Shop Time w/T.W. Friends
Discussion in 'Garage / Workshop' started by six5crèéd, Jun 5, 2020.
  1. Jan 16, 2022 at 6:51 AM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    Snow! Ice! Good morning friends!
  2. Jan 16, 2022 at 6:52 AM
    Tacoma Mike
    Southern Maine
    That’s it, a row maker.. TY
  3. Jan 16, 2022 at 6:54 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Too bad you aren't closer. I'd pull the middle interior trim piece to take the striker off, beat the metal back to where it "should" be, and crank my welder to "11" :laugh: For those saying it's gonna require extensive surgery; it's a 2000 Blazer. It might have a couple more usable years left. I've seen many striker areas put back welded like I would do...
  4. Jan 16, 2022 at 6:55 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Ugh, we're getting that crap later on today. I somehow have to get the beater started to move things around in the garage...
  5. Jan 16, 2022 at 6:56 AM
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    :facepalm:
  6. Jan 16, 2022 at 6:56 AM
    Kilo Charlie
    Kilo Charlie Disruptor
    Iowa
    2017 Inferno Off Road
    All that time for the screen door and you have it propped open LOL
  7. Jan 16, 2022 at 6:58 AM
    Kilo Charlie
    Iowa
    Making it all on your own is going to be more satisfying. Make sure you post up the finished product!
  8. Jan 16, 2022 at 7:00 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Wrapping the band iron is not hard at all. Just have to weld and work it as you go.
  9. Jan 16, 2022 at 7:03 AM
    Tacoma Mike
    Southern Maine
    Not applicable in current conditions
  10. Jan 16, 2022 at 7:09 AM
    Kilo Charlie
    Iowa
    I assume you'd use some flat bar and work your way around.. I think it would be cool to wrap the inside of the leg holes too to sort of tie it all together. Would be a little more work but the little details can take a project from cool to AWESOME.
    Wait a day.. the weather will change
  11. Jan 16, 2022 at 7:12 AM
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
    This CAD guy thinks you did a great job! A bit of mirroring and centering the cut outs and presto! :fistbump:
  12. Jan 16, 2022 at 7:14 AM
    Fargo Taco
    Fargo
    2019 TRD Pro
    If the ID of the holes matches the OD of a piece of pipe, that would be a simple addition.
    Says the guy that's never done any of this... :laugh:
  13. Jan 16, 2022 at 7:16 AM
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    ARE Topper, Icon aal, OEM Audio+
    I was just about to tag you and ask about the welder your using on the Talon. It looked to work fine for what your doing. My thoughts exactly about the repair.
  14. Jan 16, 2022 at 7:21 AM
    Tacoma Mike
    Southern Maine
    Plenty of ways to repair from perfect to various stages of not bad to various stages of red neck..
  15. Jan 16, 2022 at 7:23 AM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    This was @ 5:30 am with pea size chunks of sleet falling.....
  16. Jan 16, 2022 at 7:28 AM
    Kilo Charlie
    Iowa
    The look would be off unless the thickness of the pipe is the same thickness of the flat bar used on the edges.. and I too have not done any of this.. but I can certainly see it in my mind LOL
  17. Jan 16, 2022 at 7:33 AM
    Fargo Taco
    Fargo
    2019 TRD Pro
    I had the words "matching pipe" in my post originally but took it out. If you can't find one that matches, I'd absolutely leave it out.
    Thinner walls might look alright, too, but not thicker.
  18. Jan 16, 2022 at 7:52 AM
    Kilo Charlie
    Iowa
    We're getting good at planning other people's projects! HAHA
  19. Jan 16, 2022 at 8:19 AM
    koditten
    Kirk
    Central Michigan
    Most will just dimple die the holes. It's faster, and doesn't require more iron.
  20. Jan 16, 2022 at 8:20 AM
    koditten
    Kirk
    Central Michigan
    I'm still learning the CAD software.
    18 months ago I could not even draw a square.
