Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
  1. Nov 20, 2021 at 4:33 AM
    Hunterdc1
    Hunterdc1 1st shift Waste Control stupidvisor
    Brrrrother
    Mamas don't let your cowboys grow up to be babies
    13 8 lug ltz gasser
    New guy at work just got off work probation and promptly bought a 2020 Sierra At4, it's gorgeous. Have to remind myself not to be envious, it's tough.
  2. Nov 20, 2021 at 4:47 AM
    Cwopinger
    Cwopinger Random guy who shows up in your threads
    Blevin
    Florida
    2019 Quicksand Tacoma OR DCLB
    ARE MX, mud flaps, radio knobs, floor mats
    :eek::eek::eek::eek::eek::eek::eek:
    :crazy:
    That is just freakin insane, to pay that much for wheels AND to have to “make them fit”. SMDH
    Slashaar, Fargo Taco, tacotoe and 5 others like this.
  3. Nov 20, 2021 at 4:48 AM
    Cwopinger
    Blevin
    Florida
    And good morning Shane, Inc.
  4. Nov 20, 2021 at 5:19 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    I used to go to a lot of auctions, dangerous places...
    Got a lot of great stuff like the 1960 air compressor -- and also hauled home tons of crap too...:ballchain:
    Says Rusty: ":) Hey, this is cool!" --- and later --- "WTH was I thinking.... :confused:"
  5. Nov 20, 2021 at 5:20 AM
    Tacoma Mike
    Southern Maine
    Yea but if you didn’t take it then it’s “Dam I should have grabbed that”..
  6. Nov 20, 2021 at 5:23 AM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Kicked myself with that one too...
    Rusty >>:smack:<< Also Rusty
    Slashaar, Fargo Taco, tacotoe and 4 others like this.
  7. Nov 20, 2021 at 5:28 AM
    Hunterdc1
    Brrrrother
    13 8 lug ltz gasser
    This isnt a fancy auction house, it's near my camp in BFE so I'm expecting some junk to be floating around. I can't wait.
  8. Nov 20, 2021 at 5:31 AM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    They are the best ones, happy hunting. :thumbsup: (and post pictures!)
  9. Nov 20, 2021 at 6:06 AM
    Kilo Charlie
    Kilo Charlie Disruptor
    Iowa
    2017 Inferno Off Road
    So... some of you have mentioned powder coating which led me to miss my old set up. So now I have a new idea and need your brains to tell me if it's a feasible idea or not.
    For the powder to cure, I need a chamber that can hold 400F for at least 20 minutes plus any additional time for preheating parts etc. In the past I used and old electric oven but in my current garage I don't have 220... so.. my brain says I can convert an older propane smoker I have into an oven. I have other and newer smokers that I use for food so it's not like I am losing anything there.
    It's a single walled beast that wouldn't work as is. I feel like making it a double walled contraption with insulation in-between the walls to hold the heat in. I fell like eliminating the smokestack on top is a must as well. Some form of plate in the bottom to seal it and provide a barrier between the propane burners and the chamber. Some angle iron near the inside top to hold a shelf that the parts would hang from.
    I guess my biggest questions is what to use for insulation between the panels, how to monitor the internal temp accurately and thoughts on the bottom plate thickness.
    Thoughts, questions, comments and concerns are welcome.
  10. Nov 20, 2021 at 6:17 AM
    Hunterdc1
    Brrrrother
    13 8 lug ltz gasser
  11. Nov 20, 2021 at 7:18 AM
    My Name is Rahl
    You'll probably need some sort of insulation like they use in gas forges.
  12. Nov 20, 2021 at 7:28 AM
    Tacoma Mike
    Southern Maine
    They do have Powder Coat I.R. Lamps that you can use.
  13. Nov 20, 2021 at 7:35 AM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    I've got an oil-filled heater like that's closer to 15 yr old. I used it for supplemental heat when I was living in NM where the houses that I rented had crap for insulation and crappy non-central heating. It works great. I haven't needed it much in the last 5 yrs since I moved out of NM, but it worked great last Dec when I was without the main heater in my house for about a week waiting for a new furnace.
    Holy crap. What brand are the wheels?
    If you going to go through the trouble of needing to make an insulated box, why not just build a box out of sheet metal and insulate the outside of it. Build a separate heater box with a fan and plum ducting in/out of opposite sides of the oven box. You can use 110V heaters and easily hit 400F continuous with the air recirculating. At my last job, we built ovens out of 2" foil covered rigid foam and aluminum tape with 110V heaters. The ovens were single use, and they'd max 400F. At those temps the foam inside the insulation and tape adhesive starts to cook. If you want it re-useable, I'd make the inside of the box out of sheet metal and put rockwool around the outside. You could build the heater box out of sheet metal and use fire bricks inside of it for thermal mass and to keep the outside from getting too hot.
  14. Nov 20, 2021 at 9:52 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Depends on what Brand some Alpo Flavors are quite good.
    Having done work in different Food manufacturing plants over the years on average Pet Food plants seem to have higher standards then many of them were many years newer to be fair.
  15. Nov 20, 2021 at 10:01 AM
    Bivouac
    When I see that No user serviceable parts That is like a challenge to a duel !!
    It might come down to being not able to find parts or any one who sells them.
    After all it is not working what more damage can I do at that point.
  16. Nov 20, 2021 at 10:16 AM
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    ARE Topper, Icon aal, OEM Audio+
    Lots of fun going on around here today.
    No luck filling deer tag this AM, but again spooked one out. Without any preparation to the area..like just a little clean up of sticks and tree branches at least...I imagine we sound like a herd of Buffalo walking in there.
    Back at home, red neck engineering at its finest in a minute or so...not going to replace this clutch master cylinder and slave just yet. A little examination and I can see one issue is the clutch pedal not returning up all the way, and a bushing that's worn out. Bushing is where this fancy engineering comes in....Replacement radiator for my daughter's Jeep had extra fitting for trans cooler. I'll make a proper oil-lite soon but until then, this fitting after I cut it will be within thousandth of a inch from what I had drawn up to makeo_O
  17. Nov 20, 2021 at 10:17 AM
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
    There are a ton of those around town and every time I think they look really good. Something about that AT4 package.
  18. Nov 20, 2021 at 10:21 AM
    Bivouac
    I guess like anything else all Cajun Food does not need to be so spicy it burns going in and coming out.
    I grew up with no spicy condiments never smoked so catsup is about all I used If I was being really brave Honey Mustard but that was in my later years.
  19. Nov 20, 2021 at 10:21 AM
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    My work there's several of them, we'll including the GMC versions.
    Just remember guys, they also have a price tag two time higher than our Tacomas.
  20. Nov 20, 2021 at 10:46 AM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Might be easier to put 220 to the garage. Good for welders, air compressors, etc too.
