM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    wow you should estimate jobs
    Scrap and time
    Sorry if it upsets you!
  20. Aug 22, 2021 at 5:01 AM
    Tacoma Mike
    Southern Maine
    You should see the shit I built in the shop.
    I built motors from spare/used parts at lunch time..
    Upset?
    Take a fuck of a lot more than that.
    It is cool but dam I think you’ll break your foot if you dropped it. lol
    RustyGreen, tacotoe and T-yoda like this.
